Stripped a T30 bed screw, any advice on which screw extractor & bit size to use?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bondn3, Sep 11, 2021.
  1. Sep 12, 2021 at 6:01 PM
    #41
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    I have a nice set of LH bits that are almost always my go it. 90% of the time don't even need an extractor. An angle grinder would do it yes, without finesse in such a hard to reach spot. Jb weld a bit to the screw though? Hahahahaha
    KRUD likes this.
  2. Sep 12, 2021 at 6:05 PM
    #42
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    Some of these guys hate torx bolts because they are using HF torx bits . I walked around HF for an hour just to see and the only things I considered was zip ties and some gloves for the garden . In the end I couldn't do it and left empty handed .
  3. Sep 12, 2021 at 6:07 PM
    #43
    rangers12
    rangers12 Well-Known Member
    West Texas
    what brand are your LH bits? I have snap-on at work and they suck. Looking for another set.
  4. Sep 12, 2021 at 6:14 PM
    #44
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Quick fix, I’d slot that bolt in 3 seconds then use a flat head. No more that 30 seconds to fix
    Brand doesnt matter much with torx, ive ruined enough torq bits or bolts to hate them. Jeeps are put together with torx. The problem with torx is there just isnt enough surface area to support the torque needed to tighten or loosen in some cases.
    nhpoke likes this.
  5. Sep 12, 2021 at 7:09 PM
    #45
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    I disagree, torx has way more meat and surface than any other screw type fastener, it’s actually the only indentation type faster that will work well with an impact. Way more surface area in contact with the bit than Allen, Phillips, (square) Robertson, flat blade. Only thing better is a 6 sided bolt, but that’s not going to work on many places you use an inserted drive. Having quality torx bit, and torx faster is key though.
    edit they actually make oversized torx bits for the shit fasters some manufacturers use. Sounds like Chrysler uses crap, like Ford and some other American manufacturers.
  6. Sep 12, 2021 at 8:53 PM
    #46
    JoeCOVA
    Joe
    Colorado Springs
    Cool story. I’ve literally replaced everything that was torx and couldn’t be happier. You are the only person I’ve ever met that likes them. Must have never worked on a Jeep before.
    Everything is capable of being stripped, rounded or whatever. Unfortunately it seems I and others I know only ever have issues with torx.
    Anyways it’s moot torx suck and no words here will change that for me.
    KRUD likes this.
  7. Sep 12, 2021 at 9:03 PM
    #47
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Interesting bit...
    Henry Ford tried to get exclusive licensing for Robertson's screw. Robertson declined; Phillips did not.
  8. Sep 12, 2021 at 9:06 PM
    #48
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Believe it or not if that’s the only tool you have it’s doable. Repetitive light taps. I prefer a 16 oz claw hammer though in case I want to get it back out.:rolleyes:
  9. Sep 12, 2021 at 9:26 PM
    #49
    Fletcher37
    Fletcher37 Well-Known Member
    PNW
    Yota_MGM and Tacoboutkewl like this.
  10. Sep 12, 2021 at 9:37 PM
    #50
    Franky86
    Franky86 Well-Known Member
    Sac
    2019 OR
    I did the same thing too. Was a switching between the bakflip and the bed rails for my rtt, there was one that gave a lot more resistance than the others and that sucker stripped bad.
  11. Sep 12, 2021 at 9:39 PM
    #51
    bondn3
    bondn3 [OP] Well-Known Member
    Southern California
    2021 White TRD OR 4x4
    All in all these bed rail screws suck lol. Some screws came out like nothing and some were tightened like no tomorrow
    KRUD and davidstacoma like this.
  12. Sep 12, 2021 at 9:43 PM
    #52
    Ralphtaco805
    Ralphtaco805 Well-Known Member
    15 Tacoma
    Bilsteins 5100 Hellwig Rear swaybar 17 trd sportswheels
    Grind it off ur only hope
  13. Sep 12, 2021 at 10:02 PM
    #53
    Wyckedan
    Dan
    Woodinville WA
    I'm not sure what brand they are, I think I got them at Tacoma Screw, which you probably don't have wherever you are. Look for cobalt bits.
    The Irwin tools set might actually be pretty good
    KRUD and rangers12[QUOTED] like this.
  14. Sep 12, 2021 at 10:12 PM
    #54
    Franky86
    Sac
    2019 OR
    yep, that was my experience exactly. All but 1 was effortless. Would love to replace it with higher quality hardware but really don’t want to pull that one again haha
    KRUD and bondn3[QUOTED][OP] like this.
  15. Sep 13, 2021 at 7:08 PM
    #55
    mutely
    It’s not a “story”. I was replying to why you say torx are shit. You are wrong, there is more surface area on torx than other similar fasteners, and as such they can take more torque.
    Now, we can’t help user / tool / faster quality or error, and as I previously stated, until I got decent torx bits, I hated them.
  16. Sep 13, 2021 at 8:19 PM
    #56
    JoeCOVA
    Joe
    Colorado Springs
    Opinions arent wrong. No need to be so ignorant, the rotational surface area is no more than those tiny star points. Thats not a lot of surface area. I've bent every brand of torx bits up to T-50, unfortunately those little star points are super weak. I can conversely say that I have never rounded an 8/10 Allen. Maybe you are referring to the little 1/4" jobs like a T10-15 that you hand tighten with a screw driver to 5-10 ft/lbs. We have different experiences and can agree to disagree
  17. Sep 13, 2021 at 8:52 PM
    #57
    DogStar84
    DogStar84 Well-Known Member
    Northern California
    2021 Off-Road MGM
    AllPro Apex Rock Sliders SSO Slimline Front Bumper Baja Design lite bar 20" Baja Design Squadron SAE fog lites Mountain Hatch Tailgate Rek Gen mud flaps
    I did exact same thing. i used slightly too small of a torx bit.
    -Dealer sells the screw. I bought 3. I Keep two in the glovebox for next time or if a buddy has a nexttime! I also bought a full craftsman torx set.
  18. Sep 13, 2021 at 9:28 PM
    #58
    Tacomike18
    Tacomike18 Well-Known Member
    J
    I added a box to bed and wanted to remove the third bed rail on the bulkhead since it would be blocked. I destroyed one screw head so I left it there. At this point, if anyone can remove the stripped screw I’ll give that person the bed rail.
    KRUD and bondn3[OP] like this.
  19. Sep 13, 2021 at 10:13 PM
    #59
    bondn3
    Southern California
    DM me if you want me to refer you to a local shop lol
  20. Sep 14, 2021 at 3:40 AM
    #60
    IndyTac
    IndyTac Well-Known Member
    Indianapolis
    2019 TRD OR DCSB w/JBL
    Total Chaos bed stiffeners CaliRaised bed tie-downs CaliRaised 0-degree, bolt-on rock sliders Meso Customs Gas Hole JDM console and dash organizer Ceramic front tint Ceramic windshield coating Ziebart underbody and rust proofing Taco Garage Dashtop Multi-Mount (DMM) Black SR5 Grille Surround Swap Tacos4cheap Grille Badge Redarc Tow Pro Liberty Brake Controller Car Solutions Anytime Camera Mod TacoMods Radio Knobs Desert Does It Seat Jackers
    Many times. He seemed initially uncomfortable with a rotary tool or an extraction kit, so thinking outside the box. Called creative problem solving, not bad advice.
