Strange thing happened this morning..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LEX, Oct 29, 2010.
  1. Oct 29, 2010 at 7:00 AM
    LEX
    LEX [OP] --- --- --- - ----
    Houston, Texas
    100 Series LC
    I started my truck and backed it out of my garage. As I put in park to let it warm up a little, it was ideling rough. Felt like something was kicking my left rear tire then it went away.
    I started my commute to work and it "hiccuped" a couple of times. Kind of felt like a fuel delivery problem then it went away. My truck barely has 845 miles on it and is still bone stock.
    If this continues, I'm definitely taking it to the dealer. I'm just checking to see if anyone else has experienced this before? :confused:
  2. Oct 29, 2010 at 7:02 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    Maybe a bad tank of gas? Never had it happen before.
  3. Oct 29, 2010 at 7:07 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Dude, I woke up to my girlfriend mumbling the Mulan Song "Be a Man" in her sleep at 6:30 am. Thats a weird way to wake up.
  4. Oct 29, 2010 at 7:08 AM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    too much moisture in your gas. Sounds like to me, what are you running
  5. Oct 29, 2010 at 7:09 AM
    virgilus11
    virgilus11 Well-Known Member
    kearny, nj
    09 sr5
    TRD supercharger,EMU 884 springs, 90000 shocks, air bags rear and TSB with EMU shocks, grillcraft mesh, Relentless front bumper,Armology rear bumper, byxenon hid's retro ,undercover lid with bike rack on top, Kenwood dnx9140,TRD cover seats
    Happen to me twice after I installed the supercharger. I never stopped at the Corner Gas Station.
    I decide that I will pay few cents/gal more but I will stick with a (reputable) company.
  6. Oct 29, 2010 at 7:10 AM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    That was my first thought too. What are your overnight temps like?
  7. Oct 29, 2010 at 7:13 AM
    BuckNakedBooda
    BuckNakedBooda There's no place like 127.0.0.1
    Woodbridge, Virginia
    2013 Toyota Tundra Crewmax Limited 4x4
    Did your engine light come on ?
  8. Oct 29, 2010 at 7:15 AM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    I'm always reputable gas, and always 91 octane. Its worth the money. When I was 18 I got gas fouling from a "Fas Gas" station in my old 95 S-10. As I was taking things apart, everything under the truck was so rusted that just taking the bolts off was breaking things left right and center. ended up replacing lines, fuel sending unit, pump, the tank itself. 800$ish dollars later my transmission failed 2 months later..... so pissed.
  9. Oct 29, 2010 at 11:42 AM
    LEX
    Houston, Texas
    100 Series LC
    I keep the truck garaged overnite. The temp dropped, but by only 15 degrees. I recently put in some good gas and my light never came on.
    I noticed that it does it when the engine temp isn't at norm. I went out to lunch and it did it again between 40-50mph then stopped when at normal operating temp.
    I'm at about 1\8 tank and will fill up with 93 oct to see if that helps.
  10. Oct 29, 2010 at 11:59 AM
    jivewalker
    jivewalker Well-Known Member
    Jack MeHoff
    Chucktown
    2012 4RUNNER TE w/KDSS, 2017 LAND CRUISER
    Take it to the dealer you bought it from, tell them it's not running right, you shouldn't have to troubleshoot a new vehicle. Probably something like gas, but get the behavior on record with the dealer.
  11. Oct 29, 2010 at 12:00 PM
    speedfreek
    speedfreek Well-Known Member
    David
    Alafreakingbama
    '12 370Z 6MT
    That sucks. I have less miles and this doesnt sound promising. I hope I dont start to have these issues as well.
  12. Oct 29, 2010 at 12:07 PM
    inouk
    inouk Well-Known Member
    x2, if it would happened to me (and it was), just before filling it up, I would put a gas line antifreeze. It helps to remove moisture.
    However, if you gas already contains ethanol, you won't see a difference since it acts like a gas line antifreeze...
    If it happens again, time to pay a visit to your dealer.
  13. Oct 29, 2010 at 2:53 PM
    LEX
    Houston, Texas
    100 Series LC
    Update. Got off work and started cold. I let it warm up as usual. No issues. Took off the parking lot and nothing. Looks like it stopped doing it. I got a half tank of 93 oct just in case. You're right about it shouldn't be my job to troubleshoot it, but my weekend is pretty busy.
