Strange Sounds when driving
Discussion in '1st Gen. Tacomas (1995-2004)' started by 03redtaco, May 10, 2010.
  1. May 10, 2010 at 6:29 PM
    03redtaco
    03redtaco [OP] Well-Known Member
    Richard
    Myrtle Beach SC/ Starke FL
    03 Tacoma Prerunner SR5 DC 3.4L
    Hey everyone. I need a little help. I have an 03 Taco, 4dr,3.4l, automatic. I have been noticing a metal tapping sound when driving. I comes and goes. It sounds like an exhaust heat sheild hitting the pipe. But i checked all of that and nothing. Does anyone have any ideas what it could be????? Please help
  2. May 10, 2010 at 6:30 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Cat is probably going bad. Any check engine light?
  3. May 10, 2010 at 6:50 PM
    03redtaco
    Richard
    Yeah but it is for the o2 before the cat. But that does make sense. I would hate to replace it.
  4. May 10, 2010 at 6:56 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Yeah, the OEM ones are crazy expensive. Just get a high flow if that ends up being the problem.
  5. May 10, 2010 at 7:01 PM
    rmarqu2
    rmarqu2 YES... i am a murse....
    Roger
    Baton Rouge
    09 Black 4x4
    FOX 2.5 coilovers, FOX 14" rears, AP expos, AP front plate bumper and skid, lightforce 240 blitz, warn m8000, 3/8 amsteel, BAMF sliders, cheap Chinese rock lights, ARB lockers all around
    I had a bent dust shield in my front right wheel after some intense offroading. It basically sounded like it was coming from the wheel well and it had a "thin-metal-like" grinding/clicking/knocking/screeching sound. I don't know if that helps but i know how frustrating it can be not knowing what's wrong when you hear an odd noise. Hope you figure it out and it's a cheap repair!!!!
  6. May 10, 2010 at 7:05 PM
    03redtaco
    Richard
    Thanks. I will have to check that also. I am not sure if it would be the dust cover or not. I was on a trip to Florida and on the way back on the interstate it started. Like i said it just comes and goes. A guy i work with said that the was hearing the same noise and he changed his o2 and it stopped. Think it could be the o2? Just dont seem right.
  7. May 10, 2010 at 8:01 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Not sure. I wouldnt think a bad o2 would make noise, but I would for sure change both sensor's. You dont want to just change one. bc they work together to keep you trucks A/F ratios right.
  8. Jun 4, 2010 at 9:35 PM
    03redtaco
    Richard
    Well it took some time but I think I finally figured out what the noise was. I think that its a universal joint. We put the truck up on jack stands and held the breaks and pressed the gas at the same time to put some strain on the drivetrain. It would not do it if i just pressed the gas. I sure hope that this is the problem. The other u joints have been replaced. Not sure if the on going bad is orig to the truck or not. There are no grease fitting on it or rings. Will pick one up tomorrow from the local parts store and see if that solves the problem.
  9. Jun 4, 2010 at 9:53 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    I'm chiming in here a little late but does the sound you describe maybe sound like a piece of wire wrapped around the drive shaft when you take off from a stop ? If so, smart money says its a U joint...Good luck ...:cool:
  10. Jun 5, 2010 at 8:29 PM
    03redtaco
    Richard
    Well it diddnt do it but at certian speeds, but it did sound like a wire. I pulled th old u-joint apart and the needle bearings on one side were all medded up. I was going to put it back togeather to night but the guy at advanced gave me the wrong u-joint. didnt start working on it till about 930 this evening.
  11. Jul 20, 2013 at 7:09 PM
    mrbeggins
    mrbeggins LOW.LIGHT.WIDE
    Tanner
    Airdrie Alberta
    04 Tacoma
    Im going to dig this thread out of the graves and ask...did you ever find out what that faint noise was? It sounds like I am having the same issues. The noise goes away when brakes are applied, which means load in the drive train. Did you ever replace the carrier bearing as well?
    Thanks
