Stripped oil drain bolt, what are my options?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by locster, Apr 10, 2015.
  1. Dec 14, 2016 at 2:51 PM
    #61
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I'm just curious about this 5/8 inch wrench...
  2. Dec 14, 2016 at 2:52 PM
    #62
    WhiteNight
    WhiteNight Well-Known Member
    PDX
    13 DCLB SPORT
    Dynamat, Rigid E series 30", Rigid SR2 combo/Rigid grill, Redline elite hood struts, Clear Bra all over
    How did you strip a 2014 oil pan bold just curious? It's best to use specific wrenches on these trucks and a torque wrench to avoid this
  3. Dec 14, 2016 at 4:13 PM
    #63
    locster
    locster [OP] Well-Known Member
    Luke
    Orange County, CA
    2014 DCSB 4x4
    I started by hand, but it would only go in about halfway. I backed it out and tried it again a few times, but again, it started to get tight midway. I should have stopped to inspect the thread, but instead, grabbed the wrench to finish it (I had a skid plate in place and was trying to work around it, so I was a little lazy). That's when I felt even more resistance and knew right away that I'm fucked.
    I might have damaged the thread from overtightening after the previous oil change. I think 30 ft-lbs is quite high.
    BTW, I've been running a Fumoto valve ever since.
  4. Dec 14, 2016 at 4:45 PM
    #64
    Rctrumpet1993
    Rctrumpet1993 Member
    2014 red regular cab 4x4
    None
    Normally it's just the bolt, but if you fight it instead of replacing it, then it's the pan too. Very clear now lol
  5. Dec 14, 2016 at 4:52 PM
    #65
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I don't know why those engineers didn't design these oil pans to use a cork. It seems it would have eliminated these problems.
    This would be perfect.
  6. Dec 14, 2016 at 6:09 PM
    #66
    Checkk
    Checkk Well-Known Member
    Tom
    2011 Toyota Tacoma Prerunner TRD OFFROAD
    At my shop we work on anywhere from 20-30 cars a day, 6 days a week. at 15 bolts/nuts/screws per car were unscrewing and reinstalling over 10,000 bolts/nuts/screws a month. If you work on as much cars as we do, you'll eventually strip, cross thread a bolt. Shit happens. Try torquing down a head bolt on a 2AZFE engine after a blown headgasket and tell me if you're successful at not pulling out the threads on the block.
    For steel pans like ours, just replace the pan, its cheap and easy enough to replace vs trying to thread it. I usually rethread aluminum pans with the timesert kit since some pan replacement can cost anywhere from $200-500 depending on vehicle. Also the steel inserts are going to be stronger afterwards then the new aluminum pans.
    Rctrumpet1993 likes this.
  7. Dec 14, 2016 at 7:38 PM
    #67
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I've been doing it since I was a teenager and I've never stripped or cross threaded one and I'm within a few months of being 62... But then again I am careful. And I don't use a torque wrench on a drain bolt. I have a calibrated elbow. :)
    teamfast likes this.
  8. Dec 14, 2016 at 8:49 PM
    #68
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Ha! You said 2AZ-FE block threads stripped. The most notorious Toyota engine for doing so. Over torqued from the factory. Look on Amazon for that engine's head gasket, and frequently purchased together is a Timesert kit. Uuughhhh. What a pain in the ass!
    Did one with a friend last year. Ended up pulling the head without removing the engine or timing cover. Un-torqued each head bolt in sequence about 20 times. Until they were all loose. Block was good but head was distorted.
    A pair of bolts which went through the timing cover into the head......*****still had moist silicone on the ends of them!!!!!***** From a 2008 tC! We had to video it because it was seemingly impossible. Torqued head bolts back down to the newest spec, and ran like a champ.
  9. Dec 15, 2016 at 8:13 PM
    #69
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    I can count on one hand the amount of bolts ive cross threaded. There are those who are DIY and those who aren't.
  10. Apr 10, 2020 at 8:21 AM
    #70
    RHelton10
    RHelton10 Well-Known Member
    Atlanta, GA
    '16 DCLB MGM TRD Sport 4x4
    Predator bars, Revolver X2 tonneau cover, SwingCase tool box, Husky mats, HID conversion Fuel vapor 17” wheels, 2” front /1” rear lift with Bilstein 5100’s, 285/70R17 Nitto grappler 2’s
    Just found this thread after searching for solutions to this exact problem. I'll say this; I've done this hundreds of times on various bolts / vehicles and never had an issue until I tried to do an oil change on my 2016 Tacoma. My issue was not cross threading but I think more of over torquing. I used a torque wrench set at 30 lbs and it starting to become loose before I reached 30 lbs so I knew I had a problem. I'm now waiting on a new oil pan / drain plug to arrive so I can replace everything. I've also ordered a Fumoto F103S drain valve so I won't have to deal with this in the future. To me it seems 30lbs is just too much for these components. Only other thing I can think of is the tech that did the previous oil change screwed it up and I didn't notice until I went to do an oil change myself.
  11. Apr 10, 2020 at 12:34 PM
    #71
    Jimmyh
    SC
    2012 Prerunner SR5
    Well if the drain plug / hole has oil on it you cannot use the specifications listed as they are for a dry torque value. Or it is possible that whoever did the last change screwed it up.
    This is why I never use a torque wrench on a drain plug. Clean surface with a good gasket or seal ring and snug it down tight. The oil in the pan is not under pressure forcing it out.
    RHelton10 and Torspd like this.
  12. Apr 10, 2020 at 12:37 PM
    #72
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Did you check the threads on the pan? Maybe they are much harder than the threads on the bolt. You may be able to chase the threads and get a new bolt.
  13. Apr 10, 2020 at 2:22 PM
    #73
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Geez,loosen the bolt with a wrench,screw it off by hand,reinstall all the way by hand tighten a little with the wrench and done.
    Blockhead and HawkShot99 like this.
  14. Apr 10, 2020 at 8:34 PM
    #74
    Waasheem
    Waasheem
    2007 xrunner
    I did a recent oil change, following someone who is notorious for over tightening everything. It was a really old vehicle with an inaccessible awkward drain plug. Of course the plug was already worn to hell due to the awkward position, probably the original plug from the factory, add over tightened, I destroyed it getting it out. I advised the customer of how bad the plug is, I had a better used one, or I can order a new oem plug. He decided on using the better used plug and order a new one for next time. Honestly is what I try to give them because it’s what I would want if it were my vehicle.
