Strange revving while stopped at Red light
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacomalife1990, Aug 7, 2016.
  1. Aug 7, 2016 at 10:21 AM
    Tacomalife1990
    Tacomalife1990 [OP] Active Member
    2016 tan tacoma trd sport
    Ok so I was stopped at a red light, when suddenly my truck started revving up on its own. It jumped from its normal idle to around 2000rpm and then dropped back to normal it's did this 3 times before the light changed. Any ideas or similar situation.
  2. Aug 7, 2016 at 10:29 AM
    melman8r
    melman8r Well-Known Member
    NY
    '17 TRD Off Road AC w\Prem & Tech Pkg. in Quicksand
  3. Aug 7, 2016 at 10:32 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Normal....could be a number of things... A/C kicking on and off, injector cleaning cycle, etc. It also makes a tapping/knocking noise, as some describe it, when idling at times. This is a noisy motor (at times).
  4. Aug 7, 2016 at 10:56 AM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    How many miles on your vehicle??
    And no. I can't recall that happening to me while stopped with my foot on the brake at a light.
    Also, I would not consider a 2k rev jump while stopped at a light in drive, a normal occurrence unless there was an accidental tap on the throttle.
    I recommend a visit to your dealer.
    Hope that helps
    Cheers!
  5. Aug 7, 2016 at 10:58 AM
    Tacomalife1990
    I've noticed lol. The day I got mine I made them start just about every tacoma on the lot cause of the "sewing machine noise" just didn't sound healthy
    The hammer and Arailt like this.
  6. Aug 7, 2016 at 11:00 AM
    Tacomalife1990
    Just hit 10,000
    The hammer likes this.
  7. Aug 7, 2016 at 11:06 AM
    The hammer
    At 10k, you should be running smooth, I would get it checked
    Good luck
    Cheers!
  8. Aug 7, 2016 at 11:22 AM
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    2000 RPM is a bit of a stretch to be normal. That is a really high idle for this truck. 1-1.2k max for idle with A/C compressor cycling.
    Good luck reproducing it for the dealer though....you're better off trying to capture it on video so you have proof before getting the 3 hr "could not duplicate" treatment.
    taco 16 likes this.
  9. Aug 7, 2016 at 11:26 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Is your AC on during this? More than likely it's just the AC kicking in. It's a common thing, and no cause for concern.
    EDIT: Nevermind. Reread OP and noticed the RPMs were increasing, and not decreasing.
  10. Aug 7, 2016 at 11:27 AM
    aero90
    2000 RPM for the AC?
  11. Aug 7, 2016 at 11:27 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I edited my last post.
  12. Aug 7, 2016 at 11:31 AM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
  13. Aug 7, 2016 at 11:32 AM
    SothernTaco
    SothernTaco Well-Known Member
    Danny
    Tomball
    Turd Gen
    Mine has not/does not do this. I'd definitely call the dealer. If your dealer as anything like mine, good luck getting them to duplicate it and even if they can, good luck getting an actual answer other then..."ohh, that's within the normal operating parameters of the vehicle". I'm pretty sure I could bring my truck to my dealer with it shooting flames and missing the intake and they would say its normal, or tell me its because I sat in traffic for more then 27 minutes and its not covered under warranty.
  14. Aug 7, 2016 at 11:34 AM
    The hammer
    I would give the dealer a chance to check it out and see what they say first.
    Hope that helps
    Cheers!
    Aussiek2000 likes this.
  15. Aug 7, 2016 at 12:11 PM
    smitty99
    Scottsdale
    Yup
  16. Aug 7, 2016 at 12:26 PM
    jonnyozero3
    jonnyozero3 Well-Known Member
    Dry places
    '99 TRD OR V6 M/T
    OME, sliders, dents, hail damage, soiled armrest. Lightbulbs.
    I've seen this on my 1st gen. Problem was the side of my foot hitting the go pedal while braking. Doh.
    Lawfarin likes this.
  17. Aug 7, 2016 at 12:32 PM
    Tacomalife1990
    It was a very quick thing it reved and dropped immediately then about 20 30 sec later it did it again
  18. Aug 7, 2016 at 12:35 PM
    The hammer
    OP here’s a though or something I would try if it was me.
    I would ask the service rep if they have an experienced tech recently factory trained in engine performance, and if they have a lab scope he will have access to in trouble shooting the issue, they should.
    If they say they can’t that’s something I would discuss with Toyota corp, or/and I would then tell them I’ll call them back and try another dealer.
    Next to experience, a lab scope is the best way I know of identifying an intermittent issue.
    Hope that helps
    Cheers!
  19. Aug 7, 2016 at 12:52 PM
    The hammer
    I find it helpful, at least we know it's not just on the '16 but could be in the ecm, or some type of rare fuel system glitch, so again, an experience engine performance tech would be my best friend here.
    Cheers!
    patrick70 and Tacomalife1990[OP] like this.
  20. Aug 10, 2016 at 5:03 AM
    Velocityrick
    Velocityrick New Member
    The Surge is from the demand of the Power Steering Pump. At idle lean on the the Steering Wheel and straighten back out you will notice the Surge.
