stripped the fill plug on rear diff
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mpoirier, Mar 18, 2011.
  1. Mar 18, 2011 at 3:37 PM
    mpoirier
    mpoirier [OP] Member
    Charlottesville, VA
    '08 tacoma trd off road
    rear tsb, 5100's at 1.75", weathertech floorliners, wet okole seat covers, 265/75 Goodyear wrangler authority
    so like the title says i stripped the fill plug on the rear diff after changing the fluid today. thankfully its not the drain plug that stripped. anyway, when i went to replace the fill plug it got tight but then broke loose and will not tighten down now. i know i know. too tight. also, it will not back out if i put the socket drive in reverse. i drove around a little and the plug is keeping all the fluid in the rear diff. i guess only bc the plug it at the top of the fluid level. as it stands now the plug is all the way in only hand tight and no fluid is leaking. so now what do i do. do i try to remove the fill plug by using vise grips and pulling out on the plug while i unscrew it? should i buy a new plug before attempting this since the threads are already damaged? what are the chances it is only the plug. could i have stripped out the threads on the rear diff itself, or is the metal the diff is made from stronger than the bolt and it is in fact only the bolt that is stripped??????
  2. Mar 18, 2011 at 3:49 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    The bolt is a very soft metal. So chances are that you just need a new plug. You can get one a any parts store.
    To remove, try to unscrew it while pulling on it.
  3. Mar 18, 2011 at 3:53 PM
    05 TRD Sport
    05 TRD Sport She's Fat, I'm Drunk, It's On.
    30 minutes south of Atlanta
    2016 SR5
    36 ft/lbs. That's really not a lot.
  4. Mar 18, 2011 at 4:17 PM
    mpoirier
    Charlottesville, VA
    keeping my fingers crossed that it is only the plug. could i have damaged the threads in the diff or should i sleep easy knowing the plug is softer metal and it is only the plug that is stripped???
  5. Mar 18, 2011 at 4:19 PM
    S.B.
    Sean
    San Diego
    15 Taco
    Yes, you should be fine. The diff is made from pretty hard steel and the plug is very soft. Just clean the threads (on diff) , making sure there is no metal pieces in the threads before you install the new plug.
  6. Mar 18, 2011 at 4:25 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    When you pull out the plug, it will tell the story. If you see flat threads on the plug and not on the diff, easy fix. Messed up threads on the diff, not easy fix.
    If diff: Get a Keen-Sert to replace the threads. DO NOT use a Heli-coil, it will back out. Keen-Sert, or locking inserts work best. They use standard drill bits and tap sizes, not oddball stuff like helicoil does.
    Make sure there is enough meat on the diff before you get the parts and drill. I have used this fix elsewhere, not 100% sure it will work on the diff.
  7. Mar 18, 2011 at 4:32 PM
    S.B.
    Sean
    San Diego
    15 Taco
    I have only used Heli coils, but agree they will not work (reason stated above). When you drill and tap into the housing, make sure the flush the diff really well to get the shavings out.
  8. Mar 18, 2011 at 4:34 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    R&R your fluid after you get the plug out & pray you get any metal shavings,threads,etc; out, soft metal or not you are going to be double fucked if this shit gets thrown into diff gears (ring & pinion,etc;)
  9. Mar 18, 2011 at 4:37 PM
    S.B.
    Sean
    San Diego
    15 Taco
    Si. Or if you want OP: you can remove the 3rd member then dill and tap or what ever, then clean it all up really well and reinstall 3rd member (make sure you replace the gasket).
  10. Mar 18, 2011 at 4:44 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Flexible arm magnet to remove the remaining shavings.
  11. Mar 19, 2011 at 7:07 AM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    There should be enough room to weld a new nut on top of the fill hole and install a new bolt. Pic?
  12. Mar 19, 2011 at 7:21 AM
    river rat 69
    river rat 69 Well-Known Member
    Jim
    Orlando, Fla., Green side of the grass
    007, trd, sr5, fmf.
    NO Chrome,3" NFab's steps,TRD skid,Wet okie's.011 grill, k&n,5100's,All this comes right off when the old lady says let's go get a NEW ONE!!!
    X2 you will need a new plug but in will be ok. i would drain strain&refill.
  13. Sep 29, 2012 at 12:43 PM
    Amos
    Amos Well-Known Member
    Daniel
    Huntsville, AL
    09 4x4 DC sport
    Did you ever get your plug out and get it fixed? I just did the same thing :( I was using a torque wrench, but apparently it doesn't work anymore...
  14. Sep 29, 2012 at 12:56 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Worst case scenario, leave the cross-threaded fill plug in place, and fill using the breather hole in the future.
  15. Sep 29, 2012 at 3:29 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    If you can get a screw driver under the head you can pry up on it while you try to back it off with a socket or a wrench.
  16. Sep 29, 2012 at 7:32 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    weld it......:p
  17. Oct 1, 2012 at 12:42 PM
    Amos
    Daniel
    Huntsville, AL
    09 4x4 DC sport
    I have a new bolt on order from the dealer, still have to get the stripped one out and hope it was only the bolt and not the diff threads...
  18. Oct 1, 2012 at 12:48 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    If all else fails you can just leave the plug in, if it leaks seal it up with jb or weld it, and then just fill the diff with exact amount from the breather hole.
  19. Oct 1, 2012 at 1:00 PM
    shemp
    shemp Well-Known Member
    I doubt that its possible to fill from the vent. The gear oil will plug it and there is nowhere to vent the pressure off from. You'd have to drill/tap a second vent hole to do this successfully.
  20. Oct 1, 2012 at 1:18 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    I don't. It's been done before. It'll be slow but it'll work. Can always stick a small piece of tubing into the hole along side the tip of the bottle for a breather.
