strange whistling noise in cab
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cobra6, Jun 29, 2010.
  1. Jun 29, 2010 at 10:01 AM
    Cobra6
    Cobra6 [OP] Well-Known Member
    Beri
    Tennessee Valley
    '06 PreRunner SR5 TRD Sport
    I have a strange whistling noise I hear inside the cab.
    I have an '06 D-Cab, Prerunner, SR5, Sport - 50K miles
    After I have been on the road for 1.5 - 2 hours with the AC on, I get a strange whistling, wheezing noise that lasts about 4 - 5 seconds, and it will re-occur every 20 - 30 seconds.
    It almost sounds like the system is having trouble breathing - I just order a cabin air filter replacement - is this the problem?
    I also posted this in the Technical Chat section.
  2. Jun 30, 2010 at 1:16 PM
    Cobra6
    Beri
    Tennessee Valley
    any ideas at all?
    anyone...............anyone???????
    Bueller?
  3. Jun 30, 2010 at 3:32 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    My name's not Bueller, but since you're desperate for a response...and sometimes this gets others going...I'll give you my WAG.
    Could it be the freon (or whatever the technical term for freon's replacement is) cycling through the cab that you're hearing?
    Maybe now you'll hear from Bueller.:D But then again, wasn't Bueller driving a Ferrari?
  4. Jun 30, 2010 at 11:55 PM
    YeahYeah
    YeahYeah Well-Known Member
    Thomas
    (My Home - Murrieta, CA) Now, Alexandria, VA
    07 Tacoma Pre-Runner
    mud flaps gone, second air-filter gone, DTRL, fog light whenever and work with hi-beams, cut exhaust (was wicked flow), flat black stock rims, ABS switch, cup holder led's (with switch), turning signal mod #45, Bilstien 5100's, grill mesh
    mine does this as well. i was just coming back today from Yosemite with my AC on the whole way. Mine does that on when I hit a certain rpm. and no its not the cabin filter bc i washed mine out and it didn't help but it did make the car smell good. anyways, what i think it is is the compressor pushing more when you hit that rpm and youll notice that when you let up or go past that rpm the noise goes away. I have 45k on mine, but im telling you its nothing to worry about. Its a small noise.
  5. Jul 1, 2010 at 5:48 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    R-134a is Suva.
