Stripped filler plug on Man Trans...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pigpen, Mar 21, 2015.
  1. Mar 21, 2015 at 3:49 PM
    Pigpen
    Pigpen [OP] My truck is never clean
    Dan
    Northwest Montana
    Yep, that's what I did. The driveshaft makes it difficult to keep the socket square, so I rounded the corners a bit. Then I figured I'd use vice grips to get the job done (I have a replacement plug). Nope. The thing is on so tight that I don't know how I'm going to get it off. It's a filler it doesn't need to be that tight.
    I'm asking for constructive suggestions only please.
    Those who want to tell me how stupid I am will get replies about their mothers and sisters. That's the mood I'm in right now.
  2. Mar 21, 2015 at 3:52 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Have a nut welded on and try again
  3. Mar 21, 2015 at 3:58 PM
    Tacoma Mike
    Southern Maine
    6 point socket to start.
    The last thing you want to do is take a chisel and hammer to it.
    Try to get a 6point in it with a hammer. Make sure it's flush.
    If not try a good open end with a friend with a punch and hammer and some finess. Apply constant pressure and tap the end of a free corner.
    Then there are other ideas for a more sadistic approach.
  4. Mar 21, 2015 at 4:01 PM
    Tacoma Mike
    Southern Maine
    BTW. I hope it's still full and you haven't drained it yet..
  5. Mar 21, 2015 at 4:08 PM
    Pigpen
    Dan
    Northwest Montana
    Fortunately I knew better than to drain before removing the filler plug.
    I also knew the vice grips were a bad Idea, but didn't think the damned thing would be that tight.
    Both diffs and the transfer case were a breeze. I'll just leave it for now and figure something out. I'll probably go buy the right size open end and try that first. I don't want to pay someone to weld a nut on.
    Any other suggestions are welcome.
    ETA: got some dinner in me and my mood has improved - flame on.
  6. Mar 21, 2015 at 7:26 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    A small quality pipe wrench with sharp jaws will likely do the trick, if it's not totally rounded off beyond grabbing at all.
    Before you do anything though, smack the plug head-on a few times with a hammer - I know it's a restricted area, but smack it as best you can. This will compress the crush washer a bit, effectively loosening the plug slightly.
  7. Mar 21, 2015 at 8:00 PM
    tacoma4
    tacoma4 Well-Known Member
    I would say to drain the fluid and fill it from the shifter inside the truck, just measure out the right amount first. Then deal with the nut on your own time not worrying about changing the fluid. Would probably go with the welded nut myself.
  8. Mar 21, 2015 at 8:01 PM
    tacoma4
    Could also try hammering on a smaller size socket.
  9. Mar 21, 2015 at 8:04 PM
    Cmurder
    Cmurder 2011 TX TRD Offroad
    B.C.
    Kansas City
    2011 TX TRD Offroad
    nothing cool
    Yeah man. The 6 point socket should work. Itll grab the flat sides and not the rounded edges. Thats all i got really because that "should" do it. Good luck
  10. Mar 21, 2015 at 8:21 PM
    Pigpen
    Dan
    Northwest Montana
    wrench didn't work. tried to pound on a socket, no go - wouldn't stay on. went to the pipe wrench, nut started crumbling. got out the propane torch and tried the vice grips while it was hot - stripped more. the thing is officially buggered.
    I'm at 55k miles, this will be the second change. Toyota did the first one. I'm going to have a local exhaust guy do the exhaust reroute for me. I'll just do it sooner than planned and pull a "while you're down there...", and have him weld a nut on to it.
  11. Mar 21, 2015 at 8:21 PM
    Sparky73
    Sparky73 Well-Known Member
    Drew
    Washington
    13 DCLB 4x4
    Famous Fabrication Sliders, Duratracs, Painted Grill, BHLM, Devil's Horns Emblem, Derp'd Badges, Wet Okole Covers
    I'd spray it with penetrant and then heat the bolt with a torch before taking a welder to it.
  12. Mar 21, 2015 at 8:39 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    The last thing you would want to do is spray a flammable then put a torch on it.
    Heat makes metal expand and aluminum absorbs heat faster than metal, bad joo joo
  13. Mar 21, 2015 at 8:43 PM
    Conumdrum
    Conumdrum Well-Known Member
    Las Vegas
    2014 Tacoma
    2WD Sport Nav SC V-6 Mall crawler Home Depot truck
    Umm wipe it off first after a 2 hr soak............ Don't think the op will take a torch to it while he sprays it............:eek:
  14. Mar 21, 2015 at 9:41 PM
    Pigpen
    Dan
    Northwest Montana
    :D
    Yeah, I had that part under control...
    When I put the heat to it, I was hoping the casing would expand faster than the plug and make it open easier. Nope. I had already used the hammer and that didn't help either. The tech at my dealer must have really cranked on the wrench. I'll just change the fluid when I get a nut welded on.
    Thanks for all the recommendations. Maybe this thread will help someone not make the same mistake in the future.
  15. Mar 21, 2015 at 11:05 PM
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    Bring it to a dealership and pay to have them do it and install a new plug. Let them deal with the headache.
  16. Mar 21, 2015 at 11:24 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    ^^ This
    If it slips, I'd grind or cut 2 parallel flat spots into it and use the pipe wrench.... that will work.
    I wouldn't bother welding shit to it, IMHO.
  17. Mar 22, 2015 at 4:50 AM
    Tacoma Mike
    Southern Maine
    That is really messed up. Very sorry to hear about this. If I had known it was done before I would have said don't touch it and take it back.
    At least you have full trans. Good planning.
    Good luck.....
  18. Mar 22, 2015 at 6:25 AM
    Taco Nation
    Taco Nation Well-Known Member
    Zack
    Clinton, MS
    94.5 F350, 77 F150, 74 F100, 11 Jeep Grand Cherokee
    Lift, wheels, tires
    I have a 5 speed manual and I recently topped off my trans and diff and after a few days of driving the fill plugs had loosened and were both leaking oil. Trans was so loose I could turn it by hand. I think I read that the torque specs for both are 38 ft/lbs. I put more that that and the still came loose.
    As far as the filling goes the diff fill plug was so tight I had to use the next size down standard socket, the 24mm had a little play. Still couldn't break it loose. I put a cheater pipe on my breaker bar and bench pressed the bar using the weight of the truck to break it loose. Took almost all of the suspension travel before it broke. Such a pain in the neck.
  19. Mar 22, 2015 at 6:26 AM
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
