Stretch's First Gen Build
Discussion in '2nd Gen. Builds (2005-2015)' started by Stretch, Apr 2, 2009.
  1. Apr 2, 2009 at 10:44 AM
    Stretch
    Stretch [OP] Active Member
    Boone, NC
    Shitbeat 85 Xtra Cab
    Chevy 60 14 Bolt 42" TN Cut TSL's Linked Propane
    Yeah I know its a first gen, but it has Tacoma wheels so :p.
    1980 Long Wheel Base Truck
    20r Motor
    It rolled into the shop on some 35x15.50 Boggers, no power steering, a rusted out frame and some 3" Trail Gear Leafs up front.
    Started removing all the stock steering...
    And Installed Some Trail Gear High Steer and swapped out the 3" Leafs for some Rears up front
    The got to working on the frame...cut and ground off the bed mounts and prepped the frame for plating.
    As more parts came in I got back to work on the front end. Welded up the thirds, 30spline Longfields and plated the frame for the steering box.
    Next up was addressing the gearing. I am running 38x13x16 TSL's so the stock TCase wasnt going to cut it. Marlin Crawler Duals w/ a 4.7 Gearset in the back case.
    Had to convert the front box to a TopShift case
    Reassembled everything then built the flatbelly xmember
    Plated the frame
    On went the 38's
    Had it ready for a shakedown then had issues with the carb so I put the project on the back burner for a while until I could get some propane on it. Just finished that last night. Had to make an adapter plate to mate the 22r throttle plate to the Impco 225 mixer.
    Still left to do is:
    -Weld a new flange on the rear driveshaft.
    -Gusset shock mounts
    -Chain Motor Mounts
    -Repair front axle fill plug and fill the axle.
    -Have new exhaust made.
    -Pick up, mount and bob the new bed.
    -Mount tank brackets.
    -Wire in new LED tails, reverse and KOH style amber marker light.
  2. Apr 2, 2009 at 10:54 AM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    sweet
    i wish i had a 79-83 4wd yota
  3. Apr 2, 2009 at 10:57 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Wow...That's a labor of love right there. Nice work.
    Silly question- but what you are doing with the propane??
  4. Apr 2, 2009 at 10:57 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Very, very cool build!
  5. Apr 2, 2009 at 11:02 AM
    Stretch
    Boone, NC
    Thanks! The propane mixer replaces the carburetor. By doing this, the entire thing runs on propane. The entire stock fuel system is gone. The benefit to this is that the truck wont cut off on extreme angles like carburetors do. The truck could run while turned on its side as long as it maintains oil pressure.
  6. Apr 2, 2009 at 11:06 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    woo hoo
  7. Apr 2, 2009 at 11:06 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Nifty...What is the weight trade off for taking the fuel system out and putting propane in?? What is the flow rate for propane??
  8. Apr 2, 2009 at 11:14 AM
    Stretch
    Boone, NC
    Weight would probably be a little less. I never did a before and after run through the scales. I run 1 8gal propane tank at a time as opposed to a 15 gallon fuel tank. No idea on the flow rates, I just know it burns around 100-110 octane and works a ton better than a carburetor ever will.
    On a side note...DarkKnight...that custom user title is awesome! haha
  9. Apr 2, 2009 at 11:18 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    How long does a 8 gal tank last??
  10. Apr 2, 2009 at 11:22 AM
    Stretch
    Boone, NC
    A couple of us run the same setup on 20/22r's and regulary go through a tank per day and a half of trail riding. Depends on how much baja'ing we do and how much skinny pedal is needed that weekend on obstacles.
  11. Apr 2, 2009 at 11:26 AM
    Dark Knight
    Jeff
    NC/SC
    probably my favorite movie of all time! and I just noticed you were in Boone. Bad ass, I'm just over the mountain in Johnson City
  12. Apr 2, 2009 at 11:28 AM
    Stretch
    Boone, NC
    Ah cool. We will be rolling through there tonight on our way to the April Fools Day Crawl in Harlan, KY.
  13. Apr 2, 2009 at 11:28 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Nice...Thanks for the info. Never seen a propane set up before. Sorry to clog your build thread up wit hall the questions!!
    Awesome work!!
  14. Apr 2, 2009 at 11:30 AM
    Stretch
    Boone, NC
    No problems...glad I could provide a little tech.
  15. Apr 2, 2009 at 11:31 AM
    Dark Knight
    Jeff
    NC/SC
    woo wee wish i could go to that! but gotta work Saturday in Charlotte
  16. Apr 7, 2009 at 8:57 AM
    Stretch
    Boone, NC
    Got it running and all the leaks found the other night. Still need to modify the idle adjustment screws and re-route a few vacuum lines. Other than that its running on propane now.
    Got my temporary mount for the tank. A big sheet of 3/16 plate. That will do until I can find a long wheel base bed. Then that plate will become the belly pan.
  17. Apr 7, 2009 at 11:11 AM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    idk if this is any help to u but i seen a lwb 79 2wd toyoa truck at a junk yard about 11 mi. from my house if ur desprate for a bed
    i didnt really look at it but i dont think it had too much rust on it if u want i could talk to the guy about it
  18. Apr 7, 2009 at 12:36 PM
    Stretch
    Boone, NC
    That would be awsome if you could. No big rush as I am going to be in DC until Saturday but I sure dont mind driving down there for it, or throwing some compensation your way for finding it.
  19. Apr 7, 2009 at 12:43 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    no prob man is there anything else u need for it ill be glad to ask 4 u
  20. Apr 7, 2009 at 3:48 PM
    silver07taco
    silver07taco Well-Known Member
    COIL
    Maryland
    13 Tundra RCSB 5.7 4x4,07 Tacoma AC 4.0 4x4
    2013 Tundra RCSB 5.7 4x4, 2007 Tacoma AC 4.0 4x4
    Nice build!
