Strange thump
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Owenhall, Nov 17, 2024.
  1. Nov 17, 2024 at 3:35 PM
    Owenhall
    Owenhall [OP] Well-Known Member
    Owen
    2009 Toyota Tacoma 4x4
    Lift 33s
    My Tacoma has started making this odd clunk when stopping and hitting bumps and it sounds like possibly the rear differential It constantly does it when stopping in reverse quickly.
  2. Nov 18, 2024 at 11:55 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    have you checked your bed bolts? what about driveshaft carrier bearing? What about leaf spring bolts or ubolts?
  3. Nov 18, 2024 at 5:43 PM
    Owenhall
    Owen
    Lift 33s
    Driveshaft has new u joints center oem support bearing. And I checked the u bolts I checked the bed bolts when I installed bed stiffeners
  4. Nov 19, 2024 at 2:20 PM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    body mounts/bushings?
  5. Nov 19, 2024 at 2:31 PM
    fatfurious2
    David
    Ashburn, VA
    I just saw a thread about checking the transmission fluid
  6. Nov 19, 2024 at 3:53 PM
    Owenhall
    Owen
    Lift 33s
    Body mounts seem fine changed transmission fluid recently the sound is definitely from rear of truck I heard it from outside the sound has disappeared since then haven’t heard it in a few days
  7. Nov 19, 2024 at 3:54 PM
    Owenhall
    Owen
    Lift 33s
    Hopefully it fixed itself.
  8. Nov 19, 2024 at 4:02 PM
    Owenhall
    Owen
    Lift 33s
    One other weird thing I had was it felt like I had a transmission shudder for a second at 40mph then it went away it has never done that before and hasn’t done it since. What would cause that.
  9. Nov 19, 2024 at 4:28 PM
    Bloodhound
    Bloodhound Banned from the Pics Thread
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    Floor-mats, Running Boards, Shorty Antenna, AFE Pro Dry Air Filter, AVS In-Channel VentVisors, Beer cans in the bed
    Check your steering shaft for looseness. Buddy with a 2009 has one that clunked like crazy and was hard to pin down.
  10. Nov 19, 2024 at 4:40 PM
    Owenhall
    Owen
    Lift 33s
    My steering shaft is newish I replaced it with a doorman one and it is already rattling.
  11. Nov 19, 2024 at 4:41 PM
    Owenhall
    Owen
    Lift 33s
    Not the sorce of the noise
  12. Nov 22, 2024 at 4:01 AM
    ECE208
    ECE208 Active Member
    Evan
    Idaho
    2013 White Access Cab Tacoma SR5
    Had a similar thud when going from forward to reverse and vice versa. Turned out to be the bolts for the lower control arm.
  13. Nov 22, 2024 at 8:04 AM
    Owenhall
    Owen
    Lift 33s
    Yea I had that problem a while back this one is different but it seems to have fixed itself it has Been a few days since it has happened I think maybe a leaf spring guide was rubbing
  14. Nov 22, 2024 at 11:33 AM
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
    post a video of the noise/sound
  15. Nov 22, 2024 at 11:37 AM
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    your bolts were loose or your bushings were worn?
  16. Nov 23, 2024 at 4:04 AM
    Owenhall
    Owen
    Lift 33s
    Loose bolts
  17. Nov 23, 2024 at 4:05 AM
    Owenhall
    Owen
    Lift 33s
    I tried to post a video but the sound is very intermittent.
  18. Nov 23, 2024 at 5:04 AM
    Owenhall
    Owen
    Lift 33s
    I also had what I think was a torque converter shudder the other day it has happened 2 times not shure what to do about that
  19. Nov 23, 2024 at 8:29 AM
    Dustrider
    Dustrider Well-Known Member
    Dave
    Hillsboro Oregon
    98 Tacoma 4x4 2.7
    jack is loose and slamming around in the rear seat tool storage box
  20. Nov 23, 2024 at 8:35 AM
    Dustrider
    Dave
    Hillsboro Oregon
    98 Tacoma 4x4 2.7
    if leaf spring bushings wear out it could cause axle wrap and a shudder like a torque converter shudder