    So far so good. Running great. I'm off Monday and going to have the dealer check it out anyway.
    Thanks very much for all the replies.
    Wish me luck and have a safe Holloween weekend, fellas.
  14. Oct 29, 2010 at 2:59 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Mine also does this if I drive off after I cold start the vehicle. Idling or warming the engine for 2-3 mins and it never happens. I'm guessing something to do with the richness of the mixture on a cold engine, similar to trying to operate or drive something with the choke on with a cold carborated engine.
  15. Oct 29, 2010 at 3:25 PM
    iSTIZO99
    iSTIZO99 Well-Known Member
    Jax, FL
    2010 TRD Sport 4x4 DC/SB
    You're not the only one. Mine was doing this at random times that I couldn't recreate. At first it was mainly after I'd leave for work early in the morning and idle at a stop light. It would sputter for a couple seconds and then stop and it would be fine the rest of the way. Then another time it did while I was traveling around 40 mph. I took in to the dealer and they hooked it up to their diagnostic tool. Everything checked out fine but the tech felt it sputter. Since it was close to the end of the day they didn't have time to take it apart and troubleshoot and that I should bring it back in early on another day.
    He said it could be from bad gas, but I've been filling up at the same busy gas station for the last 5 years. At the time I was running 93, but once that got used up I filled with 87 and ran the shit out the engine to use up what ever of that old gas was left and the sputtering got lighter and lighter. So far I'm halfway down from a fresh new tank of 87 and I am not having that issue anymore. Maybe it was the gas. :notsure: I'm just over 3600 mi on the clock.
  16. Oct 30, 2010 at 5:17 AM
    LEX
    Houston, Texas
    100 Series LC
    Update...
    I hope they find the problem.
    It got worse. Last night, I got in the truck and the traction control light was on and the check engine light was flashing. The idle wad rough and it felt like my tires were out of balance everytime I would excelerate.
    I made time this morning take it to a dealer. I'm actually here now waiting on a shuttle service to take me home.
    This sucks.
  17. Oct 30, 2010 at 6:31 AM
    SilverTacoZack
    SilverTacoZack Well-Known Member
    Zack
    Elgin, SC
    2011 FJ trail teams
    All this with under 1k miles? I hope this isn't heading towards a lemon law situation ...
  18. Oct 30, 2010 at 6:40 AM
    Taco4x4NC
    Taco4x4NC Well-Known Member
    David
    Western North Carolina
    2010 4x4 DC/LB "Pytrite Mica/Katzkin leather
    3m clear bra or Venture, stant locking gas cap, Shield, front windows tinted, weathertechs, ARE "Z" topper. Sockmonkey decal, Billy 5100's x 4 corners, Eibach coils, Toytec 1.5 AAL. Michelin 265/75/16 MS2's, Grillcraft MX series/TOYOTA badging. FJ/SE TRD Anthracite gray wheels. Katzkin leather/heated seats.
    Subscribed~
    Hang in there the techs should be able to figure it out prettty fast. There are a number of things that could cause this problem.
    I hope it all works out for you.
    Keep us posted.
  19. Oct 30, 2010 at 6:49 AM
    DionysiosA76
    DionysiosA76 Captain Analyzer
    Dionysios
    Barrington, IL
    07 Taco Sport DC 6 spd-SOLD FOR CUMMINS
    Totally custom straight pipe exhaust sourced from an 01 Cummins (fabbed up by yours truly), ScanGaugeII, Westin Bull Bars, air horns, Truxedo tunneau, Black decals, Black rotors, black calipers, Secondary Air filter removal, reengineered dirtbike hauler, auxillary back up lights, blacked out tail lights, socked by Sockmonkey, blacked out hi-stop, TRD stickers (+300hp :) Owens Running Boards, Greek flag shifter, Garmin Nuvi 755w GPS, Cobra 25ltd CB with a 4' fiberglass whip... and never paid anyone nuttin to do it.
    Its getting a lot colder now in chicago, and starting last week ive gotten myself in the habit of waking up, going outside half naked to start the truck, then going about my morning activities, 15-20mins later, leaving for school in a preheated truck. I'm going to install a redneck block heater very soon as well.
  20. Oct 30, 2010 at 7:18 AM
    meeestirg
    meeestirg Well-Known Member
    Vance County, NC
    lmfao! gg!
