Strong Mildew Odor ? Possible Water Leak ? 2007 Access Cab
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Reef Runner, Jun 4, 2016.
  1. Jun 4, 2016 at 1:54 PM
    Reef Runner
    Reef Runner [OP] Well-Known Member
    Nick
    John H Kerr Reservoir, NC
    ‘18 Super White 4x4 TRD Off Road with Dbl Cab & Long Bed
    Over the last couple of years, I have been noticing a progressively worsening odor, in my 2007 Tacoma Access cab. I get the smell of "mildew", when I first get into the truck, and start it up. I have checked and changed the cabin filter. The smell was not coming from there, as I had once expected. I have now determined that the smell is coming from the doors. I can smell mildew quite strongly, if I put my nose down around the window crack (where the window goes down into the door).
    So, I am wondering if anyone has experienced this, and is there a drain, somewhere on the doors, that may become clogged, and hopefully, can it be cleared ? I'm thinking I have water accumulating down in the bottom of my doors. I also notice this more during the summer months, and especially right after a rainy spell, or after I wash the vehicle.
  2. Jun 4, 2016 at 3:39 PM
    Reef Runner
    Nick
    Somebody has got to have experienced this ???? Right ???? :confused:
  3. Jun 4, 2016 at 3:50 PM
    Clearwater Bill
    Billy
    Largo Florida
    Yes. On the bottom of the doors. Not hard to find, should be able to clear.
    If trouble clearing, may have to remove door panel, get down inside the door and remove goop/sludge, etc that may have built up.
  4. Jun 4, 2016 at 4:03 PM
    DEMikey
    DEMikey Mr. Badwrench
    mikey
    delaware
    2013 red taco
    100XR, OTW Surf Rod Rack, Toytec 3" lift, +1 on tires
    make sure your A/C evaporator drain is clear also. if not, the evaporator box will fill up with condensation and become stagnant, and if you run it long enough, it can spill onto the passenger floor.
  5. Jun 4, 2016 at 4:10 PM
    Reef Runner
    Nick
    Thanks for the suggestions. The smell is definitely coming out of the door. I believe that the drains must be stopped up. I'll check them tomorrow ! Are they towards the front, back, or middle of the door. What is the approximate size of the drain ?
  6. Jun 4, 2016 at 8:27 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The drains should be along the bottom edge of the door. There should be three or four openings. It would probably be a good idea to open the door and clean inside if one of the drains are plugged if nothing else than to clean and dry it off inside to prevent rust.
  7. Jun 5, 2016 at 5:17 AM
    Reef Runner
    Nick
    Any suggestions on getting inside the door. Does the interior panel just snap off and on ? Also, do I need to remove the arm rest first ? I'm not so sure I know exactly how to do all of this, without tearing something up ?
  8. Jun 5, 2016 at 5:52 AM
    Jimmyh
    SC
    2012 Prerunner SR5
  9. Jun 5, 2016 at 7:21 AM
    Reef Runner
    Nick
    Ok, next question.....
    No need to remove the door panels. I looked under the door and found the drain holes (3 of them - front, middle, back). The bottom of the door is clean, there is no trash, dirt, leaves, insects, etc, in the holes. They are completely open and unobstructed. Ignition key, or screw driver easily pass through - there's nothing there ?
    So, why would if have a strong mildew odor coming from my doors. If I roll either window (driver or passenger side) down, and smell right above the window slot, the odor is very strong (?). The truck is not wet or damp, anywhere that I can see or feel, on the doors or on the carpet. I am perplexed !
  10. Jun 5, 2016 at 7:31 AM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    The panels themselves might have gotten wet at one time, and need to be cleaned/shot with Lysol, or maybe even replaced. BUT, only if you are totally sure it's not the carpet that smells.
  11. Jun 5, 2016 at 7:47 AM
    Jrobertson
    Jrobertson Well-Known Member
    James
    green valley (Henderson)
    2010 Tacoma off road. 4x4
    Stock. For now.
    My 2010 recently started having this issue. Still haven't figured it out. Plan is to leave parked with the windows down. It's 111 in Vegas this week. Should dry things out
  12. Jun 5, 2016 at 7:52 AM
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    Two things to check: I discovered in mine that the plastic liner inside the door panel actually collects/traps water at the bottom - I removed a couple inches of the butyl caulk at the bottom to let it flow out. Also, there is a padding attached to the door panel that may be getting wet and staying wet. The panels are easy to get off once you know how. I've done it several times now.
  13. Jun 5, 2016 at 8:13 AM
    Reef Runner
    Nick
    The smell is definitely coming out of the window slots. I can't smell anything on the floor (carpet), anywhere, plus I can't see how the smell, should it by chance be the carpet, could possibly find it's way up into both doors. Also, I thought there was a plastic barrier, to keep the inside panel from getting wet.
  14. Jun 5, 2016 at 9:07 AM
    Skrain
    Monticello, Ky
    2009 F.J. Cruiser
    You might just have to pull the panels to visually inspect them..
  15. Jun 5, 2016 at 9:10 AM
    Reef Runner
    Nick
    Aren't the interior panels protected by plastic, from the water that may pass through from the window slot to the drain holes ?
  16. Jun 5, 2016 at 9:15 AM
    Skrain
    Monticello, Ky
    2009 F.J. Cruiser
    I think so, but short of actually looking inside to visually check, it's hard to tell WHATS going on in there to cause the smell.
  17. Jun 5, 2016 at 9:16 AM
    Reef Runner
    Nick
    I understand, but I really hate to destroy the plastic barrier to get inside the door....
  18. Jun 5, 2016 at 9:17 AM
    Skrain
    Monticello, Ky
    2009 F.J. Cruiser
    I understand, but not too many other options...
  19. Jun 5, 2016 at 9:20 AM
    Skrain
    Monticello, Ky
    2009 F.J. Cruiser
    If you look at the video, if you pull the panel carefully, you won't hurt the plastic barrier
  20. Jun 5, 2016 at 9:21 AM
    Reef Runner
    Nick
    Is there anything on the other side (outside) of the plastic barrier, that would hold, or soak up water ? If the interior door panel is dry, there shouldn't be anything else, should there ?
