Strange sound, especially when cold
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dr Acula, Nov 29, 2012.
  1. Nov 29, 2012 at 6:53 AM
    Dr Acula
    Dr Acula [OP] New Member
    North Carolina
    '03 PreRunner
    Hate to jump in with a whole new thread, but I didn't find anything while perusing the site.
    I have a bone stock '03 2WD PreRunner w/ 121k miles on it. I've owned it since '05. Love it, and have never had a single problem.
    However, last few months it's making a strange and very annnoying sound, especially when cold. The sound seems to go almost, or completely away, by the time I get to work (25 miles / 35 minutes commute)
    Hard to describe, almost sounds like a medium to high pitched whining sound. The intensity, or speed of the sound, increases when I press the accelerator.
    I had the timing belt repalced about 20k miles ago. Could it be worn belts? Any other suggestions? Thanks for any insight. Wish I knew this site existed all these years. :eek:
  2. Nov 29, 2012 at 6:59 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Is the sound coming from under the hood or in the cab?
  3. Nov 29, 2012 at 7:01 AM
    Dr Acula
    North Carolina
    '03 PreRunner
    Definitely not the cab. Under the hood, front end of the truck.
  4. Nov 29, 2012 at 12:14 PM
    BamaToy1997
    Bill
    Navarre, FL
    A VERY common failure that creates the sound you are talking about is a failed AC idler pulley bearing. Just something to look at.
  5. Nov 29, 2012 at 12:19 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    A/C idler pulley bearing like someone mentioned would be my first guess. Loosen the belts enough so you can spin the pulley or shoot some kind of oil into it to see if the sound goes away. Lowest pulley right behind the radiator.
  6. Nov 29, 2012 at 12:25 PM
    Dr Acula
    North Carolina
    '03 PreRunner
    Nice, thanks for the advice.
    BTW, BamaToy, I'm glued to your signature video. OMG
  7. Nov 29, 2012 at 12:59 PM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    I would check the ac idler like stated above. If that doesn't fix it I would check to make sure all your belts are tight if no luck check your alternator, power steering, etc anything that spins. And also check your power steering fluid level. On my old Toyota when the power steering fluid would get low it would whine really bad.
    Good luck
  8. Nov 29, 2012 at 1:03 PM
    rysully
    rysully Active Member
    Gainesville
    04 SR5 4WD
    my truck does it in the ac bearing but its not hurting anything right now so i just turn the radio up.
  9. Dec 3, 2012 at 9:16 AM
    BamaToy1997
    Bill
    Navarre, FL
    My truck does it in the mud.....but that is another story.....
  10. Dec 13, 2013 at 4:00 PM
    billb1126
    billb1126 New Member
    Bill
    Delaware
    07 toyota Tacoma
    if you use Mobile one or HK oil filter, change and see if problem goes away.
  11. Dec 13, 2013 at 4:40 PM
    043RZ
    043RZ Well-Known Member
    Spring Grove, PA
    2004 Tacoma SR5
    6" Fabtech Lift, OME Dakar leaf springs, BudBuilt Traction Bar, 15" American Racing Wheels, 5.29 Nitro Gears, 35" BFGs AT, Pioneer 200 Watt Stereo, 6x8 Pioneer speakers, Raised Front and Rear Diff Breathers, Deck Plate Mod, Red Interior Underglow, Red Exterior Underglow, Cool White LED Rock Lights,
    Dammit if this doesn't sound familiar... Yea check all belt tension and especially check that A/C pulley
  12. Dec 14, 2013 at 3:54 PM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    It doesn't look like it's been mentioned... You should also listen to your power steering pump. If it's going out it will make that noise. An easy way to check is turn your wheels at idle when it's noisy. If they noise changes, you've found your problem.
