Strange vaccuum noise on shutdown.
Discussion in 'Technical Chat' started by Johnmark101, May 3, 2013.
  1. May 3, 2013 at 10:23 AM
    Johnmark101
    Johnmark101 [OP] New Member
    Central Kentucky
    PreRunner SR5 V6
    Just picked up a new Tacoma. Really like the truck so far. However I am hearing a strange noise when shutting off the motor. It sounds like a purge or release of vaccuum pressure.....almost a whistle sound. I really don't like fooling with the local dealer any more than necessary and was wondering if anyone else has noticed this with their truck. Truck seems to perform just fine and there are no lights on to indicate a problem. For what it's worth I have a V6 PreRunner with the towing package.
    Regards......John.
  2. May 3, 2013 at 10:30 AM
    JTaco386
    JTaco386 Well-Known Member
    JT
    Fort Rucker, AL/ Home: Port Orange, FL
    13 DCSB TRD Sport 4x4
    Mine does the same thing...I think it's something to do with new emission standards...
  3. May 3, 2013 at 10:33 AM
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    Smog Pump
  4. May 3, 2013 at 10:33 AM
    Johnmark101
    Central Kentucky
    PreRunner SR5 V6
    Oops.....just found another thread about this very subject. Seems it is normal but it also appears to be annoying to many owners. As long as it is part of the normal functioning of the truck it does not bother me, but I am betting Toyota comes up with some sort of fix if enough people complain.
  5. May 3, 2013 at 11:21 AM
    SpacemanSpiff
    SpacemanSpiff Well-Known Member
    James
    08 TRD Off-road
    Toyota come up with a fix if enough people complain? :rofl:Oh, you are being serious...:D
    I wouldn't even think abou holding my breath on that one - I say this because look at how the driveline issues haven't been properly dealt with...or frame rust...or....
  6. May 3, 2013 at 11:24 AM
    BigHeadTaco
    BigHeadTaco GFY
    Big Head
    Full OME lift 885's with Dakar leaf springs. LR UCA's. ImMrYo relocation bracket.
    It is normal, mine seems to only do it when I do not let the truck warm up or if I drive for a very short distance
  7. May 4, 2013 at 10:15 AM
    Johnmark101
    Central Kentucky
    PreRunner SR5 V6
    Mine seems to do this every time it is shut off.
  8. May 4, 2013 at 1:02 PM
    TRSJimmy
    Jimmy
    Gainesville, GA
  9. May 5, 2013 at 8:58 AM
    Johnmark101
    Central Kentucky
    PreRunner SR5 V6
    So.....is this pump creating pressure at shutdown? Anyone know what the purpose of this is? Does this inject exta air into the intake mainfold at start up?
    I can accept this as normal but am curious as to the design purpose.
  10. May 5, 2013 at 9:03 AM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Exhaust.
    Fresh air to aid the cat in removing any remaining unburned hydrocarbons.
  11. Oct 27, 2013 at 6:26 AM
    trj147
    trj147 New Member
    N. Alabama
    13 tacoma prerunner V6
    annoying is an understatement. it sounds most like a defective bearing. listen closely, the noise is there about 10 - 15 seconds after start up, but is less noticeable because of vehicle sound.. turbo chargers make less noise.
