Stripped oil pan
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacomaHammer, Feb 2, 2018.
  1. Feb 2, 2018 at 12:46 PM
    TacomaHammer
    TacomaHammer [OP] Well-Known Member
    Hammer
    Park City, UT
    2016 Silver Sky Off-Road
    Just now performed my oil change and new oil filter swap for my 25000 service. While tightening back my drain plug I went abit snug and stripped the oil pan thread (or it had prior damage and I finished what was started). Anyhow, Rethreaded it and put a new size oil plug in. Should I leave as is or buy a new pan and next time put back as original? thoughts?
    Drunken Chewbacca likes this.
  2. Feb 2, 2018 at 12:49 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    If it's ok since you rethreaded it and doesn't leak then I would not bother putting a new pan on.
  3. Feb 2, 2018 at 12:49 PM
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    If you got an oversized plug in and no leaks, just leave it. Should be fine.
  4. Feb 2, 2018 at 12:53 PM
    Iamraiderpower
    Iamraiderpower Well-Known Member
    Might I recommend a Fumoto Valve? :D
    BlakeM and 9TRDTCO like this.
  5. Feb 2, 2018 at 1:35 PM
    Opihi59
    Opihi59 Vulgar Boatman
    Beyond Honolulu
    2016 TRD Sport DCSB 6MT
    Unknown lift, maybe 2" I don't know how to ID it, and would rather set it back to stock.
    I suppose it's a case of how good you feel about it. If you over drilled the hole of the old bung, and re-threaded with a proper tap, then it should be good. Though the only time I had to do this it was on a pan that was already off, I have heard of using a tap with the flutes packed with grease to catch the metal shavings if rethreading is done with the pan still installed so that little metal frags don't get sucked around your engine and will stick to the grease instead.
    If you just chased the original threads, or the new plug was a "self-tapping" plug, I'd consider it a bit sketchy and at your next convenience I'd put on that new little pan piece. I replaced the pan on my (I'm second owner) '16 since it was damaged by the PO. It was a real booger getting it off since that Toyota FIPG stuff is really something. I used RTV putting the new pan on, no issues with it so far. I believe the new pan was about $176 though, so it's not cheap for such a small and simple part.
    TacomaHammer[OP] and boynoyce like this.
  6. Feb 2, 2018 at 1:53 PM
    TacomaBlu
    TacomaBlu Well-Known Member
    2017 TRD Sport
    6in Procomp 35in Toyo M/T 18x9 Mamba M13
    Lesson learned, I would put in a new drain pan an install a Fumoto drain valve. Best thing since lite beer.
  7. Feb 2, 2018 at 1:58 PM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Has the dealer ever changed the oil ?
    shakerhood likes this.
  8. Feb 2, 2018 at 2:12 PM
    Opihi59
    Beyond Honolulu
    For my '16, the sub-pan part number was 12102-0P030, but they specifically asked for my VIN to make sure it was the correct part for my Truck. It lists at $230 retail, but I can get wholesale discounts fortunately. It totaled out at $173.57 I suppose the price of that little piece of stamped sheet metal will play a role in the ultimate decisions around replacing it. Not really a tough job, just takes a ton of time getting the residual FIPG off of the aluminum main pan.
    Likely you'd be able to find this online and perhaps save some money on the cost. Stick w OEM though.
  9. Feb 2, 2018 at 2:29 PM
    TacomaHammer
    Hammer
    Park City, UT
    Appreciate the info-I will more than likely switch it out but for now I'll see how it goes. Mechanic at work helped with the threading so I know it was done correctly. Just more money than I'd like to spend on a mess up at the moment. Oem is definitely something I value, too.
  10. Feb 2, 2018 at 2:31 PM
    TacomaHammer
    Hammer
    Park City, UT
    They have which made me wonder. Toyota care blows, all the suggested maintenance practices aren't covered. I'm sure it doesn't matter now bringing it up to them cause it was rethreaded.
  11. Feb 2, 2018 at 2:34 PM
    Opihi59
    Beyond Honolulu
    You're probably accurate in this assessment.
    2016Tacoman likes this.
  12. Feb 2, 2018 at 3:28 PM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    if you had it serviced before I'd say they did it OP, just saying... :D
    No need to replace the pan, this is a common everyday occurrence with many solutions so no need to loose any sleep over it.
    Don't feel bad, you live and learn
    Cheers!
    boynoyce and shakerhood like this.
  13. Feb 2, 2018 at 4:26 PM
    CBRDude
    CBRDude Well-Known Member
    Scott
    Toyota care does blow! My brother has had one issue after another with the skid plates bolts being stripped and busted off. Other brother the same deal. It’s all about doing it on the cheap and fast. The customer is dumb as #$@% so who cares! Scary as #$@%. Makes me think about doing it myself vs. them screwin it up!
    The hammer likes this.
  14. Feb 2, 2018 at 4:37 PM
    The hammer
    It's not just Toyota, is most every major franchise out there that pays under a commission basis. If you want quality, you need to find a reputable and conscientious independent shop.
  15. Feb 2, 2018 at 5:26 PM
    tibadoe
    tibadoe Well-Known Member
    Joe
    Gladys, VA
    17 Tacoma SR 4X4
    I agree. First thing I did was pass on those "Free" services. I enjoy working on my own vehicles.
    The hammer and shakerhood like this.
  16. Feb 2, 2018 at 5:52 PM
    Facts Only
    Facts Only Well-Known Member
    State Of Jefferson
    17 TRDOR DCLB Quicksand
    This.
  17. Feb 2, 2018 at 6:54 PM
    Roland-TB303
    Roland-TB303 Well-Known Member
    San Francisco Bay Area
    2017 TRD Offroad 4X4 DCSB
    My BMW had a hollow drain plug at the shaft that was weakened at the neck. So in case of overtoquing the screw head would shear off and not damage the pan thread. I wonder if there are such aftermarket bolts for our Tacos. Will need to look into.
