Strapping Coolers on OEM Tonneau?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SnowSpartan, Jul 21, 2020.
  1. Jul 21, 2020 at 9:00 AM
    SnowSpartan
    SnowSpartan [OP] IT, not the clown.
    Boise, Idaho
    2017 Gray DCSB TRD Sport
    It is possible for sure, but do you all think it is a good idea?
    Going camping, need extra space in the bed. I want to strap the hard coolers (35 qt size) on top of the tonneau using ratchet straps.
    GOOD OR BAD IDEA?
  2. Jul 21, 2020 at 9:11 AM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Do you plan to tow or have anything attached to the hitch? If it was me, I would pick up one of those hitch trailers and strap it down that way...it would even allow you some more storage
  3. Jul 21, 2020 at 9:18 AM
    SnowSpartan
    Boise, Idaho
    No towing, just camping gear in the bed and paddleboard on the roof.
    But that hitch trailer is a good idea!
  4. Jul 21, 2020 at 9:19 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    I wouldn't really trust putting any weight on a tonnue, they aren't that strong.
  5. Jul 21, 2020 at 9:27 AM
    TurdTaco64
    TurdTaco64 Well-Known Member
    Brandon
    Fort Collins
    2019 Cement TRDOR 6MT
    The OEM cover has a posted weight limit on it that I'm pretty sure is over 100lbs. I'll have to look next time I walk outside. OP are you just planning on running straps into the wheel wells?
  6. Jul 21, 2020 at 9:28 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    I've stood on my OEM one before with no issues. I'd say if it's strapped down securely you shouldn't have any issues.
    SnowSpartan[OP] likes this.
  7. Jul 21, 2020 at 9:29 AM
    SnowSpartan
    Boise, Idaho
    Yeah IIRC it is around 100lbs. I was going to run the straps on each side of the cooler, into the metal rings closest to the cab. It would be two 35 qt coolers.
  8. Jul 21, 2020 at 9:31 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    If you do that, cut a few 2X4's the width of the cover, put the coolers on top. If you do that, the only tie downs are your wheel wells. Bad Idea.
    Better solution... load bed, leave cover open, stack coolers on top of your other gear, tarp it up and use the tie downs inside your bed.
    pEKEo-VW4o8VchYgKkP_ACtKHeUtil1h9YV46BYM_ca633406ac6782d2fe9d1a5741547a4e6492aa77.jpg
  9. Jul 21, 2020 at 9:43 AM
    TurdTaco64
    Brandon
    Fort Collins
    Just make sure once you get them strapped down that you give them a shake and say "that ain't goin' anywhere."
  10. Jul 21, 2020 at 9:45 AM
    TurdTaco64
    Brandon
    Fort Collins
    I think you could also make some loops with 550 cord to attach to the tie downs in the bed and run them out of the cover to catch with your ratchet straps.
  11. Jul 21, 2020 at 10:16 AM
    Tacowin1013
    Theres really no good tie downs to the tonneau anyways, esp if going at highway speeds and if the cooler is full, i wouldn't want to keep looking back checking to see if it still there!
  12. Jul 21, 2020 at 11:00 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    As @hiPSI mentioned, I'd add supports, and even better, ditch the cover and pile high. You gotta remember, it's not the static weight, it's the weight bouncing on the cover, I don't how what that is, but it's a lot more than just the static weight.
    hiPSI likes this.
  13. Jul 21, 2020 at 11:26 AM
    travadol
    travadol Well-Known Member
    Travis
    Prairies, Canada
    2020 Cement DCSB OffRoad Premium
    I actually laughed really hard when I read this because I've said that exact line so many times.
