Strange sound when in neutral
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LarrysWorld, Apr 23, 2014.
  1. Apr 23, 2014 at 6:19 PM
    LarrysWorld
    LarrysWorld [OP] 05 Taquito
    Larry
    Rialto, CA
    05 Tacoma Reg Cab
    2in front lift HIDs 15" Steelies
    So I just bought my 05 Single Cab Tacoma 2.4L, now when my truck is in neutral (manual transmission), it makes a noise. The noise sounds like something is lose or some type of metal is hitting. Now when I put the clutch in, the noise goes away. Can you guys maybe help figure out what that noise can be? :help:
  2. Apr 23, 2014 at 6:20 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Throwout bearing
  3. Apr 23, 2014 at 6:22 PM
    taco1989
    taco1989 New Member
    heat shield over the cat
  4. Apr 23, 2014 at 6:24 PM
    LarrysWorld
    Larry
    Rialto, CA
    05 Tacoma Reg Cab
    How sure are you about it? sounds about right.
  5. Apr 23, 2014 at 6:30 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    It's a fairly common problem.
    There's really only 3 things that can make noise. Clutch (normally squeaks REALLY loud), throwout bearing, and pilot bearing. Very rarely is it the pilot bearing that makes a noise loud enough to be audible.
    If you can deal with the sound, just run it. Otherwise it's drop the transmission and replace.
  6. Apr 23, 2014 at 6:33 PM
    LarrysWorld
    Larry
    Rialto, CA
    05 Tacoma Reg Cab
    I need to get rid of the noise so ill check that
  7. Apr 23, 2014 at 6:34 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    If you do drop the transmission to replace it, you may as well replace the pilot bearing as well. It's cheap. Of course inspect the clutch and flywheel as well. It's basically an all day event for such a little part.
  8. Apr 23, 2014 at 6:56 PM
    LarrysWorld
    Larry
    Rialto, CA
    05 Tacoma Reg Cab
    For sure man, I appreciate it! I'll start looking for the Throw out bearing and Pilot bearings.
  9. Apr 23, 2014 at 7:00 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Just a suggestion, but PM Jorge at Camelback Toyota. He's a vendor on here and can get you factory Toyota parts for a hell of a lot less than local dealers, sometimes even less than aftermarket Chinese crap parts from parts houses.
    http://www.tacomaworld.com/forum/camelback-toyota-parts/
  10. Apr 23, 2014 at 7:01 PM
    LarrysWorld
    Larry
    Rialto, CA
    05 Tacoma Reg Cab
    Thanks for the link brotha!!
  11. Apr 23, 2014 at 7:17 PM
    Taco'09
    Taco'09 Well-Known Member
    Uh, Jorge at Camelback is gone.
    Op, there is a clutch TSB for racket in neutral. It is T-SB-0103-11 issued August 19, 2011, and covers all 5 speeds from 2005-2011. Apparently the buffering springs in the clutch disk get loose. The procedure involves replacing the clutch disk and also inspecting the pressure plate and replacing it too if it is not stamped "Aisin" on the outer edge.
  12. Apr 23, 2014 at 7:20 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    :facepalm: I forgot about that, thanks.
    Still get great prices if you want to hunt for the part here:
    http://parts.camelbacktoyota.com/parts/
    Otherwise call Gary. 602-264-2841
  13. Oct 9, 2014 at 11:09 AM
    hotrodrob
    hotrodrob Member
    09 TRD 4x4 Tacoma
    leveling kit, after market wheels, camper shell
    09 Tacoma 6 speed was making a chirping or squeaking noise at idle which stopped after depressing the clutch pedal. It was diagnosed as the throw out bearing. Ilet the dealership know that I'd researched the issue online and that it seemedto be a chronic problem with these vehicles. Without mentioning this, I'm notconvinced the dealership would have looked into any further. Before the dealerresearched the TSB, they said the warranty department would not cover the throwout bearing because it's looked at as wear and tear after about 10k (plus orminus) miles. After finding the TSB, the warranty department covered it. I wasglad to hear that the $1300 estimate (entire clutch kit replacement includingclutch plate resurface) got reduced to a $50 deductible!! A member reported onanother thread that his warranty was up, but the dealership cut the labor inhalf since there was a TSB out for the issue. They replaced the slave cylinderwith one that is sized differently than the original part, the throw outbearing, and maybe one or two other items.
    Here's a thread to read concerning manual transmissions that also covers the throw out bearing issue:
    http://www.tacomaworld.com/forum/tec...-write-up.html
