Strange Tire Air Loss and Vibration at Highway Speed
Discussion in 'Wheels & Tires' started by Gaunt596, Aug 5, 2013.
  1. Aug 5, 2013 at 2:40 PM
    Gaunt596
    Gaunt596 [OP] Well-Known Member
    Matthew
    Central Maryland
    Okay, so, over the past few days, my Left Front tire has been losing air for no reason. I have removed the wheel from my truck and looked all over the tire, there are no visible punctures or tears anywhere. The same wheel/tire also has a mild vibration at highway speed. I am using the stock wheels and and the same size tires as the factory with no lift , and the truck has 102 k on it.
    If anybody has any idea this would be lovely, as i really dont want to have to replace the tire/rim unless i have to.
  2. Aug 6, 2013 at 10:19 AM
    Gaunt596
    Matthew
    Central Maryland
    Am i really the only one with this problem? i really don't want to spend $$$$ to replace the tires, their practically brand new....
  3. Aug 6, 2013 at 10:43 AM
    WHPLSH3
    WHPLSH3 Fortified with horsepower-adding goodness...
    Vance
    Alberta
    Supercharged Spruce Mica 6spd 4x4
    Build thread coming soon!
    Maybe there's a little something in between the tire and the bead?
    The only way to know for sure is to submerse it in a tank... why not take it back to the tire shop that put the new ones on and have them check both issues?
  4. Aug 6, 2013 at 11:02 AM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    Did you just get new tires recently?
  5. Aug 6, 2013 at 11:05 AM
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    Take the wheel off the truck and don't just visually inspect it, but spray it with soapy water. The leak will show up almost instantly. I usually soap the whole tire then inspect it for the leak. Also soap and inspect the tire sensor and soap the entire wheel. I just replaced a 5 lug steel wheel that had a leak at one of the welds. Wasn't coming out of the tire, but out of the wheel.
  6. Aug 7, 2013 at 2:41 PM
    Gaunt596
    Matthew
    Central Maryland
    Okay, thanks guys. I haven't gotten new tires, im having issues with the ones that were on the truck when i bought it, but they are almost brand new, id say 85% tread left. After further inspection, my dad noticed that the valve stem is steel on the aluminum rim. would this cause any problems? also, im gonna do the soapy water thing tonight, hopefully that will pinpoint the leak.
    Edit: Just noticed the wheel thing too, ill make sure to coat everything liberally, if it turn out to be the rim, SCS might get some business from me soon.
  7. Aug 7, 2013 at 2:52 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    Once you submerge the wheel/tire in some water, the leak will pop up. It could be a bad valve stem, the TPMS might have a worn o-ring, or there could be a pin size hold in the wheel(barrel). Good luck and if we can help you with a set of new wheels just let me know:D.
  8. Aug 7, 2013 at 2:58 PM
    Gaunt596
    Matthew
    Central Maryland
    :D im going to get a set of your wheels eventually, i just might have to shell out that cash sooner than the National bank of dad would like :p
  9. Aug 7, 2013 at 3:00 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Maybe the tire bead is not seated properly. That happened with my car. How I found out and solved it (and it's a bad thing to do, so don't try it) is I drove kind of erratic. But I didn't realize that was the solution until AFTER I drove it that way and the leakage stopped.
  10. Aug 7, 2013 at 3:02 PM
    TailDrag
    TailDrag Well-Known Member
    Oddest fix ever.
  11. Aug 7, 2013 at 3:02 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    tisk tisk:facepalm:....;)
  12. Aug 7, 2013 at 3:17 PM
    babytruck
    NorCal
    I know....:eek:
    I just figured that the tire had a small hole in it. I had to put in air every day and it just got to be a routine thing. The night after I drove it that way the sensor didn't light up. And it hasn't lit up since. *shrugs*
  13. Aug 7, 2013 at 4:31 PM
    Toyota Tech31
    Debary, Florida
    Another word of advice. When you do go to soap the tire, fill it to normal pressure. If the bubbles don't show, drop the pressure by 10-15 psi. I have had tires seal themselves when not on the vehicle and filled to proper or excess pressures. Sometimes when they are off the car they need to lowered a bit to help find the leak.
