Strictly 1st Gen Air Filters
Discussion in '1st Gen. Tacomas (1995-2004)' started by goldentaco03, Jun 23, 2015.
What Air Filter Do You Use In Your First Gen?
  1. K&N
    15.2%
  2. AFE
    17.7%
  3. Stock
    50.6%
  4. Other
    16.5%
  1. Jun 23, 2015 at 7:05 AM
    goldentaco03
    goldentaco03 [OP] Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    I want to see what air filters everyone really uses. It seems to be split between K&N and AFE so I want to settle this.
  2. Jun 23, 2015 at 7:23 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I just change the damn things regularly. In the last 20 years, i have had all my Toyota go well past the 200k mile mark. Air filters are not something that is going to gain me much by spending extra money.
    My last Tacoma went 300k before the frame rusted in half. hi dollar air filters would not have prevented that from happening.
    Wyoming09 likes this.
  3. Jun 23, 2015 at 7:26 AM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    I voted K&N because I'm running their filter in the stock air box. But I am considering going back to just the stock Toyota paper filter.
  4. Jun 23, 2015 at 8:06 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Stock paper
  5. Jun 23, 2015 at 8:24 AM
    PhdNPrerunners
    PhdNPrerunners Well-Known Member
    Justin
    The Woodlands, TX
    1999 4Runner SR5 4WD
    I would go with an AEM dry fly air filter. I wouldn't go K&N since you have to oil it.
    czotie likes this.
  6. Jun 23, 2015 at 11:48 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I now am using Wix filters when this case runs out I might go Napa or Toyota just depends
  7. Jun 23, 2015 at 12:27 PM
    roehoe72
    roehoe72 Well-Known Member
    Dan
    Vacaville, CA
    04 dc prerunner v6 trd
    This is what i did..
  8. Jun 23, 2015 at 6:45 PM
    bawilson21
    bawilson21 Well-Known Member
    Bryan
    WA
    00 SR5 V6 4x4 5-speed
    Rear Diff Breather Extension Deck Plate Mod 31" Destination A/T 3" Body Lift Rancho 5000 Shocks Grey Wire 7Pin Tow harness
    Mann, Beck/Arnley, Wix, or Denso paper filters
  9. Jun 24, 2015 at 5:02 AM
    goldentaco03
    Liam
    NJ
    What about with a deckplate mod? What would be best?
  10. Jun 24, 2015 at 5:35 AM
    koditten
    Kirk
    Central Michigan
    With the plate mod, you will have a chance to bring in more dirty air. No matter what filter you use, you are going to need to change the filter more often. It's not going to matter what filter you use. Me? IM going to use whatever is the cheapest.
  11. Jun 25, 2015 at 7:50 AM
    Styx586
    Terrance
    Lake Elsinore, Ca
    ^This^ It really doesn't matter what filter you use with the deckplate mod, it will just get dirty faster. I have run the K&N and a stock paper filter with the deckplate mod. No difference in performance... The only thing that mod does is make the truck louder.
  12. Jun 25, 2015 at 11:54 AM
    Nowhereman04
    Nowhereman04 Well-Known Member
    Tar Hill Blue NC
    Silver 04 DC 4x4 SR5 TRD OFF ROAD
    Bilstein 5100's front, Bilstein 5125's rear
    I ran the K&N for awhile right after I bought my truck back in 04...complete waste of money. No performance gain whatsoever, and the oil gets sucked in and screws up your MAS. I'm currently running a stock filter, and have been for the last 50K.
  13. Jun 25, 2015 at 3:44 PM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    To those who use an AFE Pro Dry S, how does it compare to using basic, replaceable filters? Not so much performance-wise, since I doubt there is any difference, but talking cost. Will it end up paying for itself/saving money? And if so, how long does it take? When I finally get a Taco, if I am to switch to one, I figured it would be best to get one right away, to maximize the cost benefit. I want to make sure beforehand, though.
  14. Jun 25, 2015 at 3:59 PM
    bubbabud
    bubbabud Well-Known Member
    Bob
    Tonopah AZ
    13 tacoma TRD Off road.ARE shell no rust anywhere period.
