Stripped My Front Diff Drain Plug
Discussion in 'Technical Chat' started by georgeandkanoa, Oct 18, 2011.
  1. Oct 18, 2011 at 6:09 PM
    georgeandkanoa
    georgeandkanoa [OP] the point is simply this
    jeff
    calgary
    07 tacoma trd
    bilstein5100's front tinted windows access cover pioneer stereo weathertechs grillcraft grill kc's behind cbi sliders
    friggin thing was so tight I couldn't budge it,and finally stripped it.
    any ideas if pumping the fluid out,and pumping new stuff in will be ok
    how often should it be changed anyway?
  2. Oct 18, 2011 at 6:16 PM
    georgeandkanoa
    jeff
    calgary
    07 tacoma trd
    do you know if the gears in there turn all the time or just in 4WD,
    I did my transfer case and the oil was like new
  3. Oct 18, 2011 at 6:17 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Since I tow I changed the front/rear differential and transfer case fluids out at 15,000 miles...will probably go ever 20,000 after that.
    edit: If you don't do any towing I believe Toyota recommends every 30,000
  4. Oct 18, 2011 at 6:19 PM
    Sigi
    Sigi Well-Known Member
    Sigi
    Sfv ca
    06 tacoma 4x4 trd offroad
    thats a good question cause i rarely ingage my 4x4..
  5. Oct 18, 2011 at 6:21 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    every 30k at most. use air hammer to chisel the plug and itll twist out. happens all the time. next time before u take a wrench to it. tap on it with a hammer staright on. lil tech trick ;)
    trippen1999 and NM Lance like this.
  6. Oct 18, 2011 at 6:22 PM
    georgeandkanoa
    jeff
    calgary
    07 tacoma trd
    fuuck,before i did it I read about tapping with a hammer,and I forgot to do that
  7. Oct 18, 2011 at 6:27 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    front and rear diffs see more wear and tear on the fluid. tcase not so much... t case fluid is always better looking
  8. Oct 18, 2011 at 6:28 PM
    georgeandkanoa
    jeff
    calgary
    07 tacoma trd
    thanks
  9. Oct 24, 2011 at 10:37 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Try a Heli-Coil. You can find them at NAPA. The kit comes with a tap and coil insert tool. They come in all sizes but you might have to use an SAE size. The metric one have been pretty rare in my neck of the woods.
    http://www.emhart.com/brands/heli-coil
  10. Oct 24, 2011 at 10:57 PM
    Stout890
    Stout890 Well-Known Member
    Palmdale ca
    99 prerunner sr5
    10" sub, OME881 on Bilstein's, 3" all-pro leaf springs with billies in the back, JBA UCA's, bed cover with custom LED lighting, k&n intake and DT headers, OEM E-locker in the rear. 32" BFG KO2 on steel D window wheels, suicide knob. rebuilt 3RZ w/ stage 1 cam and balance shaft delete . big 3 mod, all new suspension and body mount bushings. cat back magnaflow exhaust.
    were you using a 12pt socket?
  11. Oct 25, 2011 at 10:05 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    I did the same thing to my drain plug on a tundra. First thing I did was buy a new one from toyota. Then I took a good heavy hammer and a new POS cheap ass 3/4" chisel and beat that nut off. I ahd the chisiel cut into the drain plug good enuf to stay in place. Held the chisel with some vice grips to avoid pounding my hand and waled away. Just make sure you beat the plug in the right direction. Next time be sure to use a 10mm hex to avoid stripping.
  12. Oct 25, 2011 at 10:10 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    that doesnt sound like somethin id go around bragging about :rofl:
  13. Oct 25, 2011 at 10:19 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    It was liberating.
  14. Oct 25, 2011 at 11:33 PM
    Stout890
    Palmdale ca
    99 prerunner sr5
    :jerkoff::jerkoff::rofl::rofl:
  15. Feb 26, 2012 at 1:48 PM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    I was trying to change the fluid in my front diff today and couldn't get the drain bolt out. I didn't strip it yet, but it feels pretty damn close to stripping.
    I am going to hit it with a hammer and spray pb blaster on it everyday this week and hopefully give it another try next weekend.
    what a stupid idea to use hex bolts on the front diff. the rear diff and t case use 24mm bolts.. why can't the front diff use the same?
  16. Feb 26, 2012 at 3:56 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    PB blaster or any lube won't do a thing for you. Make sure you're using a 10mm hex vs standard, and don't hit it with a hammer. Hit it with a hammer and chisel only if it strips, either way, it sounds like you should just buy a new drain plug to replace that one. Good luck.
    EdgemanVA and REDdawn6 like this.
  17. Feb 26, 2012 at 4:18 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    use one of these........take it for a good drive first warm that bitch up
    REDdawn6 likes this.
  18. Feb 4, 2016 at 6:18 AM
    Codycode45
    Codycode45 Member
    98 tacoma 3.4 4x4 sr5
    My drain is a 12 and fill is a 10 my drain is pretty much stripped fucking thing is on there geuss ill try a chizle
  19. Feb 4, 2016 at 8:31 AM
    JLink
    Josh
    Ocean, NJ
    mix up some ATF and acetone and soak it a couple times a day for like a week then try tightening before loosening. also you can try heating where it threads into with a map gas torch. if all else fails, try a chisel and hammer to spin it loose. or if you have a friend with a welder, weld a nut to the head of it
    Snow Doctor and REDdawn6 like this.
  20. Dec 1, 2016 at 2:10 PM
    IslandYotaBoy
    IslandYotaBoy Active Member
    Nick
    NorCal
    2005 Tacoma v6 trd and 98 tacoma 2.3l 4 cylinder
    Well FML! I just stripped the front diff drain plug and yes I echo why the F did they put that hex bolt on and not the 24mm bolt they used for the tcase and rear diff Anyways what should I do get a chisel and hammer doesn't that work???
