streetglow h4 90/100 w
Discussion in 'Lighting' started by kidstock, Nov 6, 2011.
  1. Nov 6, 2011 at 7:39 PM
    kidstock
    kidstock [OP] Member
    Ok just ordered a set. Anyone ever used them? Is the $26.00 spent gonna be worth it?
  2. Nov 6, 2011 at 7:49 PM
    kidstock
    What size fuse should I use with these bulbs?
  3. Nov 6, 2011 at 8:13 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    90 or 100 watt i would say around 20 amp 25 amp at the most with good wiring
  4. Nov 6, 2011 at 8:36 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I don't have any experience with those bulbs but, assuming the "90/100W" claims are accurate, I doubt you can run them safely on OEM wiring and in your stock headlight housings. (IIRC, stock bulbs are only about 60W.)
  5. Nov 6, 2011 at 8:48 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I don't think the factory wiring can handle that. If you put them in and the fuse blows, don't upsize the fuse. It is sized to protect the factory wiring and keep the truck from burning down. :eek:
    There are wiring harnesses made for this purpose. I would pick one up if I were you.
    http://www.rallylights.com/detail.aspx?ID=1247
    I have had over wattage bulbs on other trucks with glass headlight lenses and metal enclosures. They worked AWESOME. I would try it on my 2006, but I am worried I will melt the plastic housings.
    Let us know how your headlight housings hold up if you do it.
    I'd also be concerned about glare to oncoming traffic.
  6. Nov 6, 2011 at 8:50 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    too many watts for your wiring and the plastic headlight housings. i wouldnt do it
  7. Nov 7, 2011 at 4:08 AM
    kidstock
    Ok thanks for the input guys. I think I am gonna keep my fuse at a low amp just to make sure I DON'T BURN MY TRUCK DOWN. Will keep ya posted.
