Strange Thing That Occurred
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kahanabob, Dec 10, 2021.
  1. Dec 10, 2021 at 12:23 PM
    kahanabob
    kahanabob [OP] Well-Known Member
    Maui
    16 TRD 2WD 4DR
    Pulled into a parking space, put it in park and in the same motion pushed the off button. however i had only pushed the gear shifter to the R position so when i pushed the off button it stayed running and having taken my foot off the brake the truck backed up a few feet until i pushed the brake. realizing what i did i put it in D to pull back in and the truck still went backwards! i put it in N then back to D still it's in reverse. finally i put it in N and turned it off, restarted and works fine.
    BTW am aware it is Friday...
  2. Dec 10, 2021 at 12:25 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Another drunk monkey automatic transmission?
  3. Dec 10, 2021 at 12:26 PM
    Tacospike
    Two Trucks
    My brain hurts
    jmneill and Junkhead like this.
  4. Dec 10, 2021 at 12:26 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    The drunk monkey isn't in the transmission.
    lostMarbles, Tacospike and Junkhead like this.
  5. Dec 10, 2021 at 12:27 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    According to some TW members it is.
    lostMarbles and Tacospike like this.
  6. Dec 10, 2021 at 12:30 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
  7. Dec 10, 2021 at 12:40 PM
    lostMarbles
    lostMarbles A Lost Cause
    Micah
    Alaska
    2021 3.5L 6MT, and 1997 2.7L 5MT
    The wingnut behind the wheel
    That is odd. Sounds like the ECU got confused. See if you can make it happen again for poo and giggles.
    HV101 and Junkhead like this.
  8. Dec 10, 2021 at 12:46 PM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar BFG K02 AT’s RCI skid Bilstein 5100's up front, (#2) & 4600 in rear N-2 Designs remote start/keyless entry Anytime 12v outlets... one by shifter & one in bed Daily driver....
    Maybe the ECU is the one that's drunk?
  9. Dec 10, 2021 at 1:02 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    I have to agree with the other comments, sounds like you gave the computer a brain fart!
  10. Dec 10, 2021 at 1:03 PM
    lostMarbles
    Micah
    Alaska
    Could be. It strikes me as odd that one cannot turn the truck off in gear. Kind of like the designers believe automatics are for drunk monkeys. Of course, my truck will not let me shift in or out of 4Lo unless completely stopped, probably because of too many drunk knobs.
    Though, given how easy it would be to push and turn too far, I can see why. But, I do miss the manual transfer case in my 1st gen.
  11. Dec 10, 2021 at 1:59 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    Drunk monkeys??
    Crikey... bettah drink me own piss
    Junkhead likes this.
  12. Dec 10, 2021 at 2:41 PM
    Taco CPO
    Taco CPO Well-Known Member
    Jon
    Lemoore CA
    2021 Army Green TRD Offroad
    Uhhhh hmmm
  13. Dec 10, 2021 at 3:57 PM
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    I can turn mine off in gear; I've done it a few times while still in D. It turns off but gives a constant annoying noise. I'll have to try it in R... by mistake.
  14. Dec 10, 2021 at 4:06 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    booze crusin
    a fun friday
    Montana_Actual likes this.
  15. Dec 10, 2021 at 4:08 PM
    Lphonzy09
    Lphonzy09 Well-Known Member
    Texas
    2022 Midnight Black Metallic SR5
    So, don’t turn off your car prematurely in Reverse. Got it.
    Easy fix is what you did. Leave it in Neutral. Turn it off. Turn it on, switch back to park. Turn off.
  16. Dec 10, 2021 at 4:41 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    ECU programmed by 21 year olds who never ask “what if…”.
    Normal.
    Junkhead and RustyGreen like this.
  17. Dec 10, 2021 at 4:49 PM
    Montana_Actual
    Montana_Actual ;)
    I do this all time...
    In the bar parking lots.
    "Stuped tramsmission.. WORK!"
    Junkhead and brandon78lusch like this.
  18. Dec 10, 2021 at 5:01 PM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    i new we have throttle by wire but never thought shifter by wire. guess in the back of this old farts mind i thought when you move the shifter you are moving linkage to the tranny. been under there enough times i should have thought duh, where is the linkage!
    davidstacoma likes this.
  19. Dec 10, 2021 at 5:03 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I put the handbrake on before l turn the key off.
    brandon78lusch likes this.
