Strange problem with the electrical system
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dragsterhund, Sep 14, 2014.
  1. Sep 14, 2014 at 3:02 PM
    dragsterhund
    dragsterhund [OP] Member
    Charlie
    Washington DC
    2005 Access Cab V6 4.0L
    Hey everyone,
    I'm having an electrical problem that I'm having a difficult time diagnosing. Came out to my truck the other night, and it wouldn't start. It was doing this:
    https://www.youtube.com/watch?v=xfy-vkMkpM4
    In that video, I'm trying to start the car, and it looks like the ECU keeps tripping and resetting.
    I get some jumper cables, and get the car started. Starts right up. The voltage on the scan gauge is jumping around all over the place:
    https://www.youtube.com/watch?v=nV25BhdCty4
    In this video, the engine is just idling in neutral. Notice the voltage.
    I decide to start driving, thinking the battery just needs to be charged under load. The voltage is still hopping around:
    https://www.youtube.com/watch?v=weFZJbeVxII
    Usually, the voltage is 14.1 or 14.2, rock steady.
    After about 30 minutes of driving, I park the car, turn it off, and try to restart it immediately.
    https://www.youtube.com/watch?v=AEjbPB5uqVs
    Same thing as above.
    Truck is a 2005 V6 4.0L 4X4.
    Battery is about 5 months old.
    Scangauge II is the only modification to the vehicle.
    Does this appear to be a battery problem, an alternator problem, or a regulator/rectifier problem (inside the alternator, if I understand this correctly)?
  2. Sep 14, 2014 at 4:10 PM
    pouyeux55
    pouyeux55 Member
    canada (QC)
    I would start by looking if the main ground is good in place
  3. Sep 14, 2014 at 4:11 PM
    surfermatt
    surfermatt Well-Known Member
    CA
    04 prerunner, ext cab
    Front long travel custom: king 10" CO, solid lowers, fabbed spindle, heimed everything ect. Rear still in progress, waiting to be put on: bilstein 9100s, T100 axle. Stock 3.4 engine, 4.30 gears.
    Yup the ground my guess
  4. Sep 14, 2014 at 7:06 PM
    TugBoatTrash
    TugBoatTrash Face first!! Hammer down!!!
    Bob
    E. Freetown MA
    15 DC Tundra SR5
    Do dents and scratches count?
    Loose battery terminals.
  5. Sep 14, 2014 at 7:14 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    Loose terminals at battery.
  6. Sep 15, 2014 at 8:08 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Check battery terminals and if they are good have the battery load tested at the auto parts store. ( usually free ).
  7. Sep 15, 2014 at 9:44 AM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Check the cables as they can rot inside the insulation. Clean ALL connections you can - Ground at Bat and Engine. Grounding connections to Vehicle/straps to chassis, Both ends of the Pos cable.
    Also , Most shops will test your Battery an Alt for free. Take advantage of it, The more things you check and test the closer you get to the fix. (The last fix is right fix! )
  8. Sep 15, 2014 at 9:48 AM
    Aw9d
    Aw9d That one guy
    This. Seen something close to this and it turned out the cable from the Alt to battery was bad at one of the ends.
  9. Sep 15, 2014 at 3:01 PM
    Mcdees84
    Mcdees84 Well-Known Member
    Tallahassee, FL
    2014 MGM DCSB-TRD O/R
    I would unplug the scanguage from the OBDII port first. Then disconnect neg terminal and reconnect. See if it starts and returns to normal. Sometimes, Scanguage and Ultraguage can miscommunicate with the ECU and cause weird issues like that - its rare, but can happen. If that is it, go to scanguage and look at their manual. There is usually something you can do to the programming that will fix this problem.
