strange raddle!!
Discussion in 'Suspension' started by ETaco23, Mar 25, 2008.
  1. Mar 25, 2008 at 6:00 PM
    ETaco23
    ETaco23 [OP] Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I was hoping someone could help me out, I have a strange raddle when I hit a bump or something, I really cant figure out what it could be. Im guessing the skid plate, Bc of the diif drop. Its really close, about touching it. But really dont know if that could be it. Has anybody had this happen with a 3" spacer lift? Any help appreciated!
  2. Mar 26, 2008 at 3:30 PM
    spp
    spp OC, Kalifornia
    OC California
    Have you checked the back for a RADDLESNAKE?
  3. Mar 26, 2008 at 4:30 PM
    ETaco23
    Evan
    PNW
    HaHa.... Not funny! Its bugging the shit out of me. I cant find out what it is.
  4. Mar 26, 2008 at 4:39 PM
    ETaco23
    Evan
    PNW
    Could even be possible for the skid plate to be rattling agains the diff drop?
  5. Mar 26, 2008 at 4:39 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    try pushing in on parts of the skidplate. if it moves a bit, you may want to put a small spacer in to get it away from what its hitting. also, do you have nerf bars?? if so, check the mounting plates on them......could be hitting the frame a bit. let us know what you find.
  6. Mar 26, 2008 at 4:40 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    could be....and a spacer would correct the problem then for sure.
  7. Mar 26, 2008 at 8:08 PM
    ETaco23
    Evan
    PNW
    Thanks for the posts, I will check things out this weekend, See what I find. But If It is the skid plate, do you know where I can find or get some spacers?
  8. Mar 27, 2008 at 2:18 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    actually, you can use a few washers or so, but look at lowes/home depot, where they have nuts/bolts bins and they may have some type of spacers there.
  9. Mar 29, 2008 at 2:30 PM
    ETaco23
    Evan
    PNW
    Well I looked at my skid plate and It is up tight to the diff drop, But its not loose. Its up tight and I really dont think that could be it. Could the suspension shocks and coils be rattling when I hit a bump? Any Help appreciated!
  10. Mar 29, 2008 at 3:03 PM
    2003greenbean
    2003greenbean Carolina Alliance Costal Div
    socaste,sc
    03 trd
    cold air intake, step bars, custom grill, 3in lift,12 in audiobahn sub, 285/75/16 procomp tires, 20% tint,
    do you leave your trailer ball in all of the time
  11. Mar 29, 2008 at 5:19 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    Have you had the raddle ever since the lift ? If not I would take it back and ask them to re-check everything. I think this would be wise after any kind of lift installation anyway.
  12. Mar 29, 2008 at 5:36 PM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    some times the 3" coil spacer lifts can cause the top of the spindle to hit the coil just barely... usually going over low speed large bump like speed bump... you can grind the little point off the top of the spindle
  13. Mar 29, 2008 at 5:42 PM
    ETaco23
    Evan
    PNW
    Dont have a trailer ball
  14. Mar 29, 2008 at 5:46 PM
    ETaco23
    Evan
    PNW
    Sounds like that could be the problem. Im having my rear 3" block taken out and putting my AAL's/1" spacer in soon. I will have them look into it, see if they find anything. Could this cause any serious problems? should I be worried in the mean time.
  15. Mar 29, 2008 at 8:13 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    Maybe the spare tire ? Does the exhaust have any heat shields ? maybe an exhaust pipe hanger ?
  16. Mar 29, 2008 at 10:09 PM
    ETaco23
    Evan
    PNW
    maybe? I'll be putting on my new exhaust this coming week, so ill take a look. thanks.
  17. Mar 30, 2008 at 7:30 AM
    350TacoZilla
    Hancock MD
    the coil hitting isnt any type of dangerous or harmful thing...its annoying though... I got lucky with mine and they clear but V6 trucks have slightly thicker coils so they can contact alittle more
