Stripped oil pan drain plug
Discussion in '2nd Gen. Tacomas (2005-2015)' started by laigepeavitt, Jun 20, 2020.
  1. Sep 15, 2020 at 6:10 PM
    Greenedmc
    Greenedmc Well-Known Member
    Daniel
    Elizabethton TN
    2014 Silver Tacoma Trd Off Road Access cab
    FWIW the lower oil pan is less than a hundred dollars online and should take less then an hour to swap out. Easily doable in a drive way.
    Jimmyh likes this.
  2. Sep 16, 2020 at 5:19 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Where do you live ? I'm in NJ just wanted to compare $$ - I had mine done - have to check but paid more - Thanks.
  3. Sep 19, 2020 at 3:08 PM
    Newk
    Newk Member
    2011 tacoma trd offroad
    I've accidentally stripped an oil pan before :censored:..
    Grabbed my tap and die set, rethreaded with the next size up, cleaned the threads with a magnet, put a bolt and washer in and never had any problems. Takes 5 minutes and is free if you have the right tap and bolt :quickdraw:
    wrightme43 likes this.
  4. Dec 7, 2020 at 3:34 PM
    White Shadow
    White Shadow Well-Known Member
    San Diego
    05 PreRunner
    Stock as it gets
    This just happened to me yesterday. Just like the OP (it’ll tighten then loosen, tighten then loosen), but when I pulled mine out, it came with a spring attached to the bolt (I wish I took a picture of it). It was a threaded one piece in between the threads of the bolt. The bolt was fine. It looked like those springs you get in a pen when you take it apart but a fat one. I was able to put it back in but obviously not tight and put the old oil back in just to move the truck to the street where it is until I get a replacement. But I'm not sure if I should buy the whole setup (Pan, gasket, bolt)
    Do you guys have any idea where that piece of thread might be from? Can the pan thread be broken off like that in one piece? Appreciate the help guys.
  5. Dec 7, 2020 at 4:33 PM
    Tarheel22
    Tarheel22 Well-Known Member
    Raleigh, NC
    2012 Silver TRD Sport 4X4 DCLB
    none yet
    My guess is that your oil drain plug had previously been stripped and repaired with a helicoil. The helicoil is the "spring" thing that came out with your drain plug.
    Juice Weasel and Jimmyh like this.
  6. Dec 7, 2020 at 6:08 PM
    Greenedmc
    Daniel
    Elizabethton TN
    Assuming it’s a 4.0.. Get a lower oil pan with gasket and drain plug.. should be a simple diy in your drive way
  7. Dec 7, 2020 at 6:44 PM
    White Shadow
    San Diego
    05 PreRunner
    Stock as it gets
    Yes, that's what came out. But it's weird because I did the previous oil change and everything was normal that I didn't even noticed anything strange. The oil change prior to my last one was an engine swap and I told the mechanic to use my old pan because the pan of the replacement engine was dented. My old engine had 198k miles and new used engine had 52k miles.
    should I buy another "helicoil" or replace the oil pan altogether? I'm guessing the oil pan threads are stripped since the plug looked normal. Thanks!
  8. Dec 7, 2020 at 6:46 PM
    White Shadow
    San Diego
    05 PreRunner
    Stock as it gets
    It is a 4.0
    What do you mean by a "lower" oil pan? I was thinking of getting everything (oil pan, gasket and plug). Thanks!
  9. Dec 7, 2020 at 6:51 PM
    Greenedmc
    Daniel
    Elizabethton TN
    Here’s a link to some more info
    https://www.tacomaworld.com/threads/replacing-oil-pan.289616/
    The tacoma has a two piece oil pan.. the lower is the sheet metal pan that your drain plug goes into.. it bolts to the upper oil pan which is aluminum and would be more labor intensive to replace.
  10. Dec 7, 2020 at 6:56 PM
    Ensemble88
    Ensemble88 Well-Known Member
    San Diego, CA
    2017 Black OR DCLB
    King suspension, SSO bumper w/winch, Pelfreybuilt sliders, morimoto fogs
    What you described is the bolt trying to grab and missing over and over again when it starts to thread. Usually means the first couple thread pitches are messed up, but the rest are probably fine. Get a tap and die kit and use it to clean up the threads. That'll more than likely fix it.
    Didn't see the part about the helicoil. You might need to rethread to a larger size then. And if that fails, then the new oil pan.
    Afterwards, get a fumoto valve, put some hi temp thread locker on it and call it a day (don't use teflon tape! You don't want those little stringy bits melting off and getting into your oil...). Never have that probably ever again.
  11. Dec 7, 2020 at 7:18 PM
    White Shadow
    San Diego
    05 PreRunner
    Stock as it gets
    That is a very helpful thread. Now I know these trucks have two oil pans. Thank you!!!
  12. Dec 7, 2020 at 7:21 PM
    White Shadow
    San Diego
    05 PreRunner
    Stock as it gets
    I'm just going to go with a new pan, gasket and plug. I can't have my truck sit out again if that doesn't fix the problem. I will get the fumoto valve too. Thanks for the help!
    Ensemble88[QUOTED] likes this.
  13. Dec 7, 2020 at 7:22 PM
    White Shadow
    San Diego
    05 PreRunner
    Stock as it gets
    One last question, do I need some type of sealant/silicone to add to the new gasket? or just gasket alone?
    Thanks
  14. Dec 7, 2020 at 7:52 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Form in place gasket FIPG as Toyota Calls it.
    Ensemble88 likes this.
  15. Dec 8, 2020 at 4:44 PM
    #35
    White Shadow
    San Diego
    05 PreRunner
    Stock as it gets
    Placed my order today for Pan, FIPG, and Fumoto Oil Drain Valve. Thanks for all your help
    b_r_o and Jimmyh[QUOTED] like this.
  16. Dec 8, 2020 at 4:56 PM
    #36
    Jimmyh
    SC
    2012 Prerunner SR5
    :thumbsup:
    Just note the difference in torque values for the bolts and nuts.
    Bolts are 80 in lbs and Nuts are 7.4 ft lbs.
    White Shadow[QUOTED] and b_r_o like this.
  17. Dec 8, 2020 at 5:16 PM
    #37
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    Had this happen to me back when I had about 80k on it. Lower oil pan is very thin and only a couple threads thick for the bolt to grab. Ended up replacing the lower pan ($64 like 8 years ago) and going with a fumoto drain valve. While the job of replacing the lower pan is technically easy, it does take some time to really clean off and prep the mounting surface to get a good seal with the CIPG. My first attempt resulted in a leak and I had to redo it. Of course the second time around I also had to clean and prep the lower oil pan which now had CIPG stuck to it. I spent a lot of time on the second prep. Also was very careful to not move the pan at all during bolt up so as to not disturb the CIPG. Now at 209k and no issues.
    White Shadow and Greenedmc like this.
  18. Dec 12, 2020 at 1:32 PM
    #38
    White Shadow
    San Diego
    05 PreRunner
    Stock as it gets
    Just got done replacing the pan but I forgot to ask how long do I wait until it’s safe to put oil in?
    Thanks again
  19. Dec 12, 2020 at 1:47 PM
    #39
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  20. Dec 12, 2020 at 1:54 PM
    #40
    Spraynard
    Spraynard Priapism survivor
    hagrid
    Pittsburgh
    '19 AeroTundra PRO
    I never see Helicoil kits for external threads... always internal. Limits of the current technology?
    :notsure:
