Straying from the "norm" of 285's
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 808_tacoma, Aug 16, 2019.
  1. Aug 16, 2019 at 6:32 AM
    808_tacoma
    808_tacoma [OP] Well-Known Member
    Chad
    Morgan Hill, CA
    Thought I'd post in here for the 3rd gen specific folks:
    I have 265/70/17 Cooper STT Pros (10.7" section width and 31.9" height) and love them but have been considering other sizes now that I'm getting my 2" lift. I came across 305/65/17's which are quite appealing... I'd much rather have the width versus height and they come in at 32.7" in height and a hefty 12.3" section width.
    Anyone try this size before? I'm thinking that it might be a bit safer on the cab mount rubbing but might need to watch UCA rubbing.
    Also noticed that BFG KO2's (which I've been considering switching over to) come in this size and are a tad friendly on the sizing 12.2" section width and 32.6" height...
  2. Aug 16, 2019 at 6:41 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    What wheels? Spec's on them?
  3. Aug 16, 2019 at 6:43 AM
    808_tacoma
    Chad
    Morgan Hill, CA
    I'm on 17x8 0 offset FN FX Pros
    but curious in general if anyone else has tried the size
  4. Aug 16, 2019 at 6:48 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Those tires are basically a traditional 33x12.5 you’ll rub the cab mount for sure
    na8rboy likes this.
  5. Aug 16, 2019 at 6:53 AM
    na8rboy
    WI
    Type it (305/65/17) in Search box in upper right corner, check this form only. Your answer is there.
  6. Aug 16, 2019 at 6:53 AM
    808_tacoma
    Chad
    Morgan Hill, CA
    I've looked through them all... not many 3rd gen folks running it.
  7. Aug 16, 2019 at 8:20 AM
    PJTACO
    PJTACO Well-Known Member
    2017 Cement TRD PRO
    on stock pro wheels I'm about a half inch from the UCA with 285s, I have never rubbed on my cab mount, but had to heat gun a little plastic. I think there's more room in the wheel well for a taller tire, I am not really sure about a wider one
  8. Aug 16, 2019 at 8:27 AM
    Dryfly24
    Dryfly24 He’s a leprechaun. He tells me to burn things.
    George
    NM
    2020 Jeep Gladaitor - Formerly 2019 Tacoma OR SB
    I’m running 285/75/16’s and clear the UCA’s but just barely. I don’t think it would work.
  9. Aug 16, 2019 at 8:42 AM
    Ricetacoma
    Ricetacoma Well-Known Member
    2024 Tacoma - TRD Off-road - DCSB - Bronze Oxide
    Same thing here 285/75/16, that is about all she can handle in my opinion.
    Dryfly24[QUOTED] likes this.
  10. Aug 16, 2019 at 9:06 AM
    808_tacoma
    Chad
    Morgan Hill, CA
    Yea, I saw a guy with a 2nd gen running these 305’s but with -10 offset. I’m thinking that with a 1.25” spacer I could pull it off, but that’s a pretty wide setup. Then again... that’s what I’m looking for.
    If I do it, I’ll make sure to report back! Haha
