Strange rear brake issue- Please advise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DBrooks, Oct 3, 2021.
  1. Oct 3, 2021 at 10:34 AM
    DBrooks
    DBrooks [OP] Member
    Dale
    Maine
    2008 Tacoma 4x4
    Starts out that one day the rear drivers side brake drum on my 2008 Tacoma 4x4 became extremely hot. I took the drum off after it cooled down and expected either a frozen wheel cylinder or a bad wheel bearing. The bearing seemed to be OK so I just went ahead and installed a new wheel cylinder, bled the brakes and put everything back together. I went for a short road test and I'm having the same exact issues with the drum being hot. This is where I'm lost. I've looked at the brake assembly and that appears to be ok, I'm able to remove the drum by hand without to much resistance and without the brake drum installed the hub/axle turns freely( with the rear wheels off the ground of course). When I put just the drum back on I can turn the axle but there is a noticeable resistance and it sounds like it is the brake lining contacting the drum but it will turn. Now if I hand tighten 2 of the wheel nuts I can not turn the drum and axle. Has anyone got any ideas what it could be, Thanks.
  2. Oct 3, 2021 at 10:37 AM
    tcjacado
    tcjacado Well-Known Member
    Your brake shoes are dragging on the drum. How many clicks does the e brake handle go...?
    Readjust the shoes with the adjustment wheel and back it off a couple of notches.
    Jimmyh, wilcam47 and whatstcp like this.
  3. Oct 3, 2021 at 10:39 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Have you verified your parking brake cables aren't seized?
  4. Oct 3, 2021 at 10:44 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    You don't mention adjusting the adjuster. Turn it in a turn or two.
    wilcam47 and tcjacado like this.
  5. Oct 3, 2021 at 11:52 AM
    DBrooks
    DBrooks [OP] Member
    Dale
    Maine
    2008 Tacoma 4x4
    I have not messed with the parking brake. I have turned the star wheel all the way in to minimized the brake shoe diameter. What I can not get my head around is the fact that I can easily put the drum on and off but as soon as I tighten down the drum it seizes.
  6. Oct 3, 2021 at 12:07 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    im not certain................
    check the backing plate on the rear axle housing
    be certain it is ‘ square ‘ to the axle housing & axle
    after tightening...........it sounds like the torque is distorting the backing plate
  7. Oct 3, 2021 at 12:23 PM
    DBrooks
    DBrooks [OP] Member
    Dale
    Maine
    2008 Tacoma 4x4
    I'll check out the backing plate but the friction sound appears to be associated with the shoes. Question. If the parking brake was frozen at that particular brake, and that is causing the issue, would I be able to put the drum on and off fairly easily? This just not make any sense to me.
  8. Oct 3, 2021 at 1:18 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Also make certain the mating surface of the drum, axle and wheel are clean and free of rust and corrosion otherwise when it's tightened down it may not sit square on the axle.
  9. Oct 3, 2021 at 2:30 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Have you removed both drums recently and got them back on the wrong sides? I did this once and had one side getting so hot you could smell it. After a couple of days, I figured it out, swapped the drums back to their respective sides and all was well.
    The shoes and drums wear into each other over time.
  10. Oct 3, 2021 at 2:37 PM
    ROAD DOG
    FEW
    the OP had only mentioned specifically 1 side
    i had not considered the possibilty U have correctly mentioned as cast iron is very directional
  11. Oct 3, 2021 at 3:20 PM
    DBrooks
    DBrooks [OP] Member
    Dale
    Maine
    2008 Tacoma 4x4
    I think I have found the problem. The emergency brake cable appears to be frozen in the expanded or partially expanded position. Tomorrow I will take the assembly apart to confirm, but I'm pretty confident that is my problem. Thanks to everyone for their helpful suggestions. This forum is great.
    Dm93 likes this.
  12. Oct 3, 2021 at 3:30 PM
    ROAD DOG
    FEW
    hope that is .....................
    yet if Uv heated the 1 side a few times
    not likely that side is even with the other side
    might want to rehab the rear axle all around
  13. Oct 3, 2021 at 6:24 PM
    winkel
    Corydon, IN
    Good find, let us know how it turns out!
  14. Oct 3, 2021 at 7:26 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    When you reassemble:
    Dm93 likes this.
  15. Oct 3, 2021 at 7:30 PM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    Always replace the springs when replacing brake shoes or wheel cylinders. I had a brake failure once caused by not replacing the springs.
    Mudsock likes this.
  16. Oct 3, 2021 at 10:22 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    They must be making these springs differently now. I have done more drum brakes than I can count and I have only replaced a few springs usually the small ones that hold the shoe to the backing plate and once when I lost one while it was disassembled. :shrug:
    Dm93, Too Stroked and 6 gearT444E like this.
  17. Oct 4, 2021 at 8:37 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    My old springs would have worked fine but the whole bag of hardware for both sides was only $10 and worth it for new. The only thing worth getting out of that kit was the horseshoe clips that hold the parking brake to the shoe assembly. The old springs can easily be reused though.
    Dm93 likes this.
  18. Oct 4, 2021 at 8:45 AM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Had a drum out of round that will grab/drag only going one direction. Not sure, but the emergency cable will balance between both sides where it connects under the center console. You may want to check that mechanism as well to include if the drum or drums aren't out of round.
  19. Oct 4, 2021 at 5:27 PM
    Waasheem
    Waasheem
    2007 xrunner
    I too have done north of 600 drum brake jobs. The springs will generally last unless you do something like park it submerged in salt water. I have seen the little pins that hold the shoes to the backing plate with springs and cups break in two. So I plan on replacing the pins springs and cups. I always pull the boots on the wheel cylinders back just enough to check for leakage.
    cosmicfires, Jimmyh and Dm93 like this.
