Strange sound
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jdgshred, Nov 2, 2020.
  1. Nov 2, 2020 at 2:41 PM
    Jdgshred
    Jdgshred [OP] Member
  2. Nov 2, 2020 at 7:36 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Access Denied for the video. Cant see it.
    My bearings had no play in any direction when they were bad.
    Replacing them did fix the problem.
    I’m not stating it’s the bearings. Just stating my experience on my truck.
    My bearing didn’t “clink”, they “roared” and change in sound when going around curves and turn.
    1owner05, tcjacado and Jimmyh like this.
  3. Nov 2, 2020 at 8:04 PM
    gearcruncher
    Canadain bumper technician
    If you had the truck off the ground , you removed the weight of the truck from the bearing load . Its going to be very hard to hear those bearings if the truck has no load .
    Drive in a straight line up to the speed where you hear the noise . Once you are at the speed where you hear the noise , move the steering wheel from right to left while listening for a change in the pitch of the sound .
    If the sound changes as you make quick steering adjustments , chances are , you need front wheel bearings
    Too Stroked, dk_crew, SR-71A and 2 others like this.
  4. Nov 2, 2020 at 8:09 PM
    Jdgshred
  5. Nov 2, 2020 at 8:21 PM
    gearcruncher
    All I heard was wind noise
    Not easy diagnosing noises over a keyboard
    Did you try bringing the truck to speed and then manipluating the steering wheel from right to left .
    Did your noise change in pitch as you loaded each side of the truck ?
    BassAckwards and TnShooter like this.
  6. Nov 2, 2020 at 8:55 PM
    Jdgshred
    I did try that. But no the pitch stayed the exact same right to left and left to ride. Sound starts to appear at 25 MPH
  7. Nov 3, 2020 at 2:09 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    I also only heard wind noise. How many wiles on the 2009? Any past records of major items replaced?
    Stock tires and wheels or oversized? More details are needed as many possible areas to look at.
  8. Nov 3, 2020 at 12:00 PM
    Jdgshred
    145,000 miles. I do not have past records regarding anything major being replaced.
  9. Nov 3, 2020 at 12:11 PM
    gearcruncher
    Are you interested to find out whats been done to your truck while it was on warranty or another owner ?
    Type in your VIN # and see what,s been done to your truck at the dealership
    http://www.toyota.com/owners/web/pages/home
  10. Nov 4, 2020 at 12:58 AM
    muddog321
    FL
    If its the wheel bearing they will get louder so then you will know.
    Not sure of the real sound so look at due to mileage:
    Idler and tensioner pulleys (pull belt off and spin) and Alternator too
    Drive shafts and carrier bearing (grab and shake if lots of play a problem)
    Rear wheel bearings and differential (again will get louder as gets worse)
    Gear oil in the front and rear diff and xfer case good/full and no water in them
    Heat shields above exhaust and drivers side cat shield under drivers seat area
    Front disc shield behind the rotor check to see if bent in and rubbing
    Calipers sticking or rotors out of round
    Rear drums dragging
    Others will have things also but without being there really hard to help with noise cause.
    But if it drives and steers OK then the good news is it will get louder and then you will find it.
  11. Nov 4, 2020 at 9:00 AM
    Jdgshred
    Update, steering has become looser and will not return to straight position.
