Stripped drain plug hole, told normal? Lol
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NJZombieResponse, Apr 13, 2014.
  1. Apr 13, 2014 at 5:46 AM
    NJZombieResponse
    NJZombieResponse [OP] Well-Known Member
    Sicklerville, NJ
    Lifted 06 TRD Sport quad cab
    Billet Grills, AllPro front winch, AllPro rear bumper, Rugged Ridge 9k winch, 3 piece tri-fold hard bed cover, locking tailgate, real tree interior, JDM Black headlights, 8000K H.I.D. conversion on headlights, 4" PIAA ION yellow fog lamps, 2/3" Rough Country lift, 17x9 wheels with 265/70R17
    Dealer changed my oil the other day and the guy comes out telling me I need a 400 dollar oil pan because the drain plug is all stripped out.... What?!?! This truck never leaks! And they do all my oil changes! So the guy tells me that this is "normal" I asked my son and he told me to say no to everything and get the truck back but the guy was adimant on putting in an oversized plug and he said he'd work with me on the price and I told him no you won't, ull put it in free! This truck never leaked before now! So they put it in and said it MIGHT not work and if it don't I gotta pay for new oil pan. I'm writing to Toyota, and giving them a call to complain about this dealer. And to top it off they spilled oil all over inside my skid plates so when I got home oil spilled everywhere in the driveway! It was pooled up inside the skid plate! It's ridiculous! If your in south Jersey STAY AWAY FROM TURNERSVILLE TOYOTA
  2. Apr 13, 2014 at 7:05 AM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    'Normal' wear and tear is brakes, tires, belts.. etc.... not oil pan threads.
    Good for you for not buying their story. It still sucks though.
  3. Apr 13, 2014 at 7:07 AM
    Ghost848
    Ghost848 Well-Known Member
    Tony
    Alberta,Canada
    09 V6 TRD OR Silver M6
    OME + Dakers, 285/75R16 Nitto Trail Grapplers, ARB Bumper, Columbia overland Dual battery, Super winch,CC stage 4 clutch, bestop supertop, URD TO bearing, BHLM headlights, Cruisin offroad rear bumper, Harrop front E-locker.
    Sounds familiar.... Oh wait my local dealer!! Good on ya man!
  4. Apr 13, 2014 at 7:13 AM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    I'd love to hear their responses to this. That's terrible! Good luck on that and thanks for the warning.
  5. Apr 13, 2014 at 7:13 AM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    I guess it's normal if they use an impact wrench on it.
  6. Apr 13, 2014 at 7:20 AM
    tam
    tam Well-Known Member
    tam
    East Bay, CA
    Reasons to steal my truck...
    Icon Ext. Travel C/O, TC UCA, Spidertrax 1.25" spacers, CF hood, Glass bedsides, Doug Thorley cat-back, Goodyear Wrangler Duratrac 265/75/16
    I've got 160k on my first gen, no stripped oil pan bolts here. I do my own oil changes though. Don't fall for their B.S. and give 'em hell!
  7. Apr 13, 2014 at 7:25 AM
    Smoke
    Smoke Well-Known Member
    Eastern Ontario
    2006 SR5
    Stripped oil pan bolts is not normal. for any vehicle... Even a VW where you need to replace the trunk and the back bumper to change the oil or something retarded like that.
  8. Apr 13, 2014 at 7:25 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Yup 187k here, no stripping. If they have done all your changes, then there is no way they are not at fault. As mentioned above, oil pan threads are not normal wear and tear.
  9. Apr 13, 2014 at 7:43 AM
    NJZombieResponse
    Sicklerville, NJ
    That's what my son said too. He was pissed when u told him about it. If it still leaks I'm making then replace the pan on their dime!
  10. Apr 13, 2014 at 7:45 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If they stripped it, I would make them replace it, period. If they stuck a larger bolt in the hole, its just a matter of time before it begins to leak.
  11. Apr 13, 2014 at 8:01 AM
    G17GUY
    G17GUY Well-Known Member
    Modesto Ca
    tacoma
    spining hub caps chrome stick-on trim new car smell air freshiner stering wheel suicide knob nut sack on hitch back window curtain
    I would not accept the truck back until it is returned in the condition that you took it in.
  12. Apr 13, 2014 at 8:14 AM
    josh0351
    josh0351 Californication
    Josh
    VA
    Supercharged '13 TRD OR | '96 4X4 Reg Cab (RIP)
    Some stuff...
