Strange Smell coming from the AC Vents
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bradwhitenikki, Jan 25, 2017.
  1. Jan 25, 2017 at 5:27 PM
    bradwhitenikki
    bradwhitenikki [OP] Well-Known Member
    Brad
    2016 Tacoma Trd Off Road 6sp Auto
    Hello All,
    I am getting a foul smell coming from my air vents when I disengage the AC and have my vent on recirculation with the temperature on low. I had this issue since I had 2000 miles on the truck. Any ideas? It seems like something is molding up.
  2. Jan 25, 2017 at 5:29 PM
    InSight Retrofits
    InSight Retrofits Closed
    Pull your cabin air filter out and see if it's wet or anything.
    Odd for a new truck unless somehow water is getting into the vent system from the cabin air intake.
    dYL0n likes this.
  3. Jan 25, 2017 at 5:30 PM
    bradwhitenikki
    Brad
    Great advice. I will check it out.
  4. Jan 25, 2017 at 5:33 PM
    FiaCobra
    FiaCobra Well-Known Member
    Lol, reminds me of a story about a mechanic who get really pissed at a customer once and shoved fish pieces down the defroster vents.........did you piss off your mechanic lately ?....lol
    stealthmode likes this.
  5. Jan 25, 2017 at 5:33 PM
    erok81
    erok81 Well-Known Member
    Imposter
    When you turn off the ac but still keep the thing flowing air?
    I'm every car I've ever been in they all have weird smells when that happens. New or old.
    Maybe I'll try it tomorrow in my Tacoma. I haven't tried yet in this one.
  6. Jan 25, 2017 at 5:35 PM
    2Toyotas
    2Toyotas Well-Known Member
    Ken
    Western NC
    '13 Taco SR5 AC
    Condensation drain line plugged?
  7. Jan 25, 2017 at 5:36 PM
    bradwhitenikki
    Brad
    I am my mechanic. Yes, I pissed myself off, but I skipped the fish.
  8. Jan 25, 2017 at 5:37 PM
    bradwhitenikki
    Brad
    It will be interesting to see what you find. I had over 20 cars in my life. This is a new one for me. Of course, I normally replace my filters.
  9. Jan 25, 2017 at 5:45 PM
    erok81
    Imposter
    Interesting. Those cars I mentioned never changed those filters. But the again I had a 2015 BRZ with 5k or so and I'm pretty sure it had that really weird smell when turning off the ac like that. Maybe like a dirty swap cooler or something.
    Oh...have you ever been in a car in the summer where you've used the ac, gone into a store, then started the car and the blower was on but not the ac. It blows out some smelly humid air. Is it like that?
    I'll try tomorrow and see. My truck has 6k. It's pretty cold here but I'll give it a shot.
  10. Jan 25, 2017 at 5:47 PM
    bradwhitenikki
    Brad
    The best I can say is it smells like a moldy heat exchanger. I just never expected that on a 3 month old Toyota.
  11. Jan 25, 2017 at 5:49 PM
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    A little mud can plug up the drain line.
  12. Jan 25, 2017 at 6:04 PM
    bradwhitenikki
    Brad
    Makes sense, but I have not been off roading since I bought the truck.
  13. Jan 25, 2017 at 6:06 PM
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    Don't have to off road to get it. Spray up from the road.
  14. Jan 25, 2017 at 6:08 PM
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    Oh, you know the puddle of water when you park to go in the store and come out to see it on the ground?
    Thats the drain line working.
    InfernoTonka likes this.
  15. Jan 25, 2017 at 6:12 PM
    bradwhitenikki
    Brad
    Good point. I will have to check for the drip.
  16. Jan 25, 2017 at 6:18 PM
    MeFryRice
    MeFryRice Well-Known Member
    Marietta, Ga
    '16 QS Tacoma DCOR4x4
    I've had to replace my cabin filter after my most recent trail ride. Anytime I turned on the AC, we were tasting dust. I will say the oem filter feels flimsy so I would check out your options in the aftermarket world before spending money on a factory part.
    The factory drains can get clogged (how quick depends on where you park everyday) but typically your floorboard becomes wet if the AC drains are clogged.
  17. Jan 25, 2017 at 6:18 PM
    erok81
    Imposter
    This sounds stupid, and just as I thought, this is super common.
    I googled this exact quote "ac smell when turning off" and found a ton of threads on different cars with this type of issue. One of the vw ones had some "solutions" to fix it. Even popped on new cars.
    I always thought that was just a common thing with ac and never thought twice about it.
  18. Jan 25, 2017 at 6:19 PM
    bradwhitenikki
    Brad
    I am thinking stinky heat exchanger fins.
  19. Jan 25, 2017 at 6:30 PM
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    I have had the drain plugged, sprayed smelly mist, but no water on floor. Maybe I fixed it sooner than that.
  20. Jan 25, 2017 at 7:00 PM
    Citadel
    Citadel Well-Known Member
    Weird for a truck that new.
    Thoughts:
    • Clogged drain hose- crawl underneath and unclog with thin stiff wire
    Note: Drive with the AC on fresh if you can.... at a minimum when you are about to shut the truck off, switch the ac to fresh.... Recirculate allows moisture to remain on the fins of the evaporator and that causes mold over time.
    Good luck!
