strange noise
Discussion in 'New Members' started by dave6558, Mar 17, 2010.
  1. Mar 17, 2010 at 4:32 AM
    dave6558
    dave6558 [OP] Member
    Long Island
    10 TRD Sport
    rmote start. undercarriage backup lites, soon to have heated mirrors and signals
    Hello, I'm new to the forum. I have a '10 crewcab trd sport longbed. It makes a strange noise. Most times, shortly after startup, and I think it has to be in gear, you can hear a servo noise or small electric motor noise that lasts about 2 seconds. I don't think it happens again until the next startup-----and it doesn't seem to happen every time---(I only have 200 miles so IDK), This seems to come either from the firewall or behind the glove box. Any ideas ??? Thanks in advance.
  2. Mar 20, 2010 at 1:24 PM
    MAG TACO
    MAG TACO New Member
    SUN DOGG
    4x4 MAGNETICALLY TACO
    I believe that sound is directly related to your ABS diagnostic system. That sound is completely normal (per Service Foreman who I met a couple days ago). The sound to me...is similar to a compression type of noise but your description seems to be along the same type. In fact, you are probably hearing that sound from the front passenger fender/engine area. When you don't hear that sound...well, then you should be worried.
    Just part of the normal diagnostics that the vehicle will go through after you start it. The sound should come on after the vehicle has moved forward a couple feet or more.
