Strange sound started a week ago...Help?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BigHeadTaco, May 3, 2013.
  1. May 3, 2013 at 7:59 AM
    BigHeadTaco
    BigHeadTaco [OP] GFY
    Big Head
    Full OME lift 885's with Dakar leaf springs. LR UCA's. ImMrYo relocation bracket.
    So the best way to describe this sound is a "whomp, whomp, whomp" that starts slow at about 40 MPH, then gets fast and silences around 50-55 MPH. Then it comes back at 70 MPH. When I let off the gas the sound seems to go away. Drive shaft?? It is not the loudest noise, but on smooth roads you can really hear it. I have taken it to the dealer, they inspected the diffs, drive shaft, greased u-joints and told me all was fine. Tires have been balanced twice (Nitto Terra Grappler 285/65/18). No steering wheel vibrations, and the truck drives straight. More info, I am lifted full OME 885s, dakar springs on the rear, LR UCAs
    This has really frustrated me, any input is appreciated.
  2. May 3, 2013 at 8:44 AM
    BigHeadTaco
    Big Head
  3. May 3, 2013 at 8:48 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Do you feel it? Where does the sound seem to be coming from?
  4. May 3, 2013 at 9:06 AM
    BigHeadTaco
    Big Head
    Sounds like the front end, no real feeling just the sound. I think I am going to rotate the tires to see if that helps
  5. May 3, 2013 at 9:10 AM
    Aw9d
    Aw9d That one guy
    Check tire balance first. Typically that's the root to any of those issues like that. If that doesn't fix it, alignment would be the next step.
  6. May 3, 2013 at 9:11 AM
    aaronbuell
    aaronbuell Well-Known Member
    aaron
    windsor NY
    09 TRD/OR Access Cab V6 debadged
    Fog-light anytime mod, ,black grill,URD short throw,TRD decals removed ,debadged,black rear bumper, homemade tire carrier,TreadWright tires,Evo mod,removed rear headrests and seats,ABS kill switch mod,black center caps,Clarion CX501 head unit,Relentless hood brackets with floodlights.
    Wheel bearing maybe?
  7. May 3, 2013 at 9:17 AM
    BigHeadTaco
    Big Head
    Getting the alignment checked today hopefully, truck drives straight and tires have been balanced
  8. May 3, 2013 at 9:17 AM
    BigHeadTaco
    Big Head
    Can a wheel bearing go bad at 9k miles?
  9. May 3, 2013 at 9:35 AM
    Skeeter Skeetin
    Skeeter Skeetin Well-Known Member
    Greg
    Daphne, AL
    MGM 4x4 V6 6 speed
    5100's all around w/ 1.75" front. 1.5" Toytec AAL ARE shell with roof rack. Weathertech vent-visors and floormats 20% tint on front. Black and charcol wet okole's VLED V3 Triton DTRL's/turn signals. ECGS bushing
    Kick on your 4x4 and see if that makes it go away. Drivers side needle bearing. I know thats my problem after i leveled my '12. Except i have vibes in my pedals, so that may not be your problem.
  10. May 3, 2013 at 9:36 AM
    Aw9d
    Aw9d That one guy
    It's not normal but anything can happen. I had an alternator die within 200 miles before. It's worth adding to your list of things to check just to be on the safe side.
  11. May 3, 2013 at 11:13 AM
    BigHeadTaco
    Big Head
    Wheel bearings checked, they are fine.
  12. May 3, 2013 at 11:15 AM
    BigHeadTaco
    Big Head
    Alignment is spot on:
    Toe = Right-0 / Left-0
    Camber = Right-0 / Left-0
    Caster = Right-2.8 / Left-2.6
    Good news is that the LR UCAs are holding the alignment perfect.
  13. May 3, 2013 at 11:37 AM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    Did you rotate your tires yet? Do your front tires look like the are cupping? If they are starting to cup, when your tire moves from short lugs to the taller lugs it will make noise.
  14. May 3, 2013 at 11:45 AM
    BigHeadTaco
    Big Head
    I did rotate the tires about two weeks ago and this was the first time the tires have been rotated. I mentioned this to the tech he did say that it could take a few thousand miles for the tires that have been on the rear their whole life to quiet down/smooth out. Does this sound accurate?
  15. May 3, 2013 at 11:55 AM
    P9HST2
    P9HST2 Well-Known Member
    Iowa
    2012 MGM AC TRD OR
    WeatherTech floor liners, tailgate hoseclamp, Famous Fab sliders, Brute Force Fab rear bumper, Icon "3T" suspension.
    No, sounds like an excuse to get you to accept noisy tires.
    I once had new tires that were fine until the first rotation, then the car constantly pulled to the right. One of the tires would make the car pull if it was put on the front. The tire dealer said it would get better as the tire wears in. Huh? Tires wear out, they don't wear in...
  16. May 3, 2013 at 12:00 PM
    skidooman
    TJ
    Northern Nevada
    19 Taco
    I was thinking the opposite. If you have had them on the front for a while they might begin to wear funny and get noisy. Once you put them to the rear it will take some time for them to smooth out. About the time they regain their roundness, the tires that are now on the front will begin to get funny wear patterns. They usually get wear patterns for a reason though, eg: ball joints, alignment out of spec, tens of thousands of miles with no rotate.
    It could be an out of round tire though. I had a bfg km2 that was out of round from the get go. On the rear I never noticed it, on the front it seemed like it would never balance and was noisy. The only reason I found it was after a few trips to the tire shop they suspected something else. The only way to see that it was out of round was to put it on the balance machine, spin it and watch the tire from inline with it, if that makes sense. When it is spinning you will see the out of round section jump a little bit.
    Hope you find it.
  17. May 3, 2013 at 12:06 PM
    BigHeadTaco
    Big Head
    Well, I will give them a few thousand miles and see if it changes. The tires only have around 7k miles on them, and this noise has been the only issue. No steering wheel shake or other issues.
  18. May 3, 2013 at 12:07 PM
    skidooman
    TJ
    Northern Nevada
    19 Taco
    I get so frustrated by crap like this. Hope you get it figured out. I would at least put your tires back to where they were before the noise, so you could rule them out.
    Good luck!
  19. May 3, 2013 at 12:08 PM
    BigHeadTaco
    Big Head
    Yeah, it does get frustrating. Thanks for the suggestions.
  20. May 6, 2013 at 6:53 AM
    BigHeadTaco
    Big Head
    Rotated the tires, still no change. Hoping a few thousand miles will change things..??
