Stripped oil drain plug
Discussion in '3rd Gen. Tacomas (2016-2023)' started by abou824, Sep 15, 2024.
  1. Sep 18, 2024 at 11:13 AM
    #81
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    10-4.
    The question was simply to satisfy my own curiosity.
  2. Sep 18, 2024 at 11:40 AM
    #82
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    I stripped the trans pan on my 2nd gen back in 2015 torquing to spec. Never again. :laugh:
    abou824[OP] likes this.
  3. Sep 18, 2024 at 11:45 AM
    #83
    jmneill
    SE
    One of the 22 little bolts?
    I thought I was going to strip every one of them... lol
  4. Sep 18, 2024 at 11:46 AM
    #84
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^No. The trans pan drain plug.
  5. Sep 18, 2024 at 11:48 AM
    #85
    jmneill
    SE
    Well, when I say 22, it's IIRC, and assuming the '15 Tacoma has the same pan as the 5th gen Runner..
  6. Sep 18, 2024 at 12:00 PM
    #86
    Sonofliberty92
    Sonofliberty92 T O Y O T A
    Mark
    Maryland 4 South
    2014 DCSB TRD OR, 2005 Tundra V8 4WD
    I never torque the oil drain plug to "spec". It goes on until it gives resistance and maybe a quarter turn. The gasket does the rest.
    MGMDesertTaco likes this.
  7. Sep 18, 2024 at 1:08 PM
    #87
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    The torque spec in the FSM for one of the tranny pan drain plugs is actually incorrect…too high…
    Or are you talking about the bolts that fasten the pan to the tranny?
  8. Sep 18, 2024 at 1:09 PM
    #88
    jmneill
    SE
  9. Sep 18, 2024 at 3:50 PM
    #89
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    That’s the one. FSM states 21 ft-lbs which apparently is in error and should be 15.
  10. Sep 18, 2024 at 3:51 PM
    #90
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Good time to add a Fumoto so you don't have to worry about stripping it again :)
    abou824[QUOTED][OP] likes this.
  11. Sep 18, 2024 at 7:03 PM
    #91
    gdr
    gdr Well-Known Member
    Bill
    Temescal Valley, Ca.
    2016 Inferno Tacoma TRD OR 4x4
    Can you take a picture from the inside to show what the bung looks like inside. I'm curious to see how thick it is.
    joeyv141 and Jakerou like this.
  12. Sep 18, 2024 at 7:21 PM
    #92
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    That is beautiful. I bet it’s going to feel like a new truck.
  13. Sep 18, 2024 at 8:13 PM
    #93
    Wonka
    Wonka New Member
    Bill
    2022 Tacoma SR5 4x4 /4 door short bed
    Oversized drain plug, Amazon has them!
  14. Sep 19, 2024 at 3:52 AM
    #94
    abou824
    abou824 [OP] Well-Known Member
    Aidan
    Central PA
    '21 TRDOR Army Green 6MT, '13 Lexus RX350
    TRD Lift (Toyota 5100's) LT265/75 AT4W Method MR305 16x8 Bronze ARB Diff Breather Subaru Tweeters Garmin Dash Cam Clutch accumulator delete plate Vibration dampers on MT driveshaft shield
  15. Sep 19, 2024 at 3:54 AM
    #95
    abou824
    Aidan
    Central PA
    :rofl:like it just drove off the showroom floor!
    mquibble[QUOTED] likes this.
  16. Sep 19, 2024 at 5:58 AM
    #96
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Is that dry torque (building new transmission) or wet torque? :p Transmission fluid happens to be a good lubricant and penetrant. 65% of 21 ft-lb is 14 ft-lb.
  17. Sep 19, 2024 at 6:05 AM
    #97
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Note the cutout in the bung, so the drain doesn't act like a standpipe.
    abou824[OP] and Jakerou like this.
  18. Sep 19, 2024 at 6:16 AM
    #98
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I haven't ever checked what the torque specs are for the drain plug, but I find it odd that a Japanese car company would use foot/pounds vs Newton/Meters.
  19. Sep 19, 2024 at 6:19 AM
    #99
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    The FSM is written with metric torques and ft-lbs in parentheses. Occasionally Toyota gets the conversion wrong.
    BTW all the major American automakers (GM, Ford, Tesla) do the design work in metric.
    BabyBilly and koditten[QUOTED] like this.
  20. Sep 19, 2024 at 6:42 AM
    #100
    oldtimertoyota
    oldtimertoyota Well-Known Member
    New Mexico
    2009 4X4 Double Cab-1986 2wd Pickup Orig own
    I’ve personally never used a torque wrench on a drain plug and I’ve never had an issue. I do think they’re a good idea if someone hasn’t done a lot of hand tightening of things
    OP, I would replace the pan and consider it a learning experience
