Stripped a screw, now what?
Discussion in '1st Gen. Tacomas (1995-2004)' started by JustADriver, Nov 30, 2021.
  1. Nov 30, 2021 at 3:21 PM
    JustADriver
    JustADriver [OP] Well-Known Member
    1996 Tacoma 3.4L V6 2WD 5-lug AT 5VZ-FE
    I tried to pull the IAC off my throttle body. I held it between my knees, applied a lot of down pressure, 3 of the 4 screws came loose, and I stripped the 4th screw. I guess I should have bought one of those special JIS screwdriver sets to perfectly fit it, but I've ordered so many tools and so many parts that my shelves and drawers are stuffed full of expensive stuff. I guess it figures that the one thing I didn't order was crucial and it's going to cost me a lot by skipping it.
    I could reassemble all the parts, order a JIS set online with overnight shipping if possible, and hope for the off chance that I might be able to still get the screw out?
    I already sprayed penetrating fluid on it a few times, tapped it, and waited a while.
    I'm thinking most likely a JIS set is going to be a waste of time and money, and I need to buy another $400 throttle body. I don't know what all parts come with a throttle body. At this rate the screws holding the few other parts onto the throttle body are going to strip too, forcing me to replace all kinds of stuff.
    I was trying to save the $800 a shop was going to charge me to replace the IAC, and I'm just spending hundreds on tools and costing myself hundreds more in broken parts.
    Are mechanic shops typically willing to use your parts you already bought? The one I go to seems to charge 3-5x retail for parts, plus $150/hr labor. But that's a pain too because I have to give up my truck for a day or two, and it takes 1-2 weeks just go get an appointment.
  2. Nov 30, 2021 at 3:23 PM
    Woodini
    Woodini Well-Known Member
    Ray
    Daytona Beach Shores
    89 Pickup 22RE 4wd
    LCE i/h/e OME susp (install soon) 17” fn counter steer, gonna buy new rubber
    That’s not stripped.
    dremel a fat groove in it and make it a flathead, use your longest screwdriver
  3. Nov 30, 2021 at 3:29 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Just invest in some JIS screwdrivers so you don't repeat the same mistake.
    Mark77 likes this.
  4. Nov 30, 2021 at 3:29 PM
    doityerself
    doityerself Well-Known Member
    The Deep South
    2006 SR5 DCLB 4x4
    Not Enough and it continues...
    Or try a small pair of vise-grip pliers to grip the head. But they will need to have slim jaws.
    Reggie4x4 likes this.
  5. Nov 30, 2021 at 3:32 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    I could take it out in 2 seconds with a Milwaukee 1/4 inch impact. The impact would break it free
    ironicallyjesus and se7enine like this.
  6. Nov 30, 2021 at 3:33 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Might as well drill it out and plier what's left. An impact driver with a JIS would probably get it free.
  7. Nov 30, 2021 at 3:33 PM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
  8. Nov 30, 2021 at 3:36 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Agree. not stripped.
    Also most dealerships that i've had the displeasure of working with will NOT use customers parts. New or used.
    This was not the case a couple years ago. Not sure what changed.
    Mark77 likes this.
  9. Nov 30, 2021 at 3:42 PM
    Matic
    Tricky Dick
    Easley, SC
  10. Nov 30, 2021 at 3:44 PM
    joeyv141
    joeyv141 Well-Known Member
    Virginia
    08 DCLB 4x4 V6 TRD Sport
    Cutting a slot and using a large flathead screwdriver will get it out no issue.
    Its what my old shop did for about 1/2 the carb bowl screws we had to remove.
    As for shops using customer supplied parts it depends on the shop, if they do use your parts there will not be any warranty. Also should you supply parts, the shop take vehicle apart to replace said part, find you supplied the wrong parts you are likely paying a rack fee until you get the correct part since now one rack is out of service.
  11. Nov 30, 2021 at 3:49 PM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    Make certain the JIS set has the size you need. They are not magical.
    Agree with the "cut a slot for straight driver" AND USE A LONG SHAFT...
    That's what she said...
  12. Nov 30, 2021 at 3:51 PM
    ZColorado
    13 DCSB OR 6MT
    it does not have a dimple, but thats not unusual for newer Japanese screws. They actually did away with the JIS standard, but the "cross point" screws are still standard on Japanese components. These vessel screwdrivers are actually "Cross Point" drivers, and not JIS.
    I did recently receive a piece of Japanese industrial analytical equipment at work recently, all the screws have the JIS dimple though. So not sure what thats all about.
    see the bottom of this page:
    https://www.vesseltools.com/handtools/screwdrivers/jis-japanese-industrial-standard
    Matic[QUOTED] likes this.
  13. Nov 30, 2021 at 3:54 PM
    Matic
    Tricky Dick
    Easley, SC
    The crosspoints would work best.
    I bet he could just tap it slightly using a phillips and ballpeen while turning, it would come right out.
    SellyKlater likes this.
  14. Nov 30, 2021 at 4:33 PM
    SellyKlater
    SellyKlater Well-Known Member
    Ponce Inlet, Fl
    2004 Tacoma 3.4L Double Cab TRD
    3" ome lift 883. Fnfx pros.
    Just looks like you need a better #2 tip.
  15. Nov 30, 2021 at 4:39 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Drill the head turn out with vice grips replace with hex head bolts no more problems.
    Woodini likes this.
  16. Nov 30, 2021 at 4:47 PM
    Woodini
    Ray
    89 Pickup 22RE 4wd
    When I built my ruckus, I replaced EVERY screw/bolt with SS allen head bolts
  17. Nov 30, 2021 at 5:10 PM
    JustADriver
    I just got back from the hardware store.
    I got locking needlenose pliers, which couldn't get in the tight space any better than the pliers I had.
    I also bought a Dremel 200, and there's nothing in the box that looks like a cutting wheel. Pic above. Nothing even fits on the tool after taking the cap off. There's a few sanding wheels or something that won't cut anything, but there's no way to even attach them because the holes are too small and the instructions don't say anything. It's in the trash now. Not gonna even try to figure it out. The store employee was useless.
    Is there some brand of cutting wheel I can buy that's ONLY a cutting wheel, instead of that weird Dremel 200 that looks like what I thought of as a Dremel tool but appears to be a sanding kit that I have to buy extra attachments and adapters for just to be able to cut?
    I could also buy an impact driver, but it sounds like I need to get JIS bits or it won't help.
    https://youtu.be/agIRNNA-6cs?t=1855
    The guy in the video above has a JIS screwdriver he recommends, so now I'm thinking I better buy both a JIS screwdriver set, an impact driver, and every JIS bit that exists, just to see what might work? I really don't want to go through more than one more cycle of buying tools. I want to just buy literally everything that might work, and then throw it all away when I get this done.
    Here's the screwdriver.
    https://www.amazon.com/gp/product/B00E55DL4I/
    se7enine, the filename of the pic in your post says it's a tekton multi bit driver? I looked on their site and I don't see anything like that.
  18. Nov 30, 2021 at 5:15 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I have that JIS set in my tool bag. It's all I use except for some toyota/lexus screw drivers.
  19. Nov 30, 2021 at 5:17 PM
    SellyKlater
    Ponce Inlet, Fl
    Those are mini cut off wheels and the arrow should be a adapter with a flat head screw at the tip to put them in.
    Also did you try tightening the screw a little and then loosing it? That helps sometimes.
    DES2009 and tcjacado like this.
  20. Nov 30, 2021 at 5:24 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    Tighten some vise grips on the shaft of a philips screwdriver to give you more torque when loosening the screw.
