strong smell of gas around my truck.
Discussion in '1st Gen. Tacomas (1995-2004)' started by lineman2001, Sep 27, 2013.
  1. Oct 24, 2013 at 6:24 PM
    hec983
    hec983 Well-Known Member
    Tellin you bro canister and it won't be cheap.
  2. Nov 16, 2015 at 5:17 PM
    louied817
    louied817 Well-Known Member
    So I have a 1996 and have strong smell of gas on driver side. When I get into wheel well its very strong. Weird thing is that it doesn't throw a code. Any ideas.
  3. Nov 16, 2015 at 6:45 PM
    ToyoTaco02
    ToyoTaco02 Well-Known Member
    Scott
    Decatur,IL
    02 PreRunner DC 2.7L
    OME 881 1/4" top plate spacer OME Dakars OME Nitrochargers Light Racing UCA
    I changed my canister and I'm still throwing codes. I've been told there is a valve on top of the tank that can go bad as well. I just clear the codes every so often.
  4. Dec 27, 2015 at 4:38 PM
    louied817
    I haven't thrown a code yet. Strong gas smell especially in summer and just outside driver side door. Really strong between bed and cab (space). Any ideas??
  5. Dec 27, 2015 at 9:04 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    the charcoal canister right in front of your front left tire. or it could be the fuel filter right exactly where you described. just inside the frame. but only if you have a 6 cyl.
  6. Dec 28, 2015 at 8:31 AM
    TXSTICK
    TXSTICK Active Member
    Chuck
    Tucson AZ
    2014 PreRunner TRD Sport Quad Cab 4.0
    You will have to replace the seals on top of the tank. After they get older it starts to seep and leaks vacuum.
  7. Dec 28, 2015 at 8:04 PM
    ToyoTaco02
    Scott
    Decatur,IL
    Is it easier to drop the tank or take the bed off?
  8. Jan 11, 2016 at 6:10 AM
    louied817
    So I haven't thrown code yet. Been driving for a while with strong smell. No leaks visible. All started when I topped off tank in summer. Again no leaks visible however when I put my hand on gasket I smell gas on hand....
  9. Apr 12, 2016 at 7:04 AM
    EB Group
    EB Group Carbon Jedi
    Rudy
    Halifax
    2017 TRD Sport DCSB 6M
    Take the bed off! You need to get at the top and it's all there when you remove the bed.
    Dropping the tan without removing the bed is a bear.
    I've done both.
  10. Apr 12, 2016 at 12:18 PM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    I've had this problem for a while now. I noticed it on driver's side, right behind the cab. Mostly noticed the smell for a few days after filling up, and only when I was driving. It wouldn't smell after sitting overnight. Just after I'd been driving. I could see wetness on the top of the tank, around where the sending unit goes in. It had thrown a code (P0442, small evap leak).
    So when I had my bed off to coat the frame in December, I replaced the gasket under that unit. Of course, I went and fucked up putting the unit back on and destroyed one of the 8 screws/bolts beyond repair (but hell did I try everything I could think of to get the broken one out). So I resigned to 7 out of 8. Figured it'd be no issue. And sure enough, gas smell went away and after I cleared the CEL, the code did not return. Until last month.
    The gas smell is back and the same code has returned. I also have another code. (P050, I think. Very small evap leak). I got a new Stant fuel cap, hoping that clears the new one, as it is still pending. So now I have to start looking at fuel lines and such. My worry is that only having 7 out of 8 screws on the sending unit is the issue, but then I wonder why it was fine for 3 months. Who knows. Eventually I will figure it out. I am just hoping that I won't have any issues with inspection. It's just emissions here in NJ, but I am due this month.
  11. Apr 17, 2016 at 10:14 AM
    louied817
    Sender gasket replaced and fixed. Beautiful. Job complete. Thank you all.
    cruiserguy and EB Group like this.
  12. Apr 17, 2016 at 2:47 PM
    EB Group
    Rudy
    Halifax
    Great job! Happy to hear!
  13. Dec 21, 2018 at 7:47 AM
    SurfInferno
    SurfInferno Dont be stupid, its not smart.
    Dylan
    Littleton, CO
    2001 DC
    I know it’s an old thread, but does anyone have the part numbers to replace the seal/valve on the top of the tank?
    crazytacoman likes this.
  14. Dec 22, 2018 at 6:10 PM
    Kamakiri
    Kamakiri Overland and Overwater
    Joe
    West Haven Connecticut
    2004 DCSB TRD 4WD SR5 LunarMist 151k
    I’m experiencing the same — mainly when the tank is full, and a day after a fill up the code goes.
    Mechanic said it was an evap code, and I bought a cheap code reader and had already decided to go about clearing the code now and then. I managed to pass emissions just fine — clearing the code just after it is thrown then driving around for a few days and doing emissions on a low tank of gas seemed to work.
    It threw the code today after some good bumps on I-95, so maybe it is a deal jarring loose somehow.
    Staying subscribed to this thread for other advice and updates
