strange smell?
Discussion in '1st Gen. Tacomas (1995-2004)' started by bfred13, Jan 22, 2012.
  1. Jan 22, 2012 at 10:57 PM
    bfred13
    bfred13 [OP] Member
    brittany
    04 tacoma trd
    Lift
    Hey all, my husband is currently deployed so I was left with his truck. we just had to replace the ball joint and inner and outer tie rods becaus the ball joint broke. The ABS light is on but i was told at the shop i needed a new sensor but wouldnt harm anything other than i may not have abs. i drove to truck to walmart and when i got home and got out my brakes smelled like they were burning like burning rubber. is it still safe to drive? what could the smell be? Please help i have to drive it from nc to florida and i dont want to lose my brakes.. thanks in advance...
  2. Jan 22, 2012 at 11:03 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    something is wrong!..will be hard to diagnose over the internet..but the more precise symptoms and info on exactly what is going on will be insightful for us and maybe we can help you out!
    but in the mean time, take it a worthy repair shop or even a Toyota dealership and let them see whats going on.
    would be helpful if you give details on the truck itself such as year, 2 wheel drive or 4x4.
  3. Jan 22, 2012 at 11:10 PM
    bfred13
    bfred13 [OP] Member
    brittany
    04 tacoma trd
    Lift
    It is a 4x4. Trd sorry i dont kniw much about it. my friend said it kind of smelled like rubber and i have literally just put tires on it so could it just be the smell if the tires? It smelled like rubber and asphalt... but the brakes work just fine.. im about to sell this thing.
  4. Jan 22, 2012 at 11:23 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Look on the tires, especially the inside, for wear marks. Compare to the rear tires for reference. If everything looks the same, the tires aren't it. Brakes are tricky, have it inspected by a certified ASE brake tech, or dealership(some are iffy).
    Broken ball joint? If it broke while you were driving, I would suspect there are larger problems than just the ball joint.
    Let us know what the tech says. We can only guess without some more facts.
  5. Jan 22, 2012 at 11:47 PM
    bfred13
    bfred13 [OP] Member
    brittany
    04 tacoma trd
    Lift
    We got everything fixed from the ball joint luckily he was only pulling out of a parking spot and not going fast. i just noticed it today and i have driven it quite a bit since the ball joint issue. The tires have 50 miles on them and i never noticed it before tonight. i have smelled the smell before on my mazda and the dealership told me my brakes were hot and it was because it was cold out and they had not been used in a few days. i slammed on the brakes a few days ago then got under to make sure no brake fluid was leaking and it wasnt. Damn this truck its fine and when 1 things goes everything goes we just had to put 2k into it we i cant handle much more..
  6. Jan 22, 2012 at 11:50 PM
    bfred13
    bfred13 [OP] Member
    brittany
    04 tacoma trd
    Lift
    If it helps at all it is a 2004 v6 TRD 4x4 with a 3 inch lift.. i just got size 285/75/16 tires for it..
  7. Jan 22, 2012 at 11:55 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    Best thing is get a estimate somewhere, burning smell is not good, pop the hood check your brake fluid level. With no visible signs of smoke coming from anything specific your gonna have to look harder. Does it smell at idle, or just when your driving? Happen only when you apply brakes? Need more info. If you just upgraded to 285's another possibility you could be burning your clutch if it's a stick shift.
  8. Jan 23, 2012 at 12:06 AM
    bfred13
    bfred13 [OP] Member
    brittany
    04 tacoma trd
    Lift
    I only noticed it when i parked it and got out after driving 3 miles but i was using the brakes. there was no visible smoke and the brake fluid is good but i will double check it in the morning. it is an automatic so its not the clutch. is there a chance is was just because the brakes were wet and cold? It rained here for 2 days and i hadnt driven it for those 2 days. im sorry this is so complicated i dont knoe who else to ask and i know before my husband left he was all over this site so this was the fiest thing that came to mind..
  9. Jan 23, 2012 at 12:12 AM
    907taco
    Bobby
    Alaska
    Well something is not right, wet and cold should not cause this. Not to sound like an ass but you have the parking brake off right?
  10. Jan 23, 2012 at 12:19 AM
    bfred13
    bfred13 [OP] Member
    brittany
    04 tacoma trd
    Lift
    That made me laugh haha. No i don't use the parking break. The shop told me the tires might smell as i am wearing them in but i dont know what smell they meant. i dont know i will probably just stop in and ask them tomorrow. Im sure they hate me by now i forgit to give them the tire key when i took it in to get new tires... -_- but when i got out of the truck and smelled it as soon as i smelled it it went away like it didnt linger around.. first sniff i smelled it second sniff it was gone..
  11. Jan 23, 2012 at 12:25 AM
    stewartx
    stewartx Well-Known Member
    Huntsville AL
    2012 Silver DC SB TRD Off-Road
    Winch, front hitch, step bars, bed extender, bed step, gull-wing toolbox, tailgate lock, security system, cb radio, etc.
