Strange sound from front wheels
Discussion in '1st Gen. Tacomas (1995-2004)' started by iDrew, Feb 17, 2012.
  1. Feb 17, 2012 at 10:02 AM
    iDrew
    iDrew [OP] I spend too much on vehicles...
    Andrew
    Edmond, OK
    '16 TRD Off-Road DCSB
    STOCK AF
    Title says it all.
    I have this strange chirping, squeaking, screeching, sound coming from my both of my front wheels. I have a 2002 Prerunner, Non -TRD.
    I jacked it up the other day, and yesterday, to see if I could figure out what the problem was and I found a couple of things:
    1) BOTH of the front wheels are rather hard to turn when off of the ground, moreso the passenger side than the driver side. After spraying some WD-40 on the rotors it made it a little easier to spin.
    2) I found it rather easy to move the wheel side to side, but here's the kicker, when I would move it, it would move the other wheel also and it would lock the steering wheel in place, but when I tried to move it again, it would move much less but it also would move the steering wheel ever so slightly. So I can't fully rule out a bad ball joint but it doesn't seem to be the problem.
    3) When I'm driving, there is a faint squeak of the wheels, and when I gently, and I mean GENTLY apply the brakes, it squeaks much louder. When I apply the brakes harder, the sound stops and returns when at the end of a completed stop. Obviously it goes away when I stop.
    5) I found that when I took my Driver-Side front wheel off the bolts that fix the wheel into place were rather easy to move, left and right that is. Not quite sure if they moved in and out though..
    6) I found that the McGard locking lug nut keys are very shady and they tend to break... So I can't really do anything to get the locks off now, and I also have to register the locking lug nuts with McGard and spend $15 on a new key. Needless to say, I'm rather UNimpressed with their OVERLY PRICED products.
    Those are the things that I found. Now my question is, what do you think it could be? Keep in mind that I did replace the front brakes less than 5k miles ago. Yes, I did do the job myself and I felt everything went rather well, and my stepfather would likely agree.
    As for the locking lug nuts, anyone know a cheap way to get them off?
    I do still have the factory set that came with the truck, but there's only 3 of them since Hibdon Tire lost 1. They did however buy me a new set free of charge.
    Anyways, any help would be greatly appreciated.
    Thanks, Drew.
  2. Feb 17, 2012 at 10:06 AM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    Sounds like your wheel bearings are going bad. Mine make the same noise. Ill tell you what happens when I put them in next weekend.
  3. Feb 17, 2012 at 10:06 AM
    87xjmike
    87xjmike Well-Known Member
    Folsom
    98 5lug 2rz
    downey mid travel 2wd set up
    i have no experience with locking lug nuts so i can't comment to them but is your truck aligned properly? The screaching could be from heal/toe thats way off. I had a screach, thought it was wheel bearings but it didn't go away after i replaced them, got it aligned and it went away.
  4. Feb 17, 2012 at 10:09 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    You sprayed WD40 on the rotors?
  5. Feb 17, 2012 at 10:09 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Can't really address the other issues but I'd make sure I used some brake cleaner on your rotors & clean that WD40 shit off....
  6. Feb 17, 2012 at 10:10 AM
    JDMcQ
    And hope that the pads didn't soak it up.
  7. Feb 17, 2012 at 10:11 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    x10
  8. Feb 17, 2012 at 10:12 AM
    98tacoma27
    Ben
    Not Beech Creek
    ^^ has my vote^^
  9. Feb 17, 2012 at 10:13 AM
    JDMcQ
    I would have to guess, and it is just that, a guess, that your brakes are hanging up. How do the pads look? Remove the calipers and spin the rotor. Does is spin freely without the pad rubbing on it.
    Then, no matter what you do, clean the WD40 off the rotors and install new pads.
  10. Feb 17, 2012 at 10:18 AM
    iDrew
    Andrew
    Edmond, OK
    STOCK AF
    I just drove it and braked really hard to get it off. It seemed to have temporarily fixed it but it comes and goes. It's rather, inconsistent.
    And, again, I can't get the wheels off anymore. Thanks to those POS McGard keys...
    How much are new wheel bearings? And what's the likelihood of BOTH front wheel bearings going out at the same time?
    I feel like the brakes are semi-engaged... And, this may be irrelevant but, when I let off the gas, the truck seems to not like coasting while in drive. Yet when I slide it into neutral, it seems happy again.
    Thanks for the quick replies!
  11. Feb 17, 2012 at 10:21 AM
    JDMcQ
    Find a good mechanic.
  12. Feb 21, 2012 at 11:01 AM
    iDrew
    Andrew
    Edmond, OK
    STOCK AF
    Any word on how it went?
  13. Feb 21, 2012 at 12:46 PM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    Have you checked your brake pads? Totally possible they are rubbing the wear indicators, or worse down to the metal backing plates which will screw up your rotors.
    Could be wheel bearings but I'm putting money on brake pads.
  14. Feb 21, 2012 at 6:11 PM
    JSFoster75
    JSFoster75 Well-Known Member
    Scott
    Bluff City, TN
    2018 Wrangler JLU Sahara
    Too many to list.
    To remove locking lug nuts: Buy a cheap, and I do mean cheap, socket that is 1 size to small to fit over the round locking lug nut... Then hammer it on and remove it... You'll need 1 per locking lug nut, and one that will form to the lug nut when you hammer it on, hence the need for a cheap socket made from cruddy metal... A socket with the variable position teeth works better than a hexagonal socket...
  15. Feb 22, 2012 at 8:42 PM
    iDrew
    Andrew
    Edmond, OK
    STOCK AF
    OOH! Gracias! That's what I heard but I'd need 4 new lugs.
  16. Feb 22, 2012 at 8:45 PM
    JSFoster75
    Scott
    Bluff City, TN
    Too many to list.
    Yeah, but you can buy some new lugs fairly reasonably... I think they sell them in packs of 5 or 6 at the dealership...
  17. Feb 23, 2012 at 11:03 AM
    iDrew
    Andrew
    Edmond, OK
    STOCK AF
    Reasonable as in less than $20?
  18. Feb 23, 2012 at 11:08 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    go to napa or advance auto
  19. Mar 7, 2012 at 11:21 AM
    iDrew
    Andrew
    Edmond, OK
    STOCK AF
    So yesterday I got the new lugnut key in the mail and jacked the car up and proceeded to take off the rotor and caliper. Old pads are out and they are worm down to nothing. What's strange is that my stepfather and I put new pads on about 5 months ago. Honestly I'm not 100% sure how long ago but they definitely shouldn't have worn out by now. So I get the new rotors on and put the caliper back on and it turns out that Autozone gave me the brake pads for a 2002, now keep in mind that mine is a 2002, abut they didnt have the holes in them for the pins that hold the caliper in. So I drove up to Autozone in my Ford Focus which only has 2 gears mind you, and had the look up the actual pads. What's weird is that the pads for the 2001 had the pin holes. So that either means that mine has had the previous years brakes put on the front or Toyota changed something up with the 2002. I don't know what the deal was but I got everything put on, and the annoying chirping, squeaking, screeching sound went away.
  20. Sep 29, 2017 at 6:56 PM
    iDrew
    Andrew
    Edmond, OK
    STOCK AF
    God damn, I was a dumb child...
