Stripped stud
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jfoster92, Jul 27, 2021.
  1. Jul 27, 2021 at 2:00 PM
    jfoster92
    jfoster92 [OP] Well-Known Member
    Justin
    Farmerville, la
    08 Tacoma prerunner v6/manual
    When removing my y pipe to drop the transmission one of the studs on the passenger side manifold stripped. I searched for other but couldn’t fine much on the subject mostly just bolts stuck in the head which I could see sharing similar principles. I was just wondering if anyone had possibly retapped the stud or replaced it somehow
  2. Jul 27, 2021 at 3:11 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    The nuts are pinch nuts. They chew the threads up. I have cut the stud off, and replaced with a bolt.
  3. Jul 27, 2021 at 3:28 PM
    jfoster92
    Justin
    Farmerville, la
    Thanks for the tip. Luckily it was only 1 out of 4 that messed up. Would going back with different nuts be helpful in the future?
  4. Jul 27, 2021 at 3:43 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Put some high temp anti-sieze on them when you put it back together that will make them easier to get off in the future.
    Torspd and jfoster92[OP] like this.
  5. Jul 27, 2021 at 7:25 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Had to
    Do the same thing, nut and bolt. Move on.
    Torspd likes this.
