Strange "Pinging" at low rpm's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jross20, Apr 26, 2018.
  1. Apr 26, 2018 at 11:56 AM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Mine does the same and I'm meticulous with all maintenance. I do an occasional techron treatment and have tried some 89 octane. I try to stick with Chevron gas. Seems to be better.
    jross20[OP] likes this.
  2. Apr 26, 2018 at 12:53 PM
    jross20
    jross20 [OP] Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
    I did change the oil yesterdayybut I only use the OEM filters which I buy in bulk. Using the same oil, Pennzoil 5w-30 high milage.
  3. Apr 26, 2018 at 12:53 PM
    jross20
    Georgia
    I was thinking of running some seafoam through the gas.
  4. Apr 26, 2018 at 12:55 PM
    eon_blue
    Azusa, CA
    Best way to use Seafoam is to run one can through the gas, and use another can (the spray can kind) through the throttle body. It does a much better job of cleaning when done through the TB, the gas tank is more just for the fuel system. But doing both is the best of both worlds.
  5. Apr 26, 2018 at 1:04 PM
    taco2010trd
    Tampa, Florida
    I'd recommend the seafoam in the throttle body. Didn't seem to do anything when I put it in the gas tank. Techron is a better option for the gas tank imo.
    jross20[QUOTED][OP] likes this.
  6. Apr 26, 2018 at 2:48 PM
    jross20
    Georgia
    Now when you guys say throttle body, how are you going about doing so? I've only ever done it in my previous cars via the brake vacuum hose.
  7. Apr 26, 2018 at 3:13 PM
    Spiffy09
    Spiffy09 Well-Known Member
    '10 White TRD O/R DCSB
    Seafoam makes an aerosol version now, that way you can spray it directly into the throttle body.
    taco2010trd likes this.
  8. Apr 26, 2018 at 3:16 PM
    eon_blue
    Azusa, CA
    Don't want to do it via the brake hose, at least not on Tacomas...I read somewhere on here that it only feeds into a few cylinders or something like that when you do it that way. Through the throttle body is best, the can that is posted above is the one you want. It has a special straw on it that hooks on the throttle body intake tube and sprays right past the butterfly valve while the RPM's are held steady at ~1.5k. It's easy to do, there are instructions on the can that are easy to follow.
  9. Apr 26, 2018 at 3:19 PM
    Spiffy09
    Not sure which 2nd gens use an electric vacuum pump for the brakes, but my 2010 does and there isn't a vacuum hose from the intake anyhow.
    I'm pretty sure there's a post with which hose to use if you don't want to spray it directly into the throttle body, I'll see if I can find it.
  10. Apr 26, 2018 at 3:21 PM
    eon_blue
    Azusa, CA
    yeah I'm not too sure how different it is for you guys versus my 1st gen, but doing it via the throttle body insures that it's doing what it was intended to do..and the aerosol can version of Seafoam is much safer to use via the TB than the older liquid cans that you had to pour....pour it too fast and your engine is toast. The aerosol can sprays slowly and in a fine enough mist that you don't have to worry about seizing the motor.
    One thing to watch out for though is that you have to make sure your RPMs are at about 2k, if they're too low then the butterfly valve doesn't open up enough for the Seafoam to get through it and it all runs back out through you air intake and ruins your aEm Pro Dry filter....ask me how I know, lol
  11. Apr 26, 2018 at 3:24 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Costco is on the TT list, believe or not
  12. Apr 26, 2018 at 3:25 PM
    jross20
    Georgia
    Toast? Back in automotive school they actually taught us to use the liquid on the vacuum line and near the end to flood and kill it. Then we let it set for 30 minutes, then crank it up. Does this really break stuff? I've done it to 3 vehicles without any issues :poking:
  13. Apr 26, 2018 at 3:27 PM
    eon_blue
    Azusa, CA
    There was a guy on the Yotatech forums a few years back that started this huge thread about how he hydrolocked his motor using Seafoam...I've been terrified of that happening ever since. I'm sure it's not common but I remember even on those liquid pour cans they had a warning saying to take it to a mechanic to have them do it via the throttle body or vacuum line, presumably for that reason I figured.
    Anyhow with the aerosol can it's a non-issue really
    Spiffy09 and jross20[QUOTED][OP] like this.
  14. Apr 26, 2018 at 3:28 PM
    Spiffy09
    I think he's getting at potentially hydrolocking the engine while doing it, you're not just supposed to shove the vacuum line in the can and wait for it to drain it. You want to always keep a decent mixture of air and seafoam going into the vacuum line, it also helps the seafoam atomize better.
    jross20[QUOTED][OP] and eon_blue like this.
  15. Apr 26, 2018 at 3:28 PM
    #35
    jross20
    Georgia
    That is crazy, see they taught us that you basically wanted a lot of the liquid to hangout onto of each cylinder for a while to eat the carbon up. Now I am afraid to try it... lol
    As in, the last bit of seafoam you would dump in to stall out the engine, then let her set a while. After 30 minutes and a long crank they would fire up and pump out insane amounts of crap for a while, then we were taught to floor it a few times up and down the road to clear it out.
    eon_blue[QUOTED] likes this.
  16. Apr 26, 2018 at 3:29 PM
    #36
    Spiffy09
    I'd have to imagine he damn near poured the whole can into the line then started it, I think you'd be pretty hard pressed to actually hydrolock an engine with Seafoam. That said, I still put my finger over the lid a little bit and let the vacuum of the engine draw the liquid out slowly.
    jross20[OP] and eon_blue[QUOTED] like this.
  17. Apr 26, 2018 at 3:30 PM
    #37
    eon_blue
    Azusa, CA
    I just stick with the aerosol can now lol. Easy to use and pretty much worry free
  18. Apr 26, 2018 at 3:31 PM
    #38
    Spiffy09
    Like I said, just don't pour it straight in. Just keep a little air and liquid going.
  19. Apr 26, 2018 at 3:31 PM
    #39
    jross20
    Georgia
    Ok so aerosol, but back to the original issue... Does anyone think this will help the pinging? I am going to experiment on my way home from work today to see if she still does it.
  20. Apr 26, 2018 at 3:33 PM
    #40
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    TT?
