Strange whistling sound
Discussion in '1st Gen. Tacomas (1995-2004)' started by NC Gazzer, Jan 3, 2023.
  1. Jan 3, 2023 at 6:06 AM
    NC Gazzer
    NC Gazzer [OP] Well-Known Member
    Durham, NC
    1996 Tacoma 4wd 2.7 + 2023 TRD Sport
    For the past few months I've been hearing a strange whistling sound from my '96 Tacoma. It doesn't happen on every drive but when it starts it occurs every few minutes or so. It sounds sort of like someone whistling to call someone - something like a wheee-ooo-wheet. Just one short whistle repeated every few minutes or so without any regularity.
    Attempts to get it to whistle when revving the engine with the hood up have failed. All of the hoses are in good shape and the drivability of the truck is not affected. I did replace the thermostat with a coolant replacement 6 months ago, but don't recall that the noise started soon after that. I did have a Fiat 128 that developed sort of an occasional whine that turned out to be related to the heating control, but messing with that on the Tacoma doesn't seem to effect any change.
    Any ideas? Thanks.
  2. Jan 3, 2023 at 8:30 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Ask your friends where they hid the noise maker? :anonymous:
  3. Jan 3, 2023 at 3:04 PM
    THatt
    THatt Well-Known Member
    Upstate SC
    1996 Tacoma 2.7L MT 4X4
    And check PCV grommet. Mine developed a whistling sound after and only at times while at highway speed under load. Had already replaced vacuum hoses so was sure it wasn't that. After rechecking things several times noticed oil residue around grommet. Replaced and no oil residue or sound afterward. Could also be an idler pulley?
    HondaGM likes this.
  4. Jan 4, 2023 at 3:40 PM
    NC Gazzer
    Durham, NC
    Easy enough. Thanks.
    I'll poke around the PCV valve to see if I can recreate the noise. I am planning a valve cover gasket replacement is on tap for the Spring and I planned to replace the pcv valve as well. I'd expect that an idler pulley would give me a more constant whine, but I reckon it's possible. Thanks.
  5. Jan 4, 2023 at 7:56 PM
    Currygoat
    Currygoat Well-Known Member
    Bay Area, California
    2002 Tacoma 2.4 5 Speed
    Rims, 4600 Bilsteins, K&N filter
  6. Jan 4, 2023 at 8:12 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  7. Jan 4, 2023 at 8:14 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    My Civic has a whistle at highway speeds that I think is coming from my wiper blades. Could be anything that catches air the right way.
    NC Gazzer[OP] likes this.
  8. Jan 5, 2023 at 10:34 AM
    NC Gazzer
    Durham, NC
    Wow, it's a good thing that this fad did not catch on. Pretty obnoxious.
    I don't think my occasional whistle is related to wind. It occurs at any time and at any speed, from 2 mph on up.
    6P4[QUOTED] likes this.
  9. Jan 5, 2023 at 10:55 AM
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    I used to teach High School, ran a computer lab where my students worked on courses online Independently. I have one of those Fart Machines with a remote.
    Used to hide it under one of the desks hidden in all the wiring, I'd set it off occasionally. Funny as hell to watch the kids try and ignore the sound or try to not look around
    for the "source". Hard not to break out laughing. What the hell, the good old days.
  10. Jan 5, 2023 at 11:00 AM
    ScrippsRanch67
    Bob
    Fiberglass shell
    It's probably the electronic tracking device your wife hid in your truck to check up on you.
    NC Gazzer[QUOTED][OP] likes this.
  11. Jan 5, 2023 at 2:54 PM
    Akkording
    Akkording Well-Known Member
    Pete
    Houston
    03 +300k Still Truckin, 2012 4Runner
    Brake booster leak?
