Strange noise?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Julian lucas, Mar 10, 2022.
  1. Mar 10, 2022 at 1:04 AM
    Julian lucas
    Julian lucas [OP] Member
    2015 access cab 4x4
    2015 tacoma access cab 4x4 off road.
    Strange groaning vibration noise off and then on every few seconds when coasting and gassing. Got worse when I put a level kit and blocks on. Everything up front seems tight, bearings and such. Could it be drive shaft bearing?
  2. Mar 10, 2022 at 1:10 AM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    Sounds like you might need the ECGS bushing.. what speed does this happen at?
    See if you can upload a video of the sound.
  3. Mar 10, 2022 at 1:32 AM
    Julian lucas
    2015 access cab 4x4
    All speeds but especially noticeable when coasting at high speeds
  4. Mar 10, 2022 at 1:55 AM
    gsubioguy
    gsubioguy Well-Known Member
    Evan
    Maine
    '21 TRD OR
    Does it go away in 4wd?
  5. Mar 10, 2022 at 2:00 AM
    Julian lucas
    2015 access cab 4x4
    Haven’t tried it. What would that do?
  6. Mar 10, 2022 at 2:17 AM
    gsubioguy
    Evan
    Maine
    '21 TRD OR
    IF it's the needle bearing the vibrations/noise will stop with 4wd engaged. But based off you saying it's occurring at all speeds it's likely not the culprit. However, the 4wd test is quick & easy way to verify/eliminate it as a cause.
    Island Cruiser likes this.
  7. Mar 10, 2022 at 2:18 AM
    gsubioguy
    Evan
    Maine
    '21 TRD OR
    The needle bearing is a known/very well documented problem once the front is lifted ~1.5"+
  8. Mar 10, 2022 at 5:23 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    I vote needle bearing.
  9. Mar 10, 2022 at 10:47 AM
    Julian lucas
    2015 access cab 4x4
    Wow you guys were absolutely right. I put it in 4wd high range and vibration stopped.
    Is the ecgs bushing same as needle bearing?
  10. Mar 10, 2022 at 10:48 AM
    Julian lucas
    2015 access cab 4x4
    Yes it got worse after I lifted 2 inches. Will it always be a problem?
    gsubioguy likes this.
  11. Mar 10, 2022 at 10:50 AM
    fourfourone
    yup. I've had mine installed for about 30k now. Still smooth.
  12. Mar 10, 2022 at 12:41 PM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    It's a replacement for the needle bearing and works better.
    gsubioguy and Island Cruiser like this.
  13. Mar 10, 2022 at 2:06 PM
    Julian lucas
    2015 access cab 4x4
    Does the passenger side need to be replaced as well? I just read that it is different is that true?
  14. Mar 10, 2022 at 2:29 PM
    Taco'09
    Taco'09 Well-Known Member
    OP, the ECGS fix is a bushing. Toymoco later came out with a TSB that was intended to be an improved needle bearing to the one that came with the truck from the factory.
    The passenger side has an entirely different set up but uses the same OEM needle bearing. The difference is the right does not see the same side loads as the drivers. As far as I know, I may be the only one on this forum that also replaced the passenger side with the ECGS bushing. But I have not typically advocated also using the ECGS bushing on the right.
  15. Mar 11, 2022 at 10:23 AM
    amyracecar
    amyracecar suck it up buttercup
    Virginia Applejack
    SouthEast USA
    2013 AC V6 MT OR Spruce/Mica
    I have a similar issue on a similarly configured truck - 2013 AC with a 1-½ in lift up front - but the vibrational noise is only really audible when I first start it up/OTW out my hood. I heard it last winter on the few cold days we had, then it went away when it got warm - now it is back and the 4H switch does seem to make it go away - gonna test again tomorrow.
    My question is - if this is the culprit, shouldn't the noise be more consistent?
    Not just after start up?
  16. Mar 11, 2022 at 3:02 PM
    Beerline123
    Beerline123 Well-Known Member
    07 Tacoma access 4x4
    Check the air intake at the passenger fender. The foam they use to stop vibrations wears off there. Good luck