    Assuming the odor has only occured once and not excessive, I wouldn't be immediately or overly concerned. The smell could come from not fully disengaging the parking brake, riding the brakes while driving, or a contamination of one or more of the brake pads. Drive it (carefully) one or two more times to see if the odor goes away.
    However, I wouldn't ignore, nor put off repair of, the ABS warning light. And I most certainly wouldn't take the truck on a long trip with that warning displayed. Get the problem fixed, and have them check out that odor in the process.
  12. Jan 23, 2012 at 12:34 AM
    bfred13
    bfred13 [OP] Member
    brittany
    04 tacoma trd
    Lift
    After the amount of money we just dumped into it we dont really have enoung. the sensor alone is 360 bucks. the sensor itself isnt bad but when the tire fell in from the ball joint it stretched the line connected to the sensor. i triple checked with the shop if it was safe to drive and he had said yes just get it fixed when you get there and it is just going to be like an older car without abs. also my husband had said the sensor could have grease on it because the cv boot tore and grease went flying everywhere but we got that fixed. i just dont know what to do with this thing its breaking the bank.
  13. Jan 23, 2012 at 1:12 AM
    stewartx
    Huntsville AL
    The warning light could just as easily be an indication of another problem (low brake fluid, etc). Leaking brake fluid could also be a source of the smell. Thus, if you're really determined to travel with that warning light displayed, at least check the brake fluid level often, including before and during the trip.
    By the way, some auto parts stores, such as some AutoZones, will check the ABS diagnostic codes for free, provided you eventually have the problem fixed by them. The resulting code might provide a better indication of the problem.
    Anyway, that's about all I can offer here. Good luck with your trip.
  14. Jan 23, 2012 at 9:45 AM
    bfred13
    bfred13 [OP] Member
    brittany
    04 tacoma trd
    Lift
    Okay, so I checked the brake fluid and it is not low. I just drove it about 12 miles to my friends house and when I got out it didn't make the smell. I even stuck my head in the tire well and there was no smell at all. She was probably just being a tempermental c*** at that point in time because it is fine now.
  15. Jan 23, 2012 at 10:14 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    [​IMG]Welcome to TW from Sparks, NV[​IMG]
    It could be the tires rubbing on the UCAs if they are stock. Did it have that size tire on it before?
  16. Jan 23, 2012 at 10:20 AM
    crazyengineer
    crazyengineer Well-Known Member
    patrick
    Bristol, TN
    05 Tacoma SR5 TRD Offroad
    K&N Cold Air Intake, Warn Winch and Bumper Guard, Wet Okole Seat Covers, Undercover Bed Cover, TRD Kenwood Head Unit, Infiniti Speakers, JL 13.5 inch pancake sub
    the parking brake was my first though, my sister drove her car 4 or 5 miles home with the parkin brake on. Had to completely replace the brakes and i believe the disks as well
    so now when i hear burning rubber, that is always what i think of
    good luck figuring out what it is
  17. Jan 23, 2012 at 10:27 AM
    NicNac22
    NicNac22 D.I.L.L.I.G.A.F
    Nic
    Wild and Wonderful
    95 V6 4x4 ex cab SR5 5sp PICKUP!!!
    fun stuff coming soon! New battery, radiator and CV joints and axles. Added some Rancho RS5000 shocks.
    if you didnt use the parking brake, you brake pads could have stuck a little from normal braking. Is the smell only on one side? just becareful when you smell that, that the brakes dont heat up enough to melt to the rotor and seize up....(ive done that)
    if its only doing it occasionally which it sounds like, it might be from when the tire fell in and goofed up your brakes a little bit, maybe bent it a little. if you can get the tire off inspect the pad yourself see if there is any uneven wear on it.
    just becareful driving when you smell the burning rubber.
    EDIT: mine was caused from using the parking brake and when i released it, it did not fully disengage and they melted to the rotors :(
  18. Jan 23, 2012 at 1:16 PM
    oldstick
    oldstick Medicare Member
    GA
    Was there an alignment check done after replacing the ball joints and arms?
    If not it could be way out of alignment and the tires wearing real hard causing the rubber smell.
  19. Jan 23, 2012 at 1:28 PM
    focotacoma
    focotacoma Well-Known Member
    Fort Collins
    07 Speedway Blue 4x4 TRD off-road
    Im getting there......
    Are you sure the ABS isn't malfunctioning due to the sensor or whatever you need to replace. For instance are the brakes lightly engaged...allowing you to drive but not hold speed. (Does the truck coast as it did before without gassing?)
  20. Jan 23, 2012 at 1:48 PM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    Two things:
    1. New tires can smell strong for quit a while. I had new tires put on my wife's minivan and I can still smell them after 6 weeks. Not a strong burning rubber smell, but it does smell like rubber.
    2. I recently cleaned my throttle body. Some of the cleaning solvent ran down the side of the engine, taking some old oil with it, and it dripped on the manifold. That smelled exactly like burning rubber when i started the truck for the first time. Scared the living daylights out of me - I though I messed something up big time. Anyway, OP mentioned that the CV boots broke not long ago and "grease were flying everywhere". Maybe some of that ended up on the manifold, or close to it where it now dripped onto the manifold and caused the smell.
