Stripped lug nut stud
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dustinclm, Nov 17, 2013.
  1. Nov 18, 2013 at 6:11 PM
    dustinclm
    dustinclm [OP] Well-Known Member
    Thibodaux, La
    2012 Super White DC 4x4 V6
    Bilstein 5100 set at .85" WeatherTech Floor Mats
    just saw that parts diagram online. thanks I'm going try to put them back on now
  2. Nov 18, 2013 at 6:18 PM
    dustinclm
    Thibodaux, La
    online says I need a special tool for these washers. I don't have it. does anyone have any ideas?
    EDIT: I got them back on. had the wife hold the pin and I just pushed them back on. my freak out is over. On a positive note. I have the stud changed and all that is left is to put the tire back on
  3. Nov 18, 2013 at 6:21 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Wow those springs shouldn't just fall off. Better they fall of now than on the road. They should be pretty easy to put back on.
  4. Nov 18, 2013 at 6:23 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Channel locks. Push the pin through the back, hang the spring off the front, and push the washer on and turn 90*.
  5. Nov 18, 2013 at 6:54 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    I guess you didn't loosen the drum brakes first?
  6. Nov 18, 2013 at 7:10 PM
    dustinclm
    Thibodaux, La
    I used two 8x1.25 bolts and pushed the drum off with those. if I needed to loosen the brakes, I didn't know or over looked it. those things popped off the second the drum was free and I had no idea where they came from. I got them back on like the diagram showed and I hope all is working.
    thanks guy for responding so quick
  7. Nov 18, 2013 at 7:24 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Did you release the parking brake before removing the drum??
  8. Nov 18, 2013 at 7:54 PM
    dustinclm
    Thibodaux, La
    I never engaged the parking break, if that's what you are referring to. I just broke the lugs, jacked up the truck, removed tire and then the drum. The truck was in park.
  9. Nov 18, 2013 at 7:56 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    You normally want to back off the star adjuster before forcing the drums off.
  10. Nov 18, 2013 at 8:12 PM
    dustinclm
    Thibodaux, La
    well now I know...
  11. Nov 18, 2013 at 8:13 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Didn't have to back mine off, just had to break the rust around the hub.
  12. Nov 18, 2013 at 9:51 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Depends on how many miles you had on the drums. It's possible for a groove to be worn inside the drums, so the shoes would catch on the lip of the drum when you try to pull it off.
  13. Nov 20, 2013 at 5:40 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Yea I understand, 116k miles though.
  14. Nov 20, 2013 at 5:41 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    No lip at over 100k miles? You sure your adjusters are working?
  15. Nov 20, 2013 at 6:15 PM
    #35
    Sandman614
    Tim
    '06 SR5 Off Road
    Maybe a slight lip, not bad enough to need to back them off. Positive, I also cleaned them up and lubed them after I hosed down everything with brakleen.
  16. Nov 21, 2013 at 6:31 AM
    #36
    coolreed
    coolreed Well-Known Member
    Reed
    OKC
    2019 Toyota Tacoma TRD Pro
    Goodyear Wrangler Dura Track Pro Tires, K&N Cold Air Intake, Pedal Commander.
    Instead of using a hammer to remove a broken lug stud. I have found that a pneumatic hammer works much much better and safer.
    I broke a stud recently and after replacement of the broken stud I cleaned my rear brake components on both sides and painted my drums. Might as well take advantage of the down time.
