Strange sound from headers under load but not a leak....
Discussion in '1st Gen. Tacomas (1995-2004)' started by Honey badger, Mar 6, 2011.
  1. Mar 6, 2011 at 9:41 AM
    Honey badger
    Honey badger [OP] Honey badger hits whatever tree he wants to hit!!
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    So I just instaled some Doug Thorley headers on my 2002 3.4L and now I am hearing a funny sound from it. I had a Toyota tech do the instale for me and we both checked for any leaks and tightened all bolts and nuts properly. At first I was thinking it was a leak but after doing some reaserch on hear I am thinking it may be air just moving around in the larger headers since the V6 is not pushing enough air to fill them. What do you guys think? Has anyome had any experience with after market headers and this? Thanks for any info and sorry for the newb question I am just concerned about this sound and do not want it to be a leak that will cause damage to the motor.
    Also this sound only comes when I am on the gas and RPM's are around 2000 and 3500prms you can't really hear any signs of a leak under idel. The reason I think and hope it is just the air passing through is because you can hear it really good in the cab and the pipe crosses right over the transmision and the sound comes from right by the dash.
  2. Mar 6, 2011 at 12:59 PM
    Honey badger
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
  3. Mar 6, 2011 at 2:40 PM
    ilove_taco_ma
    ilove_taco_ma Well-Known Member
    fresno, california
    95 tacoma 4wd LX
    nothing, all stock expect got a OE replacement air filter K&N.
    do you have any aftermarket intake installed also? air filter? sounds like with the new aftermarket headers, you're just hearing more torques.
  4. Mar 6, 2011 at 3:19 PM
    Honey badger
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    I have the stock intake with a K&N drop in filter that is all. I guess with the lighter material that the headers are made of that that is what I am hearing. With my head as close as I can get you can hear a noise at idle that almost sounds like a leak but like I said we both checked it many of times. Maybe I am just over analyzing it and being to worried I will sea foam it and that will tell me all.
  5. Mar 9, 2011 at 10:25 AM
    Honey badger
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
  6. Mar 9, 2011 at 7:46 PM
    beatle
    beatle Well-Known Member
    Springfield, VA
    98 3.4l SR5 TRD
    I also hear a noise from behind the driver's side dash that sounds almost like an exhaust leak, and only under load. The truck is still stock (as far as I know) so I'm not sure if this is a normal sound or not.
  7. Mar 9, 2011 at 8:01 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    Think you have a minor crack and when you get that certain pressure on it it makes the noise?
  8. Mar 10, 2011 at 6:29 AM
    Honey badger
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    Dang that is not what I wanted to hear :( So do you think it would be a crack on the header or on the block?
  9. Mar 10, 2011 at 6:48 AM
    tacomakid96
    Phil
    Out n' about
    I'm not saying it is or isn't, I'm just trying to think why the sound would go away when its under less load. Odds are its probably something minor, I wouldn't stress to much about it.
  10. Mar 10, 2011 at 7:58 AM
    Honey badger
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    At idle when you put your head under the fender and listen you can hear a faint sound. Not a leak I know what a leak sounds like I had one on my mustang but its almost like the exhaust is just bouncing around in the header before exiting is the best way I can explain it. I hope it is not a major or minor problem and its just with bigger headers the air moves around more as I am about to SC the truck.
  11. Mar 10, 2011 at 8:05 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    hmm.... bump good luck keep us updated
  12. Mar 10, 2011 at 8:24 AM
    Honey badger
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    Yea I hope it is nothing serious. I will seafoam in the next few weeks and that will let me know a lot about what is going on. I will keep updates.
  13. Mar 10, 2011 at 9:05 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    Just wanted to give some input as this is a pretty common nuance when switching to aftermarket headers. The sound you are hearing is the sound of two things combined. 1.) More exhaust gases exiting 2.) Thinner lightweight aluminum compared to the stock headers.
    Most cases the sound almost sounds like a whirling, leaking, tinny sound if that could describe it. What I would do is just double check the header bolts after a few hundred of running it and call it a day. Seafoam has absolutely nothing to do with what you are hearing, nor is it a remedy.
  14. Mar 10, 2011 at 9:08 AM
    Honey badger
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    See others have also said the same as you and on my mustang I had it was a very familiar sound. I do need to re-check the bolts as I have put several hundred miles since the instal. The only reason I was gonna seafoam was since it smokes see if any smoke was coming out of the leaks if there are any.
  15. Mar 10, 2011 at 9:43 AM
    Yamaha Dave
    ^ Gotcha. Well Seafoam is good stuff for your fuel system so I'd recommend you do it anyways. :D
  16. Mar 10, 2011 at 10:58 PM
    138taco
    138taco Active Member
    Andrew
    socal
    03 prerunner
    black billet grill, icon suspension, total chaos UCAs, solo motorsport 3inch spindles, deaver springs, BAMF brake relocation bracket, doug thorely headers, deck plate mod, afe drop in filter, tinted windows, PIAA bulbs, dynomax superturbo, blue LED conversion, spidertrax wheels spacers
    ^what he said. i have thorleys and thought the same thing when i first installed them. so when i went back for a check up, the guy said the same thing. no worries bro you should be fine:thumbsup:
  17. Mar 14, 2011 at 6:21 PM
    Honey badger
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    Well that is great news. So yours made a funny sound too? I still want to seafoam just have not had time to do it yet.