    2 in spacer lift front 2, in AAL rear [tundra leaf] , flip up tow mirrors, ARE shell electric brake controller and cooper ATP 265/r70x16 tires on stock TRD wheels
    In a normal DD situation I change my stock paper filter every 30k for about $7 you do the math.
  15. Jun 25, 2015 at 4:04 PM
    sente3
    sente3 -
    North Jersey
    That's about what I figured. My last car was about the same, hence why I never got a cleanable filter. It never seemed worth it, but I like the concept of not throwing things away. My asking was mostly just curiosity/hopefulness.
  16. Jun 30, 2015 at 4:03 AM
    MtnClimber
    MtnClimber Well-Known Member
    Jareb
    Wayne, Maine
    '10 DC
    OME suspension, STT Pro's, sliders, XRC 10K winch, Aluminum skids, ARB, CVT, GFC, OVS, ECGS stuff, Midland stuff, TRD stuff
    I use Wix filters purchased at my local NAPA. I don't want to risk any oils from a oiled air filter getting on and clogging my MAF.
  17. Jun 30, 2015 at 7:49 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    If the oil filter dissection wasn't enough for you guys, I'd guess the stock stuff is likely superior at filtering in this instance as well. Stick with stock.
  18. Jul 2, 2015 at 2:03 PM
    Kurama
    Kurama Member
    Minnesota
    04 TRD 4x4
    No difference in performance between the K&N and the stock or the deckplate mod itself?
    As for me, I stuck with OEM air filter, I ran the K&N and didn't care for it. Never tried AEM but don't think I'll bother.
  19. Jul 2, 2015 at 4:29 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    I utilize an K&N fipk as my primary intake
    but I also have the factory air box with deck plate mod.
    Occasionally I will run the later if I know I'll be splashing some on wetter trails.
    If I run the AB/dp closed... the stock fuzzy filter generally stays cleaner/longer.
    Tarmac duty would likely see it staying cleaner and for even longer periods.
    But when utilizing my AB deck plate mod (open)... the stock fuzzy gets dirtier and quicker.
    Especially when off road and in dusty environments.
    I've even had the pc throw a code when the element has become clogged.
    and so I would suggest a filter that can be washed/cleaned if using the DP/FAB.
    ^ that or carry a spare element when off road and in a dusty environment.
    Realize that most users of the K&N not only over oil it...
    but likely clean it excessively and more then it should be.
    The K&N filter elements work best if left somewhat dirty.
    The encrusted dirt stuck to the oil on the gauze
    actually assists with finer filtration.
    I would not advise using a K&N drop in element...
    unless one understands/follows the oiling/cleaning procedures.
    Even then... it's pleat holes are larger then that of the fipk's conical element.
    And... there are less holes per square inch on the drop in element.
    So I wouldn't use the K&N drop in element 'cept maybe for street duty.
    Realize that the K&N drop in element
    is nowhere close in performance/protection
    when compared to the conical element of the fipk's system.
    ^ even then... a pre-filter over the fipk's conical element is smart
    if wheeling off road in severely dusty conditions.
    I'm too cheap to pay for K&N's pre-filter...
    So I simply cut the foot off an old pair of nylon stockings
    and cover the fipk's element with that.
    Yep... I oil the nylon pre-filter too.
    When it gets excessively dirty...
    I just take it off, shake it out, re-oil it, reinstall it
    and it's ready for another round.
  20. Jul 3, 2015 at 5:30 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    no need to spend big dollars just to pay for a fancy name on the box, here are very good quality, economical, permanent air filters for our trucks.
    permanent air filter v6 - $27 http://www.ebay.com/itm/321703561106?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
    permanent air filter I4 - $25 http://www.ebay.com/itm/Spectre-Air-Filter-for-Tacoma-HPR6690-/381302233204?fits=Model:Tacoma|Engine+-+Liter_Display:2.4L&hash=item58c7625874&vxp=mtr
    looks to be even better quality then the k&n filters I have bought in the past
