Stripped oil drain bolt, what are my options?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by locster, Apr 10, 2015.
  1. Apr 10, 2015 at 8:26 PM
    locster
    locster [OP] Well-Known Member
    Luke
    Orange County, CA
    2014 DCSB 4x4
    Wasn't at my best today. It's only the 3rd oil change on my new truck and cross threaded the drain bolt. What other options do I have other than a new oil pan?
  2. Apr 10, 2015 at 8:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The oil pan is an easy replacement, as the bottom one (One with the plug), is small, and not that expansive. Otherwise, drill it out, and tap it for a larger plug.
    shakerhood and mbmack1 like this.
  3. Apr 10, 2015 at 8:32 PM
    RobertHyatt
    RobertHyatt You just can't fix stupid...
    Robert
    Birmingham AL
    2007 Tacoma Prerunner SR5
    Or drill it out and helicoil it for the same threads if you want to keep it stock-like.
  4. Apr 10, 2015 at 8:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah, Ive heard of folks having good luck that way, Ive just never been successful at it on a drain plug :eek:
  5. Apr 10, 2015 at 8:42 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    Pabloeeto likes this.
  6. Apr 10, 2015 at 8:43 PM
    locster
    Luke
    Orange County, CA
    2014 DCSB 4x4
    Where can I get one of those kits?
  7. Apr 10, 2015 at 9:03 PM
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    says the guy driving a jeep...
    ummm no. at least not without removing the pan.
    remove the pan, then tap it. or just buy a new pan.
    if you go drilling and tapping that pan while its installed in the truck where exactly do you think the metal shavings are going to go? they dont turn into pixie dust.
  8. Apr 10, 2015 at 9:12 PM
    high n mighty
    high n mighty Well-Known Member
    Oshawa Ontario
    01 camo taco
    If your gonna remove the pan then....
    Forget the tap, just put a new pan on
    PottMatter likes this.
  9. Apr 10, 2015 at 9:14 PM
    B737
    Kevin
    Jersey Shore
    stock
    +1
  10. Apr 10, 2015 at 9:14 PM
    high n mighty
    Oshawa Ontario
    01 camo taco
  11. Apr 10, 2015 at 9:16 PM
    Mr.Bohannon
    Mr.Bohannon Well-Known Member
    Dylan
    Winston Salem, NC
    1996 TRD 2.7
    Aisin Manual Hubs Bilstein 5100 K&N Drop in Undercover Tonneau
    I think the "remove the pan" step is kind of a given. :eek: Or maybe you're messing with chris and I'm missing your sarcasm...:anonymous:
    You still save for the cost of a pan if you just tap it to a larger size.
    shakerhood likes this.
  12. Apr 10, 2015 at 9:17 PM
    high n mighty
    Oshawa Ontario
    01 camo taco
  13. Apr 10, 2015 at 9:19 PM
    B737
    Kevin
    Jersey Shore
    stock
    the advice was remove the pan... "otherwise" drill it. lol
  14. Apr 10, 2015 at 9:23 PM
    high n mighty
    Oshawa Ontario
    01 camo taco
    or use that rubber plug in a pinch, it works, short term
  15. Apr 10, 2015 at 9:30 PM
    locster
    Luke
    Orange County, CA
    2014 DCSB 4x4
    At this point, I think I'm just gonna get a new pan and perhaps install a Fumoto valve while I'm at it. I have a skid plate, so will need to get a low profile valve.
    Thanks all.
    14TACO4X4 likes this.
  16. Apr 10, 2015 at 9:37 PM
    Harley2
    Harley2 Well-Known Member
    Rick
    Vermont
    15 Super White Double Cab 4x4
    In this situation I'd use a Timesert. Different than helicoil. Perfect and designed for this type of situation. http://www.timesert.com/. any tapping that needs to be done no matter how you handle it put a blob of grease on your tap. It holds any metal chips as you tap. Far cheaper and quicker than replacing the pan and its a permanent repair. I've used them with great success on Harley pans etc.
  17. Apr 10, 2015 at 9:55 PM
    locster
    Luke
    Orange County, CA
    2014 DCSB 4x4
    I checked out the kit for this application, and it's ~$95, which is the price of a new oil pan online. You do end up with a steel threaded insert though, if that's one advantage over the new pan.
  18. Apr 11, 2015 at 3:34 AM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    They make oversize self tapping drain plugs. Just go to an auto parts house and pick one up for a few bucks.
  19. Apr 11, 2015 at 3:40 AM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    as lazy as I am that would be a permanent fix for me.
    devkurf likes this.
  20. Apr 11, 2015 at 4:21 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Actually, the advice was replace the pan, otherwise drill and tap. just sayin... :rolleyes:
