strong smell of gas around my truck.
Discussion in '1st Gen. Tacomas (1995-2004)' started by lineman2001, Sep 27, 2013.
  1. Sep 27, 2013 at 6:51 PM
    lineman2001
    lineman2001 [OP] New Member
    john
    virginia
    95 toyota tacoma
    3 inch suspension lift, cold air intake, dual fans, optima battery, and locked rear end.
    This is my first ever question I'm new to this site. Recently I've noticed a strong smell of gas around my truck. I thought the cap wasn't venting so I barely put it on, and that helped. However now its back again. Its now longer got a lot of pressure on it, but the gas smell is still very strong. Any help with this would really be appreciated. Thanks
  2. Sep 27, 2013 at 7:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW! It could be that the fuel cap is cracked. Have it tested, or replace it, and see if that helps.
  3. Sep 27, 2013 at 8:20 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Where do you smell it from? The front, rear, in the cab. Is the truck hard to start at all? Fuel pulsation dampener, fuel pressure reg, fuel filter maybe. Just did a quick search on yahoo and seems to be a common issue on 3.0L's
  4. Sep 28, 2013 at 4:36 PM
    polack
    polack Well-Known Member
    I have a similar problem. i notice it when i exit my truck. The problem with mine is the evaporator canister. Mine is fucked and for some reason instead of sending my fuel fumes to the engine to burn off they are venting to the atmosphere. 360.00 dollars to replace or i clear the check engine light once a week and deal with a little gas smell every now and then.
  5. Sep 28, 2013 at 4:56 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Likely from topping off the tank.
    Fill it until it clicks and you're done.
    Aught2TaCO likes this.
  6. Sep 29, 2013 at 7:08 AM
    polack
    I've never topped off any tank. I bought this eight months ago and the code came up two days later. PO was an old guy so i imagine he did it.
  7. Sep 29, 2013 at 9:28 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    Fuel leaks in the Tacoma are VERY common. The culprit of where that fuel could be coming from from are vast. The leak could be coming from the gas cap, corrosion from the fuel filler neck where the gas cap mates to the truck, the fuel tank gasket, fuel filter, the Charcoal Canister. The only real way to track it down is to have a smoke test done at a service shop. The leak may be minuscule and even the smallest needle point leak will cause the sensors to go off. My suggestion, spend the $70-$80 to have a Smoke Test done, find out for certain where the leak is coming from and decide if the truck can be operated with no issues or pay to have to part replaced. Or you can get a smoke test done, and just deal with the CEL by clearing the code out yourself. Lots of options.
  8. Sep 29, 2013 at 3:21 PM
    polack
    My code doesn't affect fuel mileage or performance so i clear mine every time it pops up. About twice a week. Smartphones are great tools.
  9. Sep 29, 2013 at 3:31 PM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    Check the purge valve. It's not the most expensive thing and can cause the you to smell fuel.
  10. Sep 29, 2013 at 6:19 PM
    04trd
    04trd Well-Known Member
    Cleveland Ohio
    2015 f150 lariat
    weather techs, 20precent tint, leveling kit, back flip bed cover, rhino liner
    Try this stuff. It works great for getting rid of gas:p
    otis24, EB Group and o0oSHADOWo0o like this.
  11. Sep 29, 2013 at 6:40 PM
    TACO TX
    Kelly
    Denison ,Texas
  12. Oct 3, 2013 at 6:48 PM
    polack
    That's the first thing i replaced. it was cheap but not the cause. i'm going to set up a smoke test and hope the find something small.
  13. Oct 3, 2013 at 7:18 PM
    Hektor
    Hektor Well-Known Member
    Texas
    04 Tacoma 4x4 TRD DC v6
    Charcoal canister!!!!!
  14. Oct 4, 2013 at 1:17 PM
    shift96
    shift96 Well-Known Member
    how do you clear it from your smartphone?
  15. Oct 4, 2013 at 4:55 PM
    polack
    360.00 dollars!!!! i'd rather pay 70.00 when it's in getting the front end looked at to make sure.
    There is an app called Torque. Download it. Go on ebay and buy a Bluetooth OBD II scanner for like ten bucks. Run the app and there is an option to check codes and clear them.
  16. Oct 6, 2013 at 2:41 PM
    Hektor
    Texas
    Yep charcoal canister it's pricey, my friend had the same problem as you and it was the charcoal canister he couldn't stand the smell of gas as it gets worst. Good luck
  17. Oct 8, 2013 at 3:02 PM
    TXSTICK
    TXSTICK Active Member
    Chuck
    Tucson AZ
    2014 PreRunner TRD Sport Quad Cab 4.0
    Just went thru this on my 2002, at first it did not throw a code but I could smell the gas near the bed of the truck. More so on the driver side.
    The truck has 131,000 miles on it. I read a lot about the charcoal canister could be the problem (cost a lot 300.00 from the dealer).
    So I replaced it, the code came back and still the strong gas smell, worse with a lot of gas in the tank. The code said it could be the gas cap, so I replaced it, no change. I finally read a post from someone who had this problem and when they dropped the tank the seals around the full pump and the check valve were leaking gas on too the top of the tank.
    I bought all of the seals that go on the top of the tank (not to bad on cost) from the dealer and a new over flow check valve (it is cheap). When I dropped the tank, sure enough you could see were the fuel had been leaking on top of the tank and drying out. When I was pulling off the vapor/fuel lines two of them broke, so I got some new lines at the auto store. Not pre-formed but not required. Put it back together and the smell is all gone and no more codes.
    Save your self some money and wait on the canister. A few others also added to the thread and said they had the same thing happen with the leaking seals. Also if you have not done it replace your fuel filter on the rail under the driver side door.
    A mech at a local toyota truck shop told me he replaces lots of seals on the tank and very few canisters.
    If you don't have a scanner to clear the code, unhook the batt for a few min.
    Sorry, missed the part about the phone app.
    Chuck
    ugmold, EB Group and Dcsleeper408 like this.
  18. Oct 8, 2013 at 4:17 PM
    polack
    THANK YOU SO MUCH!!
    Going to take a look tomorrow after work. I hope this is my problem also.
  19. Oct 24, 2013 at 8:51 AM
    eunit
    eunit Member
    ernie
    las vegas
    15 dblcb
    I have the same problem. I was thinking I should get the seals be for I pull the bed.And maybe a fuel pump while its off.How did this work out for you?
  20. Oct 24, 2013 at 4:04 PM
    polack
    I filled my fuel tank up, cleared my codes and drove around town doing errands. No fuel on the top of my tank anywhere. Almost on empty and haven't thrown a code. odd, seeing as i use to have to clear the code every two days. Going to try a different fuel cap if the codes pop up again before i just break down and buy the damn canister.
