strange popping/ clinging noise when in 4wd
Discussion in '1st Gen. Tacomas (1995-2004)' started by xxOkieTacoxx, Oct 7, 2014.
  1. Oct 7, 2014 at 9:03 PM
    xxOkieTacoxx
    xxOkieTacoxx [OP] Well-Known Member
    Jake
    Texarkana, TX
    99 Tacoma SR5 3.4L 4x4/ 16’ DCLB TSS
    3.4L V-6 W/ custom intake,Flomaster super 44 dumped, 15" Incubus Alloy Wheels W/33x12.50 Yokohama Geolander MT'S, Bilstein 5100 Adj W/ OME 881coils, Pro Comp rear leafs W/ Bilstein 5100 shocks, Manual Hubs, Diff. Drop,Custom front bumper w/ winch W/ keyed disconnect and 2 250,000CP running lights, relocated blinkers, front bumper removed, radiator guards, custom skid plates, Rhinolined interior,
    1999 Tacoma v6 with locking hubs. My 4wd works but when I start to climb a steep hill or go through some boggy mud I hear this loud echoing clinking noise (best I can describe it) it sounds like its coming from the passenger side front but I might be wrong. Its hard to tell when I'm in the truck. I was thinking ujoints at first but that would be on the drivers side. Its like gears are slipping cause when it starts doing it the 4wd works but I can tell its not pulling up the hill the way it should. I just hope its not something in my diff. Anyone have this happen?
  2. Oct 7, 2014 at 10:41 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Is this a refference to manual locking hubs?
    Is so, try various combinations of the hubs locked and unlocked to see what changes. Put it 4WD and only lock one hub. If the sound goes away you've isolated it to that corner.
    You can even try 4WD with neither hub locked.Still got the same noise? Looks like its the diff.
    The diff, the CV joints (inner and outer) and the hubs and bearings could all potentially make the kind of noise you are describing.
  3. Oct 8, 2014 at 7:00 PM
    xxOkieTacoxx
    Jake
    Texarkana, TX
    Thanks for the reply. I'll try that.