    ^^^THIS without a doubt! Fucking lazy-ass Stealership mechanics! :fenforcer: Sorry, Bro - stand your ground and don't settle for this BS. Hopefully Toyota North America comes back in your favor. Keep us posted.
  13. Apr 13, 2014 at 8:59 AM
    akhermit
    akhermit Well-Known Member
    Anchorage Alaska
    12 DCSB Magnetic Gray Metallic TRD Offroad
    Stripped threads are not normal. Someone overtightened or cross threaded the plug. Make them replace the pan or it may bite you in the a__ later on.
  14. Apr 13, 2014 at 10:08 AM
    File IFR
    Central MA
    One important thing to check: The jackoff that stripped your threads is most likely the same jackoff that spilled oil ON the engine.... do check to see if you have the correct oil level on your dipstick.
    The kid probably never added the extra to the crankcase.
  15. Apr 13, 2014 at 10:33 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  16. Apr 13, 2014 at 10:41 AM
    kyleTRDtaco12
    kyleTRDtaco12 Well-Known Member
    Kyle
    New Jersey
    2012 Toyota Tacoma Base DCSB 4x4 V6 6MT (202)
    TRD Cat-Back Exhaust TRD Sport Package Springs & Shocks (Front Linear Coil Springs, Rear TSB Leafs) Front & Rear Toyota/Bilstein 40mm Shocks) Silver Toyota 16" SR5 Wheels with 265/70/16 BFGoodrich Rugged Trail T/A Tires w/ Locks OEM Black-Chrome Housed Headlights (SR package) OEM TRDpro Grille Insert RokBlokz Rally MudFlaps w/ Stamped Logo OEM 'TRD Sport' Bedside Graphics TRD QuickShifter w/ TRD Shift Knob Hawk HPS Front Brake Pads w/ Brembo Blank Rotors OEM Front Aluminum Skid-Plate eBay TRD seat covers Rear Diff. Breather Mod A/C Drain Extension Mod OEM Fog Light Kit OEM Intermittent Wiper Switch OEM Bed D-Rings OEM Bed Mat OEM Door Sill Protectors Blacked-Out Badges (from Xrunner 205 Black Sand Pearl) Pop & Lock Tailgate Handle TruXedo TruXsport Roll-Up Tonneau Cover AVS BugFlector II Front Bug Guard AVS In-Channel Window Vent Visors TRD High Pressure Radiator Cap Stubby Radio Antenna Ultra-Gauge EM v1.2 w/ Windshield Mount BullaCulla 7-Pin Relocation Bracket Misc. Stickers
    Idk whats been up with these Toyota dealers lately... they have been just terrible.... I thought mine was good until they charged me $130 for an alignment, in the express lube section no less, and wanted $115 just to aim my headlights.... what? Someone in the service department must be smoking some of that good stuff Lol. Oh and I brought my corolla to the dealer once for an oil change and it was overfilled by a quart.... doyyyyyy
  17. Apr 13, 2014 at 10:49 AM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Regardless of the dealer saying that it will need a new $400 pan to fix the situation, you can easily fix it yourself for a fraction of the price provided you have the know how and the proper tools. All you need is a helicoil thread repair kit , new drain plug, and a tube of RTV ultra Grey gasket sealent and to drop the oil pan.
    I did this exact thing on a buddies 2008 4Runner because he stripped the threads on the pan. It took about an hour to complete the repair and that's including bullshiting with each other the whole time.
  18. Apr 13, 2014 at 11:20 AM
    car78412
    car78412 Well-Known Member
    Hudson Valley NY
    13 Tacoma reg cab 4x4
    It really is normal. This is what happens when your truck is serviced at a Toyota dealership. I know I know. Your gonna tell me that all dealerships are not the same. The sad truth is that they are. And your gonna tell me that your truck never had a problem before. I have been to 3 dealerships in my area for service and they all provided me the same poor service. Sooner or later your gonna pay that extra amount for Toyota service. It's just a matter of time.
  19. Apr 13, 2014 at 11:53 AM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    It is only normal if it is over torqued. So since they have done all the oil changes they need to pay for a new oil pan and the replacement.
  20. Apr 13, 2014 at 2:16 PM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    Precisely why I do my own maintenance on all my vehicles. I have the "Free Maintenance" plan on my truck but free isn't free when they fuck shit up. I know when I do it, it is done correctly and it is done the way that "I" want it done. Unless it is something internal or electrical I refuse to let anyone touch my truck.
    Good luck to you OP. Hope everything works out okay!
