strange thing happend
Discussion in 'Technical Chat' started by azzurri, Mar 17, 2009.
  1. Mar 17, 2009 at 4:04 PM
    azzurri
    azzurri [OP] Well-Known Member
    hi anyone know what's wrong here all of a sudden there is a vibration in my steering wheel it's fine till you reach 40 mph?
    Any thoughts
  2. Mar 17, 2009 at 4:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    What kid of truck?
  3. Mar 17, 2009 at 4:07 PM
    El Diablo
    El Diablo SMSgt / 2W091
    Beelzebub
    TacomaUnderWorld
    Your Wife
    I believe Toyota knows there is a problem with steering between 40 and 60 miles per hour. There might be a TSB for it but I wouldn't know for sure since I drive a PowerWagon.
  4. Mar 17, 2009 at 4:27 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    I agree that the most likely cause is something amiss with your wheels / tires.
  5. Mar 17, 2009 at 7:57 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The first thing you could do that doesn't cost anything....Is rotate your tires and see if the *feel* of the vibration changes. If the steering wheel doesn't vibrate as much, then chances are....one of your wheels/tires is out of balance.
  6. Mar 17, 2009 at 8:02 PM
    cole47
    cole47 Well-Known Member
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    x2
  7. Mar 18, 2009 at 9:49 AM
    sportee
    sportee Member
    '08 SR5 Double Cab 4x4
    Still planning :)
    ...I got the same thing...
    ...feel a vibration when I hit about 50mph and gets worse up to about 70...
    ...I assume it is a thrown wheel wieght...Ive been planning to rotate tires and see what happens...havent got to it yet. Maybe this weekend :D I have read about a quick cheep mod for the drive train vibration...
    ...but I think im going to do the carrier bearing mod too. This should help with the drivetrain vibration at about 25mph...
  8. Mar 18, 2009 at 4:05 PM
    azzurri
    well i had the small vibration it was the wheel weights but my big problem with the heavy vibration was mudclay and rocks logged in the wheel it self. so after you go mudding spray the wheels good get right in there and power wash the sob outta it
