Stripped Union/breather hole on rear diff
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Texasantilib, Jul 25, 2014.
  1. May 4, 2020 at 8:34 AM
    #61
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
    Reading more about this coupling that just spins... Do you have a very thin crescent wrench that you can fit under hex portion and around the shaft.. If so you can get a really good amount of leverage using that as the lever while simultaneously using a socket wrench to turn the hex part...
    I have used this approach before and it works well...
    Or a very small pickle fork (ball joint)
  2. May 4, 2020 at 10:17 AM
    #62
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Turned stripped - I just put some Teflon tape on it and screwed it in - been good 4 years.
