Strobe Relays/Modules
Discussion in 'Lighting' started by blackhawke88, May 15, 2012.
  1. May 15, 2012 at 2:03 PM
    blackhawke88
    blackhawke88 [OP] wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    Hello All,
    I want to have all my LED off road lights able to strobe with one of these strobe relays/modules:
    http://www.soundoffsignal.com/electronic/elec_etledfc1.htm
    problem is, the highest rated module i can find is only 3 amps.
    All my LED lights added together will draw 15 amps.
    Is it possible to have the strobe module hooked up to the circuit prior to the relay, so it is actually strobing the relay, which in turn activates the lights? or will that quickly burn out the relay? Thanks!
  2. May 15, 2012 at 2:16 PM
    tacomafide
    tacomafide Cheese it in there!
    Sean
    Alberta
    '10 DCLB TRD Sport+Leather Pkg.
    de-badged, de-stickered, no jewlery, level kit (removed after second front dif), tint, skid plate (now dented), front tow hook off of Land Cruzer, reciever d hook (cleavis), yellow wire mod, abs kill sw. mod, window visors, stubby antena, anytime reverse lights mod, anytime reverse camera mod, blizzacks on stealies, bed lights mod, weathertec mats allround,
    15a from LEDs huh, mother f'r.
    R u sure??
  3. May 15, 2012 at 2:18 PM
    tacomafide
    Sean
    Alberta
    The relay might not even be able to pick/drop at strobe speeds.
    I would not go that route.
  4. May 15, 2012 at 2:20 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
  5. May 15, 2012 at 2:24 PM
    NoSoup4You
    NoSoup4You Well-Known Member
    David
    San Clemente
    2008 DCSB DMZ LT 4x4
    Camburg | King | Glassworks | DMZ | Nitro | Banks | Pelfreybilt | Brute Force Fab | Bay Area Metal Fab | Baja Designs | Rigid Industries | STL
    I have seen 10A LED strobes .. can you do with 2?
  6. May 15, 2012 at 2:29 PM
    tacomafide
    Sean
    Alberta
    Could u get a strobe module for each one?
    What's another 100 bucks?
  7. May 15, 2012 at 2:31 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
  8. May 15, 2012 at 2:47 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
  9. May 15, 2012 at 2:57 PM
    NoSoup4You
    David
    San Clemente
    ya, that's a lot better than what I was thinking of.
    I was looking at brake light strobes .. they handle more amps but don't have selectable patterns.
    nice find :thumbsup:
