Strange Tick from front end on launch
Discussion in '1st Gen. Tacomas (1995-2004)' started by crazyasu45, Jun 23, 2010.
  1. Jun 23, 2010 at 5:23 PM
    crazyasu45
    crazyasu45 [OP] Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    I hear a fast tick...tick...tick...sound on hard acceleration from a complete stop...it only last a few seconds then goes away...it's not comming from the engine...it sounds like a suspension problem..any ideas :confused: I also hear a clank sound sometimes on cornering...
  2. Jun 23, 2010 at 7:58 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    Bump!!!
  3. Jun 23, 2010 at 8:04 PM
    df4iguy
    df4iguy Well-Known Member
    Dan
    Chicago
    how loud is it? does it sounds like bb's in a coffee can?
  4. Jun 23, 2010 at 8:09 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    could be the brakes.....
  5. Jun 23, 2010 at 8:59 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    Not too loud of a tick...tick...tick...as I take off the tick matches my speed for a few seconds then it disappears...doesn't really sound like bb's in a coffee can...why were u thinkin my wheel bearings might be shot?
  6. Jun 23, 2010 at 9:02 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    could be...I'll check em out...Thx...
  7. Jun 23, 2010 at 9:16 PM
    df4iguy
    Dan
    Chicago
    no i was thinking detonation under full throttle. I hear it in mine from time to time but its very faint
  8. Jun 23, 2010 at 9:23 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    NO it's not detonation...but thx for scaring the bejesus out of me :eek: lol as I metioned in my first post...it's not an engine related sound :D
  9. Jun 23, 2010 at 10:05 PM
    Siebler
    Siebler Duck Killing Machine
    CJ
    Portland, OR
    99 Long Travel 5 lug, 01 Tundra 4wd
    TC LT Front, F67 on 12" shackle, LCE Underdrive Pulley, Flex-a-lite fan, DT headers, Super 44 muffler, 4:11's and Aussie Locker, 22 Gallon Fuel Cell, Beard seats, sliders, bed cage
    Possibly bad Balljoints. Check them out, they do make noise when they go bad.
  10. Jun 24, 2010 at 7:09 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    interesting. ..i just noticed the same thing this morning in the parking deck.
    i played around a bit and found that the only time it happens is if i use the emergency brake. ...when i don't engage it, i don't hear the ticking when i take off.
    i also have a brake squeeling ..can't tell if it's the drivers front or rear ..i suspect the rear.
  11. Jun 24, 2010 at 2:00 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    Thx I'll check that out too :D
  12. Jun 24, 2010 at 2:08 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    My parking doesn't work because my brake levers are seized but i don't believe this is the cause...but i'll check it out...Thx for the reply...
  13. Jun 24, 2010 at 10:43 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    This is kinda simple but....
    ...are there any rocks stuck in your tires that stick out above the tread?
  14. Jun 25, 2010 at 5:54 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    Nope...but I wish it was that :D I think it's more along the lines of a worn suspension components or something...the ticking speeds up with acceleration...it's not constant though...goes away after a few seconds of driving...also does this on cornering as well..
  15. Jun 25, 2010 at 6:07 PM
    03redtaco
    03redtaco Well-Known Member
    Richard
    Myrtle Beach SC/ Starke FL
    03 Tacoma Prerunner SR5 DC 3.4L
    I had a strange tick tick noise also. Maybe diff. My problem was the U-Joint. I would check to see how much play you have in them.
  16. Jun 26, 2010 at 12:41 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    Checked my U Joints...No play whatsoever...could be a bad CV Joint...but I think that makes more of a clunk sound when it goes bad doesn't it :confused:
    It could also be worn out Ball Joints...or bushings...
  17. Jun 26, 2010 at 12:46 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    belt tensioner?
  18. Jun 26, 2010 at 1:04 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    Maybe...Nice one :D
  19. Jun 26, 2010 at 1:18 PM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    cv joint
  20. Jun 26, 2010 at 1:20 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    read post #16
