Stripped threads on drain plug
Discussion in '1st Gen. Tacomas (1995-2004)' started by Zvilly96, Jan 26, 2023.
  1. Jan 26, 2023 at 10:29 AM
    Zvilly96
    Zvilly96 [OP] New Member
    Zack
    98 tacoma
    I was Doing an oil change on the new to me automatic 2.7 4x4 98 tacoma for the first time and noticed the threads on the pan were stripped upon removal of drain plug. Also saw that the gasket in between the upper and lower pan is leaking very minimally. I’m leaning towards dropping the lower pan replacing it as well as getting a fumoto drain plug. On the other hand I could re tap the plug and ride it out. What’s the consensus here? Also if I do drop the pan is there enough room to get it out or will I have to disassemble anything to make room ? The last 3-4 threads were fine so I was able to do the oil change and torque it accordingly. Thx in advance
    HondaGM likes this.
  2. Jan 26, 2023 at 10:33 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW...if the boss has enough to tap thats probabably the cheapest route..ive never had to buy a pan so i dont know how much they are
    Zvilly96[OP] likes this.
  3. Jan 26, 2023 at 10:34 AM
    1schoir
    1schoir Well-Known Member
    Freeport, NY
    2006 Red Tacoma SR5 Access Cab 5 speed..1995 Blue Tacoma Extra Cab 4 cyl 5 speed...
    This all depends on your definition of the phrase "leaking very minimally". These "minimal" leaks usually get worse over time, so if you are going to keep the truck for a while...
    At the very least, I would opt for tapping the plug to see if you can eliminate that as the source of a future problem.
    HondaGM likes this.
  4. Jan 26, 2023 at 10:39 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Looks like RockAuto has a couple of options for well under $100. I have no idea how easy or hard it would be to replace.
    HondaGM likes this.
  5. Jan 27, 2023 at 9:56 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Unless you change your oil more than once a year or so, I would just "torque it accordingly" and let it go. When the oil puddle gets to be more than an inch around, then I would consider the previously mentioned options. I don't know how hard it is to remove the pan on your Tacoma, but on mine (3.4L engine) it's quite a job.
